Clone of Amstrad's Adlib clone
Reply 21 of 34, by root42
Nice! That looks great and like a lot of fun to solder!
YouTube and Bonus
Reply 22 of 34, by Benedikt
The first board is ready for testing!
241.09 KiB
There was just one minor problem: I ordered flip-flops that don't match the footprint on the board and had to solder that thing on in SOJ-style.
Reply 23 of 34, by root42
Looks beautiful! Is the 558 still in production or is it EOL?
YouTube and Bonus
Reply 24 of 34, by Benedikt
The Ne558 is NOS. It should be possible to use two NE556, instead, but since this board needs vintage parts, anyway, I didn't care about that.
This should be roughly equivalent to an NE558:
15.58 KiB
Reply 25 of 34, by matze79
Looks good 😀
Reply 26 of 34, by Benedikt
Well... the card works!
... but I didn't see this problem coming:
57.99 KiB
I can only assume that the original card would have caused the same problem in this machine, but it's still a bit disappointing.
Reply 27 of 34, by matze79
Hi Benedikt,
RK097G Pot will fit on your Board, there is also Mono Version.
it has optimal height to fit.
And for the Audiojack, i also tend to use the flat ones but they will not fit all cases, so the ones used on SB128 are perfect.
Reply 29 of 34, by Benedikt
Card number two. This looks much better, indeed:
191.06 KiB
177.98 KiB
134.37 KiB
I'll leave the testing for tomorrow.
Reply 30 of 34, by root42
Nice bracket! Did you make it yourself? Or is that a standard one?
YouTube and Bonus
Reply 31 of 34, by Benedikt
That's a Keystone 9200-3 DA15 bracket with additional 8mm and 7mm holes.
I had to shift the DA15 socket by a few mm to make the bracket fit, but it certainly makes things a lot easier.
Reply 32 of 34, by Benedikt
And it fits and works!
81.71 KiB
39.28 KiB
The card sounds a bit noisy with headphones when set to an appropriately low volume, but the background noise does not seem to get louder when you turn the volume up.
Reply 34 of 34, by Benedikt
perhenden wrote on 2021-12-18, 20:53:
Benedikt wrote on 2020-02-02, 12:57:
Very nice! Is there a parts list available?
KiCad can generate a parts list for you, albeit without specific part numbers, because I did not specify any.
Also note that the PCB layout still contains some minor errors/insufficiencies that I never corrected, because I do not plan to build another batch.
