imgmount
General information and assistance with DOSBox.
imgmount
Postby JessicaJones » 2019-11-30 @ 19:32
Hi
When I do the following:
Code: Select all
imgmount D "C:\RedneckRampageFamilyReunion01.cue" -t iso -fs iso
I get error: Image file not found.
The cue and bin exist in my mounted C drive!
What am I doing wrong?
JessicaJones
Re: imgmount
Postby jmarsh » 2019-11-30 @ 21:46
A mounted drive only has short filenames.
jmarsh
Re: imgmount
Postby dr_st » 2019-11-30 @ 21:57
I thought you needed to provide host pathnames, not mounted guest pathnames to IMGMOUNT. But maybe it works with both now?
User avatar
dr_st
Re: imgmount
Postby jmarsh » 2019-11-30 @ 22:36
It works with either.
jmarsh
Re: imgmount
Postby JessicaJones » 2019-11-30 @ 22:59
jmarsh wrote:A mounted drive only has short filenames.
Is it the same as ms-dos, so 8 characters maximum?
JessicaJones
Re: imgmount
Postby jmarsh » 2019-11-30 @ 23:17
Yes, the same filename shown when you use the DIR command inside DOSBox.
(Or just type the first few letters of the filename and press tab to autocomplete it.)
jmarsh
Re: imgmount
Postby Dominus » 2019-12-01 @ 00:26
Look inside the cue file (open it with a text editor) it might have a path to the bin in it. And yes, if the cue is in the folder you mounted as c:/ you need to shorten its name, and probably the name of the bin in real and in the cue file to 8 characters.
User avatar
Dominus
DOSBox Moderator
Re: imgmount
Postby gdjacobs » 2019-12-02 @ 01:24
Any issues with case sensitivity?
User avatar
gdjacobs
Re: imgmount
Postby IIGS_User » 2019-12-02 @ 15:32
JessicaJones wrote:
Code: Select all
Disk images does not need to be in mounted drives.
This command implies the .cue & .bin files are located in your host C: directory.
Please try again, with replacing the "C:/...01.cue" part with the real path seen on your computer,
w/o mounting its folder within DOSBox.
Klimawandel.
User avatar
IIGS_User
Re: imgmount
Postby junglemontana » 2019-12-05 @ 09:42
Are there any special reasons to imgmount from a mounted drive instead of host directory?
junglemontana
Re: imgmount
Postby jmarsh » 2019-12-05 @ 11:38
junglemontana wrote:Are there any special reasons to imgmount from a mounted drive instead of host directory?
Generally I find it's easier to keep the .iso+.cue in the same dir as the rest of the game's files and use a batch file to mount+run (and do anything else like set core/cycles) in one step.
Especially if it's on a network drive that might be mounted in different locations depending on which machine I'm using.
jmarsh
Return to DOSBox General
Who is online
Users browsing this forum: BLEXBot [Bot], knowledge [bot] and 3 guests
