Reply 40 of 111, by Horun
karl80038 wrote:
I'd like to apologize for my very late reply, however I archived a lot Intel download links to archive.org between October 9th and October 10th. I then pasted the links in a text file that I'd like to share now. Hopefully it'll be useful to someone and they can get the driver without needing to download the large archive.
It may not have all the items that were at some point on Intel's website, but I think most of the common downloads are represented
Awesum job karl and Thanks for the fine work !
Reply 41 of 111, by jaZz_KCS
Very, VERY much appreciated. In the name of the ever ongoing crusade that is the preservation of data, I salute you.
Reply 43 of 111, by Horun
Update: have grabbed every Manual and latest BIOS from Intel except the newest boards, have a week to go so should have most if not all of them. Am grouping them by series to make it easier.
Question: this is my current layout (see attached file), Archive by series then archive by board.
Can some someone give me a "this would be better" or "that is OK" or other suggestion before I start uploading to archive ? Thanks !
    42.75 KiB
    61.13 KiB
Reply 44 of 111, by chinny22
Think your doing a good job
I'd say its easier to scrap he series folder and just have a big list of motherboards to scroll down.
But if you have alot of instances of common files like the BIOS Update Readme.pdf in the example above I think your current method makes the most sense and the folder names are easy enough to understand.
Reply 45 of 111, by Horun
Thanks ! I will post it all as a big list as you say and also post in groups of series so someone will not have to download 1Gb+ just to get one manual or one BIOS if they know their board model number.
Reply 48 of 111, by karl80038
Yes, Intel has unfortunately removed the files from their server. However you should be able to download the files by using Archive.org Wayback Machine.
I archived many download links there right before the files were removed from Intel's website. I'm starting to archive Intel's BIOS updates very soon and will then post the links in this forum thread.
Reply 49 of 111, by franpa
Meanwhile, Nvidia still offers driver downloads for extremely old video cards from the 90's onwards https://imgur.com/a/lfTO91J however it's a shame they don't host all the drivers. Under Windows 9x, driver compatibility with games was highly volatile and you'd need specific driver versions for whatever games you were primarily playing at the time. With Windows XP and newer this mostly stopped being an issue.
Edit: Vogons already has many of the Nvidia drivers at http://www.vogonsdrivers.com/index.php?catid= … &menustate=14,1
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 50 of 111, by Nurripter
marvias wrote:
I found this site via google. It has many of the files categorized and also offering downloads from other vendors.
https://rebyte.me/en/intel/
Hello,
I am wondering if anybody knows how trustworthy the file hosted on that site are. I ask because the removal of drivers and such, has left me in a position I never knew I had to worry about. I currently have an Intel D865GBF at home, and want to reinstall windows XP for it, but I'm wanting to install the proper drivers for my board. The only issue is that I can't seem to find any of the files in the archives on archive.org and such, Intel only has the bios files for it now, and I've only found files on rebyte.me. So I'm in a bit of a pickle. If anybody knows how trustworthy it is, it will help me judge if I take the risk of installing the files it has or not.
Thanks,
Nurripter
Reply 51 of 111, by Horun
I have already grabbed the manuals and BIOS for most of the boards, just a couple dozen left to go and they are the 67, 77, 79, 85 and 87 chipset boards. Already got all the ones starting from the 430/440 series thru 975, and 31 series thru 61.
Reply 52 of 111, by Horun
Nurripter wrote:
Hello, I am wondering if anybody knows how trustworthy the file hosted on that site are. I ask because the removal of drivers a […]
Hello,
Thanks, Nurripter
Yes the files on rebyte.me in the Intel section are good, have grabbed quite a few over the years. Only down side is: you have to complete a Captcha or TWO for every file you download, have not figured a way to get around that.
Reply 54 of 111, by Nurripter
Thanks for the information. Definitely gonna help me out. Too bad about that captcha stuff. But it is what it is.
Nurripter
Reply 55 of 111, by nd22
I do not know whre to put this so I leave it here:
https://www.fudzilla.com/news/49817-chipzilla … ivers-from-site
It seems Intel is doing away with the old drivers from mid 2000s and earlier . Should I try to make an archive or is there already one in the making?
Reply 56 of 111, by Stiletto
Moved post.
do the Fandango!" - Queen
Stiletto
Reply 57 of 111, by ssokolow
Since nobody has mentioned it, this Reddit thread may also be useful to keep an eye on for coordinating things:
https://www.reddit.com/r/DataHoarder/comments … of_drivers_and/
Internet Archive: My Uploads
My Blog: Retrocomputing Resources
My Rose-Coloured-Glasses Builds
I also try to announce retro-relevant stuff on on Mastodon.
Reply 59 of 111, by Horun
Thanks for the MD5 but most of the stuff I downloaded direct from Intel is not in either archive, maybe 10-20% is and why I decided to manually grab what I could. See my dir list for the Legacy Boards (https://www.intel.com/content/www/us/en/suppo … top-boards.html). That is the list I promised to get the manuals and Last BIOS files for, earlier in this topic and yes I have done it, 201 diff motherboards. Am still working on the ones listed as recent by Intel (67, 77, 85, etc chipset: https://www.intel.com/content/www/us/en/suppo … top-boards.html).
I hope you can get what ever you can before it is gone.
    dir_list.txt
    130.88 KiB
    179 downloads
