HWiNFO support of vintage hardware
Reply 580 of 683, by appiah4
Latest version on web does not launch on my Cx5x86 Win95C PC. I see it in Task Manager but the window never opens.
Reply 581 of 683, by Mumak
appiah4 wrote on 2021-12-07, 22:18:
Try this build: Re: HWiNFO support of vintage hardware
Reply 582 of 683, by appiah4
Mumak wrote on 2021-12-07, 22:29:
That one actually launches, but Win95 locks up as soon as the summary window opens..
Reply 583 of 683, by Mumak
appiah4 wrote on 2021-12-08, 19:56:
Please enable Debug Mode and after the lock up reboot the system and attach the HWiNFO32.DBG file it produced.
Reply 584 of 683, by appiah4
Mumak wrote on 2021-12-08, 20:03:
Here you go..
EDIT: As a pointer, the CPU is detected correctly as 120MHz, 40MHz with 3x multiplier, but on the line below (Effective) the speed is detected as -2 and multiplier detected as -0,05x or some such. Then it locks up.
Reply 585 of 683, by Mumak
appiah4 wrote on 2021-12-08, 22:07:
Here you go..
Thanks. Will it also lock up when you launch it in Sensors-only mode?
Reply 586 of 683, by vorob
1.88 MiB
My Toshiba Satellite Pro 430CDT completely froze on app launch. Expected behavior? I’ve got 40gb hdd here.
Reply 587 of 683, by Mumak
vorob wrote on 2022-01-13, 16:08:
Please enable Debug Mode and after freeze and reboot post the HWiNFO32.DBG file it produced.
Reply 588 of 683, by vorob
Here you go. Thanks.
Btw, is there a way to understand if this machine can handle HDD in DMA mode? I don't have such option in Device Manager of Windows...
    HWiNFO32.zip
    2.02 KiB
    47 downloads
Reply 590 of 683, by Mumak
vorob wrote on 2022-01-16, 07:52:
HWiNFO can tell you what DMA modes the drive supports if it can query the IDE drive. If it doesn't you might need to enable Low-level IO Access for IDE/SATA Drive Scan.
Try to put the following line into the [Settings] section of the HWiNFO32.INI file to skip LPC test and avoid the crash:
LPC1=0
Reply 591 of 683, by leonardo
Mumak wrote on 2021-10-24, 21:25:
leonardo wrote on 2021-10-24, 21:04:
Here are the report files for my older systems: […]
I would also like to note that HWiNFO 7.12 does not start on Windows 95. There is no error, it just fails to load. Dependency Walker doesn't find any issues with 7.12, either. Version 6.24 runs, so that's what I used to generate the debug files and reports.
Thanks for the reports, the output looks good to me. Would you be able to try some versions between 6.34 and 7.12 to find out which is the latest one working on Win95?
Sorry it took me this long to respond. It looks like 7.16 is good again on Win95. I've included a screenshot highlighting some weirdness in the GUI regarding the FSB on my system (it's supposed to be 75 MHz, meaning the memory should also be reported to run at this freq.) The GUI now also stretches sideways so that you can't properly view it on a 4:3 screen:
41.59 KiB
GUI screenshot
Maybe make use of a tabbed interface (CPU/mobo/GPU) here, or make it scrollable?
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 594 of 683, by vorob
Well, I need to run HWINFO DOS in safe mode command prompt with no mem utilities, but then it tells me that I don’t have memory?
1.26 MiB
Reply 595 of 683, by Mumak
vorob wrote on 2022-02-05, 20:25:
Looks like not enough free system memory, most likely because other drivers and TSRs are running.
Reply 596 of 683, by appiah4
You need more RAM. You can download some from the interwebs.
Reply 597 of 683, by debs3759
appiah4 wrote on 2022-02-07, 18:29:
I'd max out all my systems if I could just download more memory 😀
Reply 598 of 683, by vorob
FYI. According to this site GeForce 2go should have 143mhz, https://www.techpowerup.com/gpu-specs/geforce2-go.c1554 but hwinfo report wrong value.
385.63 KiB
Reply 599 of 683, by Mumak
vorob wrote on 2022-05-17, 20:14:
Please attach the HWiNFO Debug File so I can analyze the details.
