SATA2PATA adapters experience
Reply 20 of 29, by douglar
Here is what I've seen for Sata IDE Bridges
IDE Controller to SATA Drives
JM330 -- I don't have one of these
JM20330
27.46 KiB
IDE/SATA DOF
86.57 KiB
The performance between adapters using these chips was within the margin of error in my testing. (Tested using speedsys)
I've seen it implemented lots of different ways:
  • 40 pin female to Sata cables
  • 40 pin male to Sata connector
  • mSata to 44 Pin Male
  • M2 NGFF Sata to 40 Pin Male
SunPlusIT
SunPlusIT
103.08 KiB
I've only seen this in the plastic encased module that has 40 pin female, Berg power connector, Sata cable in, Sata Cable out
Performed 5-10% slower than the JM20330 or IDE/SATA DOF
For the DOMS, I've seen 2 controller chips:
SM223TF that supports up to UDMA4
161.24 KiB
EN2232T that supports up to UDMA6. Had some compatibility issues with some early EIDE controllers, but fine with original ATA or UDMA5 controllers
109.46 KiB
Reply 21 of 29, by gdjacobs
matze79 wrote on 2019-09-26, 16:12:
Use old Sandforce SSDs, they don`t need TRIM and wear leveling works well, also garbage collection is pretty good. They also com […]
Blzut3 wrote:
My personal experience with the cheap China adapters is that they work fine* for hard drives, but an SSD will be unbearably slow within a few days of usage. Perhaps mine is a dud, but honestly at this point in my life I'd rather just spend the $20 to have a known good controller with the Startech IDE2SAT2.
* I only tested for a few days before I just decided to pay for the Startech and never looked back.
They also compress every piece of data to save writes. And but less stress on cells
I use one in Apple Mac G5 and also on P3 with Windows 98.. runs very good, with some newer SSDs i had curious problems... eg ultra slow..
I've not really found a reason to switch to SSD when a modern SATA disk will vastly outperform period hardware and push the limits of a UDMA100 port.
Reply 22 of 29, by The Serpent Rider
Simple. Dramatically better access time and read/write speed on random small blocks. And HDD sequential read/write speed could be easily below ATA100 speed near the inner edge of platter.
Reply 23 of 29, by Joseph_Joestar
gdjacobs wrote on 2020-12-02, 15:22:
Not counting speed, silent operation is another big advantage that SSDs have. Even modern SATA HDDs can get pretty loud. And I don't mean while reading/writing data, just the noise that they produce by spinning.
I have both a Samsung SSD (for the OS and games) and a Western Digital Blue HDD (for file storage) in my WinXP rig. Power settings make the HDD spin down after 5 minutes of inactivity. The rig becomes much quieter after that happens.
PC#1: Pentium MMX 166 / Soyo SY-5BT / S3 VirgeDX / Voodoo1 / OPTi 82C930 / AWE64
PC#2: Celeron 466 / Abit ZM6 / Voodoo3 / AWE64 / YMF744 / SC-155
PC#3: AthlonXP 1700+ / Abit KT7A / GeForce4 / SBLive / ALS100
PC#4: Athlon64 3700+ / DFI LanParty / 9600GT / X-Fi Titanium
Reply 24 of 29, by gdjacobs
Joseph_Joestar wrote on 2020-12-02, 17:15:
That's a fair enough point, although I have a number of drives which are very quiet just as I have some which sound like jet turbines spooling up.
Reply 25 of 29, by RichardG867
I've once tried double-bridging a SATA DOM on my PC-Chips M748MR board flashed with an Award BIOS from another board. It didn't go well, even with the original (32 GB limited) AMI BIOS. The adapter is a red PCB bi-directional AliExpress special with the D0F bridge, and the DOM is a 4 GB Apacer (taken from a Wyse thin client) with the JMD330 bridge.
Reply 26 of 29, by douglar
RichardG867 wrote on 2020-12-03, 00:15:
So you have a DoF adapter that goes from a sata drive to an IDE controller? I have not seen one. Are you able to post a pic?
I've seen some DoF adapters that have 40 pin female, but I thought those were designed to sit on a motherboard. Didn't think they would let you go from a sata motherboard to an IDE drive. But then I never tested to see if it would work.
41.91 KiB
41.79 KiB
Reply 27 of 29, by RichardG867
douglar wrote on 2020-12-03, 01:52:
Looks exactly like this. I have successfully used it both ways, with an 80 GB Hitachi SATA drive on two IDE boards (SiS 620 and VIA 686B), and a 40 GB Maxtor IDE drive on a modern SATA system (AMD B450).
    132.07 KiB
Reply 29 of 29, by kolderman
RichardG867 wrote on 2020-12-03, 04:38:
This is the one I have always used, both red and black PCB. Works well, no IDE cable required!
