Reply 40 of 390, by DenizOezmen
BootROMError8046 wrote on 2021-06-19, 20:00:Actually someone else ran a ppro on this board!
Maybe with a different modified BIOS? By a quick check, the P3B-F BIOS uses tons of MSRs that are specific to Pentium II and above. I'm not sure if the calls are protected against being used on older CPUs. (Found an article that seems to talk about it here, too.)
BootROMError8046 wrote on 2021-06-19, 20:00:Also, the software doesn't support the 60kb microcode file as it's not 2kb, and checking the cpuids of each pii and piii will be really exhausting. Do you have a list of the microcodes to download? Thanks in advance!
Right, you'll need the single files. Here are the ones I used to build the modified BIOS.
[Edit: Removed attachment; downloads in first post contain source microcode files for each mod.]
