Dos4GW options?
General information and assistance with DOSBox.
Dos4GW options?
Postby ProDigit » 2019-10-20 @ 14:37
Hi all!
Wondering if DOS4GW.exe is still used in dosbox?
Too bad 64 bit operating systems have no backwards compatibility with 16bit programs.
Anyone has a list of possible options for DOS4GW?
Like, can certain memory addresses, extensions, configurations or performance be modified by adding something to the dos4gw command?
ProDigit
Re: Dos4GW options?
Postby DosFreak » 2019-10-20 @ 17:53
DOSBox runs DOS programs. DOS4GW is a DOS program. Therefore...
Your second paragraph makes no sense.
User avatar
DosFreak
Re: Dos4GW options?
Postby digger » 2019-10-21 @ 00:36
DosFreak wrote:Your second paragraph makes no sense.
That was actually not a crazy question. A DOS extender does all sorts of stuff that advanced users might want to tweak.
DOS32A for instance is a drop-in replacement for DOS/4GW and can optionally be configured with an environment variable, as documented here: https://dos32a.narechk.net/manual/html/user/4.htm
User avatar
digger
Re: Dos4GW options?
Postby leileilol » 2019-10-21 @ 00:38
DOS4GW is used only if the game/program provides it. DOSBox itself does not contain any DOS4G/DOS4GW. It is not permissively licensed so they legally can't anyway.
by the way, DOSBox is not for running Windows 9x
User avatar
leileilol
Re: Dos4GW options?
Postby gdjacobs » 2019-10-21 @ 02:26
I'm something of a piker when it comes to DOS programming. How much of the functionality of DOS extenders was standardized by the DPMI and VCPI specifications and how much was implemented on top independently for use by client software?
User avatar
gdjacobs
Re: Dos4GW options?
Postby jmarsh » 2019-10-21 @ 03:27
DOSBox used to implement either one or both of the interfaces (I forget which) but no longer does.
jmarsh
Re: Dos4GW options?
Postby kjliew » 2019-10-21 @ 06:19
jmarsh wrote:DOSBox used to implement either one or both of the interfaces (I forget which) but no longer does.
That was indeed the right path of decision.
viewtopic.php?f=32&t=4017
kjliew
Re: Dos4GW options?
Postby gdjacobs » 2019-10-21 @ 22:18
Ah, so the DOS extender interface which end user software was designed to leverage was essentially a de facto standard. i.e. Tenberry, Phar Lap, et al all provided a non standard API which workalikes such as DOS32A and PMODE/W had to implement?
User avatar
gdjacobs
Re: Dos4GW options?
Postby BloodyCactus » 2019-10-22 @ 02:23
well a defacto api most implemented was things like extending int 21h api
eg: open file ds:dx, translated into ds:edx reflecting the string into lower memory and doing the int 21h call.
file reads, writes etc.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
User avatar
BloodyCactus
Re: Dos4GW options?
Postby gdjacobs » 2019-10-22 @ 15:13
Did the extenders tend to do this the same or were they generally incompatible with each other at both the API and ABI level?
User avatar
gdjacobs
Re: Dos4GW options?
Postby cyclone3d » 2019-10-22 @ 15:22
As far as I am aware, most of the extenders were incompatible with each other. The exception being that DOS/32A being able to be used in place of DOS/4G and DOS/4GW.
https://en.wikipedia.org/wiki/DOS/4G
User avatar
cyclone3d
Re: Dos4GW options?
Postby BloodyCactus » 2019-10-22 @ 15:43
well extenders were often tied to a compiler.
eg: pharlap is not the same as dos4gw.
dos4gw compatability was big (pmode/w, wdosx, dos32a etc) because it was the premiere 32bit c compiler at the time (watcom). DJGPP/GCC had a trans pmode port outside its own go32.
they were all incompatible. eg: DJGPP used XCOFF as file format. watcom produced many (but not xcoff), Pharlap is the spec designer of VCPI.
The only things you can be certain of is DPMI and VCPI as they were 'officially' spec'd out.
User avatar
BloodyCactus
Re: Dos4GW options?
Postby kjliew » 2019-10-22 @ 23:01
DJGPP is a purist DPMI 1.0 implementation. It does not have protected-mode extension for DOS INT21h or any BIOS INTxx services. If one needs any of those, then one will have to implement real-mode INTxx calls the *DPMI* way, which kind of sucks... It is really meant for porting Linux codes to DOS, but for porting 16-bit DOS codes into 32-bit DJGPP, then one would wish the standard C library is good enough.
kjliew
Re: Dos4GW options?
Postby BloodyCactus » 2019-10-23 @ 00:11
kjliew wrote:DJGPP is a purist DPMI 1.0 implementation. It does not have protected-mode extension for DOS INT21h or any BIOS INTxx services. If one needs any of those, then one will have to implement real-mode INTxx calls the *DPMI* way, which kind of sucks... It is really meant for porting Linux codes to DOS, but for porting 16-bit DOS codes into 32-bit DJGPP, then one would wish the standard C library is good enough.
djgpp is the name of the dos port of gcc. it runs on top of go32 or pmode/dj which implement dpmi functions for vcpi hosts if dpmi doesnt exist. you often find cwsdpmi shipped with djgpp.
User avatar
BloodyCactus
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 2 guests
