Windows 10: Can't get fullscreen to work
General information and assistance with DOSBox.
Postby Forklift17 » 2019-10-06 @ 22:27
I've looked at several tutorials for how to get DOSBox fullscreen. I have tried multiple settings for fullresolution, windowsresolution, output, etc. in the config file. Nothing I have tried works. The best I can do is to get a large window that only has a tiny portion in the middle for DOSBox, and the rest of the window is black.
I know that most DOS games have a 4:3 aspect ratio, and this is fine, but this does not describe my problem.
How do I enlarge DOSBox to fill most or all of the screen, not just that tiny portion in the middle?
Forklift17
Re: Windows 10: Can't get fullscreen to work
Postby Forklift17 » 2019-10-08 @ 03:37
DosFreak wrote:ALT+Enter or fullscreen=true in dosbox.conf
That makes the window go big, but all the fonts are still tiny. The rest of the screen is just a thick black border.
Forklift17
Postby jmarsh » 2019-10-08 @ 03:52
change output to opengl in the .conf file. Also set aspect to true if you don't want the original 4:3 screen stretched on a widescreen monitor.
jmarsh
Postby Forklift17 » 2019-10-08 @ 04:17
jmarsh wrote:change output to opengl in the .conf file. Also set aspect to true if you don't want the original 4:3 screen stretched on a widescreen monitor.
I fixed it. I was commenting out stuff with #, but it seems you can't do that on the setting lines. I set the fullscreen resolution to 0x0, and now it's truly fullscreen.
Thanks for the help, everyone!
Forklift17
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 2 guests
