Reply 100 of 111, by SETBLASTER
Horun wrote on 2019-09-19, 02:40:
Since I own a VS440FX and MU440EX and will try to DL all the "Legacy" last BIOS and post to usenet somewhere.
I cannot find any of the BIOS thru their ftp so may not get all the old boards listed as will have to DL thru their support website.
horun . did you manage to get all stuff for a MU440EX motherboard? i just got one of those and i cant find anything on the web for it. since it has an integrated ati rage and also integrated yamaha chip. pentium2 tho it looks very nice board. can you share the drivers for it?
Reply 101 of 111, by PC Hoarder Patrol
Think most of it is available here
ftp://oisellerie.org/drivers/Intel/MU440EX/
I downloaded my copies direct from Intel last year - this was what was on the page at the time
171.05 KiB
Reply 102 of 111, by SETBLASTER
PC Hoarder Patrol wrote on 2020-05-08, 19:37:
Think most of it is available here […]
thanks for the image screenshot, i wish i had done something like that on all the Aopen boards and soundcards before aopen deleted everything.
now this was strange because intel site didn´t have ati rage drivers for win95
and looking online , i found another site that do have the drivers for ati rage win95
https://rebyte.me/en/intel/124362/
Reply 104 of 111, by PC Hoarder Patrol
Depending on your boards AA / PBA revision level and with the latest BIOS for whichever version that is (beginning 4M4uE0X1 or 4M4UE0X3), up to Slot 1 PII 333MHz (although it may support the 533MHz Celeron Skt 370 on a suitable slocket adapter)
Reply 105 of 111, by rawrau
Hello! I hope I am not too late... I have an Intel DH77EB board and now that I wanted to add a modern GPU I was supposed to update the BIOS from the stock 053. However, upon finding out about these news, and after visiting Intel's site for recommendations, the method for updating the BIOS via recovery failed.
Is there any chance someone here saved all BIOS versions for all board and happens to have them?
Since I can't update from 053 to 103 directly using the recovery method, I think the only way to fix this is flashing all the individual updates one after another, but that won't be possible without all the .BIO files
Please, someone help me with this!
Reply 106 of 111, by PC Hoarder Patrol
This looks like the complete bios revision history upto v0103
http://cwcyrix.duckdns.org/intel-legacy-files … eleaseNotes.pdf
Haven't checked that they have every one, but DriverGuide seem to be hosting quite a few of the versions
https://members.driverguide.com/driver_search … www&gqm0=dh77eb
EDIT: You might find a few more versions here
https://fr.pcdrivers.guru/intel-r-desktop-boa … 2.html#download
Reply 107 of 111, by rex89
rawrau wrote on 2020-06-28, 05:05:
Hello! I hope I am not too late... I have an Intel DH77EB board and now that I wanted to add a modern GPU I was supposed to upda […]
Hey Buddy,
Did you manage to update your motherboard Bios? I have the same motherboard model and wanted to upgrade my GPU to the latest one.
Please share the Bios file/files which worked for you and also a little help note will be appreciated.
This will be my first time when I'll be upgrading my Bios. I've attached an image to showcase you my current Bios version. As far as I remember I've not updated the bios to date.
@all If anyone has the same model and can share the files and few notes to take care while upgrading will be appreciated.
Your help will be highly appreciated.
Thank you.
    6.71 KiB
Reply 108 of 111, by penguinponics
Got 101 off driversguide which feels sketchy enough but it worked. I see there are or were several attempts at getting all the BIOS's. Has this been accomplished? Do they need a more permanent home? I could host them for the next several years. I'm also an Intel reseller and put in a request with them to at least list the BIOS updates since many of the newer boards support UEFI but often need to be updated for things to work properly. HOPEFULLY they'll do that at the very least.
Reply 109 of 111, by lamer_joe
Hi there
I found that if you find your product on the intel site (e.g. https://ark.intel.com/content/www/us/en/ark/p … ard-dg31pr.html) you could then take the url and place it in the wayback machine (http://web.archive.org/) and choose the last date that the product page was updated(in my instance 2nd September 2019) before 22 November 2019 then you can go to the “Downloads and Software” section and retrieve the drivers/bios/manuals that you need.
As another example I saw that DH77EB was being looked for - http://web.archive.org/web/20190901154639/htt … op-Board-DH77EB
Hope that this helps... sorry if it is a repost
Reply 110 of 111, by NinthWave
enigmaxg2 wrote on 2019-11-22, 18:54:
I downloaded manually all the BIOSes I could and organized into Socket/Chipset/Board/Version it's almost 2GB in size. […]
In case of a transitional BIOS needed but no longer available (thankfully were only 2 or 3 cases across the entire board list) I took it from the rebyte site.
This is an example of how I organized them:
Also downloaded some Wifi and Bluetooth drivers (and streamlined the archive because most of these are shared across devices). Another 2GBs.
Hello,
I hope it's not too late and you still have those files...
I am looking for a FW for 1200V3RPS version 02.01.0002
It's a 1150 socket
I am crossing my fingers.
Reply 111 of 111, by darry
NinthWave wrote on 2022-11-17, 04:53:
Hello, I hope it's not too late and you still have those files... […]
Hello,
It's a 1150 socket
Hi,
If you had followed @lamer_joe's instructions in the post just before yours in this thread, you would have found what you are looking for.
For your convenience, I have done the legwork for you.
Here it is (version 02.01.0002) :
https://web.archive.org/web/20190905063925/ht … 1_FRUSDR106.zip
Newer versions are available, by the way (newest being 03.04.0002 ):
https://web.archive.org/web/20190903062445/ht … oard-S1200V3RPS
