Reply 160 of 887, by bjwil1991
That's good to know. If only 486 laptops had the ET4000 series video. I have a 4000AX ISA and 4000/w32p VLB and those are wonderful cards for DOS.
So wait, the T4800CT has an ES688 or the Panasonic quad-speed PCMCIA CD-ROM with integrated sound?
Reply 161 of 887, by ragefury32
bjwil1991 wrote on 2020-07-20, 02:08:
T4800CT - this implies no CDROM built-in, and only the Windows Sound System (if I remember correctly is defined as 2 chips - one for WAV (ESS688) and one for FM synthesis, and that FM synthesis is an OPL3 (YMF262) or an OPL3 clone. It can also be a one-chip solution like an ESS1688 with ESFM integrated)
If you plan to buy a Toshiba T-series for classic gaming and you need a CDROM drive, consider a T2150/2155CDT instead (practically the same but with a CDROM drive integrated, and a C&T 65545, which performs better than the WD). And that Tseng ET4000 will likely be rather power hungry.
Reply 162 of 887, by bjwil1991
I already have a PCMCIA external CD-ROM drive that I can use and hope it works since it never worked on my Satellite Pro 410CDT laptop since the CD drive for it broke.
But thanks for the information. Appreciate it, plus, it's hard to find a T2150CDT these days on eBay, but I'll keep searching.
Reply 163 of 887, by vorob
My N600c is here! Worked for two hours and then died. Was blinking like crazy, looked like I was plugging and unplugging the charger. That was expected, the seller told me that the laptop had some charging port issues. Had to disassembly it completely to get my hands on charging port. And some weird guys say that modern laptops are hard to disassembly, 🤣!So the soldering between port and motherboard was dead, I renewed it. But the laptop still didn't boot up. As a last resort, i've reinserted ram, and surprisingly it started working again! Already tried few windows games (quake 3, thief ii, unreal) that wasn't working well on M1 from N400c, and here they work perfectly. Now I'm going to install win 98.
180.75 KiB
162.96 KiB
38.09 KiB
137.35 KiB
Reply 164 of 887, by vorob
If anyone has this laptop and have a guide on how to enable native dos sound I would be appreciated to have it. Just to save some time. If such a thing doesn't exist I'll google myself 😀
Reply 165 of 887, by HandOfFate
I'm dealing with exactly the same problem atm (Compaq N600c: hangs on playing audio in DOS, music works)
I'll update the topic because I had it working for one boot yesterday. And then suddenly the I/O, IRQ and DMA combination didn't work anymore. Sigh.
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX, PicoGUS /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 167 of 887, by HandOfFate
I found one on this driver CD at Archive.org: https://archive.org/details/mmcd9v22
Should you get it working btw then I would very much like to get your ESSAUDIO.INI (which is created by the non-WDM drivers) and perhaps everything that Compaq Diagnostics (https://driverscollection.com/_44749461801219 … dows-98-XP-free) spits out 😀
Reply 169 of 887, by HandOfFate
Yes, I had the same.
For the unknown device you can manually pick the ESS ES1989 PCI audio device from the list. Then it automatically installs a DOS emulation device, a gameport and then you should have sound.
Reply 171 of 887, by vorob
HandOfFate wrote on 2020-07-24, 15:12:
It’s not working well. Trash midi sound and some games won’t have sound even with proper settings.
Reply 172 of 887, by vorob
74.12 KiB
73.48 KiB
49.06 KiB
I don’t understand what I’m doing wrong here. IRQ more than 7 is impossible to set here, I’m getting error.
Reply 173 of 887, by HandOfFate
You've got completely different IRQ/DMA settings than what my drivers gave me. Interesting.
I did make some progress and I now got sound to work reliably in Rise of the Triad, stuttering sound in Quake (edit 2: fixed 99% of stuttering) and no sound in Doom (edit: got sound working in Doom). I will update my topic about the sound issues later. I'm going to try some more things to hopefully improve the sound in Quake, at least.
But I am starting to doubt, after 6+ hours of trying to get it to work, that this notebook (or even this chipset?) is really suitable for DOS gaming 😜
Reply 174 of 887, by ragefury32
HandOfFate wrote on 2020-07-25, 09:59:
Hmmm...the audio or the setup? Well, there are several issues here:
a) Tulatin is really too fast for the old DOS stuff, but not really great for the later WinXP stuff, so it's in that weird transition period between Win98 and XP. setmul can only give you limited magic here.
b) ESS Maestro 2/Allegro (really a Maestro 3) does not do all that great for FM (emulated).
c) Tulatin P3 is a weird little in-betweener - If you buy Tulatin mobile (2001), you might as well buy Banias Pentium-M (2003), which is a much better Tulatin derived core but better clock control, faster FSB and USB2 support. Of course, I am not sure if there are ANY pre-AC97 Pentium-Ms out there.
d) Same goes for the Radeon M6 - its better than the Rage 128 Mobility or the S3 Savage Mobiles, but it's not great against the Geforce2Gos (came out around the same time) and beyond.
So yes, the n600c is the "ultimate" DOS laptop out there (in terms of fastest CPU and most performant mobile GPU), but I would not say the best.
Reply 175 of 887, by kalohimal
You can try out my hardware speed control program CPUSPD if you're interested in playing old DOS games which the N600C CPU is too fast to run. It's not tested on this system but since the PIII mobile has enhanced speedstep and the south bridge is ICH3-M, I think it should work fine under DOS/Win9x/Win Me.
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 176 of 887, by adalbert
ragefury32 wrote on 2020-07-28, 04:07:
I also have Dell Inspiron 8100 and it has mostly the same specs including ESS Maestro, but the GPU is Radeon 9000 which is superior to everything else mentioned here (it's pretty rare version, usually came with GF2, GF4). But it's big and heavy... it also has PCI dock so you can install Solo1 and even maybe Voodoo.
Dell Precision M60 or Inspiron 8600 is also nice as a bridge between old and modern systems. It has lots of legacy connectors (irda, pcmcia, lpt, com, TV, usb, firewire, LAN), possibility to install floppy in a bay. Docking station you can usually get for free on scrap or for 1EUR at most which has DVI, all mentioned ports and PS/2 ports. There is also PCI dock. It has Pentium M up to 2.2 GHz so you can run modern OS, Radeon 9600 Pro (in best version), unfortunately no DOS audio (it's Sigmatel c-major, maybe there is some legacy emulation but I don't know). LCD screen up to 1900x1200. With PCI dock in theory you could install ESS Solo 1 and floppy drive in additional bay...
Reply 177 of 887, by HandOfFate
Does the sound work in DOS with the Inspiron 8100?
Reply 178 of 887, by adalbert
Honestly I didn't even try it because i use it only with Windows 98 and XP. I expect that there may be the same problems as with N600c, but i will try later and report.
Reply 179 of 887, by HandOfFate
That would be great, thanks 😀
