First post, by parhelia512
Hi all !
I have an old Guillemot TNT2-M64 with a strange problem.
The card can work 2D and 3D with no problem (tested under 3DMARK), but the output quality is really strange.
The card display odd horizontal ghosting (icons, windows...).
I know this is not a collectible card, but i would like to understand what's the problem and, why not, try to solve it.
Thanks for you help !
Reply 1 of 6, by aaronkatrini
Does it happen with any other card?
It could be a faulty connection between the Vga ramdac output on the board, the Vga connector on the board or the cable.
Reply 2 of 6, by parhelia512
Thanks for your answer !
Yes all others cards are ok with the same cable / display.
Do you know how i can check the ramdac ?
I will try to connect the card to the TV with the svideo port and see if something is different.
Reply 3 of 6, by Tronix
You can try to short circuit this inductance (L):
164.48 KiB
I indicated the purpose of the inductances approximately. First of all, you need short circuit HSync and Vsync inductance. And if i not mistake, short GND inductance. Maybe this will help.
https://github.com/Tronix286/
Reply 4 of 6, by parhelia512
Thanks for your reply !
I've shorted the three last inductances (HS VS and Ground) and no changes.
Could this behaviour come from the chip himself ?
In fact, even at boot, when the card display the BIOS version, i can see there is something wrong : lack of precision for the caracters.
Reply 6 of 6, by cookertron
parhelia512 wrote on 2019-10-06, 16:06:
I've been unable to find something to correct this problem...i think it will go to trash can 😒
Thanks for the replies !
Did you manage to resolve this issue? I'm interested because mine is doing the same thing! 😞
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
