Reply 401 of 887, by Warlord
- l33t
never experienced screen jerking like that on mine.
Reply 402 of 887, by vorob
- Oldbie
Did you play build games? Cause in other dos games I don't catch such stuff.
Reply 403 of 887, by Warlord
- l33t
ya ive tested them mine doesnt do that, try hooking yours up to an external monitor and see if its still does that. could be your lcd
Reply 404 of 887, by Warlord
- l33t
might be the inverter board for the lcd
Reply 405 of 887, by bjwil1991
- l33t
And possibly dirty contacts for the video signal.
Reply 406 of 887, by Spitz
- Member
vorob wrote on 2021-01-27, 22:18:I have it! I have it! My Toshiba 2805 with Geforce 2go finally arrived! As described, screen is burned, but I've got another Tos […]
I have it! I have it! My Toshiba 2805 with Geforce 2go finally arrived! As described, screen is burned, but I've got another Toshiba with Savage videocard, so I've switched the screens and now I've got perfect machine. Even hinges are perfectly fine. Already tested stuff and everything is working fine.
Only one thing bothers me: build games (duke 3d, blood) got some screen jerking from time to time: https://youtu.be/z-l3V0MXOzk
Tried even under dos mode, same stuff.
Try to load some VESA driver under DOS. These can be found in some DOS games or here somewere on Vogons - uni VBE. After loading it under dos run Blood setup and choose 640x480 or 800x600. Let us know it that help.
Well... I miss 80/90s ... End of story
Reply 407 of 887, by vorob
- Oldbie
I need some additional testing, but looks like 320x200 doesn't produce such glitches, I only see it in high resolution. Both in native dos and win 98.
Warlord, did you test it in 320x200 or higher?
Reply 408 of 887, by Warlord
- l33t
like I said before my laptop doesn't have that issue. I don't have any strange artifacts, or screen res issues. Might has something to so with the LCD you replaced your broken LCD with.
try some of these fixes on this page and see if it helps you. https://gona.mactar.hu/DOS_TESTS/
can you also try slowing down your cpu.
Reply 409 of 887, by Spitz
Reply 410 of 887, by vorob
- Oldbie
Actually, it's not the same, it's similar. Mine is 603 and Warlord has 402. I've got some strange slot called SmartMedia under DVD-ROM. Also, the modem slot is different and usess another type of connection (I've got 401 model and can compare). Maybe they are using another revision of geforce 2, I dunno. But so far these two build games are the only ones that gave me a headache
Reply 411 of 887, by Warlord
- l33t
maybe a good compromise is to add a audigy2 zs into the mix for sound in some windows games. I have the cardbus version but I have never tried using it. I wonder if like the PCI card you can force Audigy 1 vxd drivers to install on it. I read that duke3d works on audigy2zs
Reply 412 of 887, by Spitz
- Member
vorob wrote on 2021-01-28, 20:26:Actually, it's not the same, it's similar. Mine is 603 and Warlord has 402. I've got some strange slot called SmartMedia under DVD-ROM. Also, the modem slot is different and usess another type of connection (I've got 401 model and can compare). Maybe they are using another revision of geforce 2, I dunno. But so far these two build games are the only ones that gave me a headache
There You go:
https://dosdriver.de/download/univbe.zip
And:
https://dosdriver.de/download/vesadrv.zip
Let us know if it done some good....
Reply 413 of 887, by Warlord
- l33t
thanks hopfully that helps somone, but our laptops use nvidia which are VBe 3.0 already and don't use are need univbe. or vesa drivers, nor will any of those programs or tsrs work with them.
however a program like
Rob Muller drivers may help in some cases
vbeplus https://gona.mactar.hu/DOS_TESTS/vbeplus.zip
vesa12 https://gona.mactar.hu/DOS_TESTS/vesa12.zip
Modified univbe.drv https://gona.mactar.hu/DOS_TESTS/modified.zip
Reply 414 of 887, by Spitz
- Member
Warlord wrote on 2021-01-29, 01:21:thanks hopfully that helps somone, but our laptops use nvidia which are VBe 3.0 already and don't use are need univbe. or vesa […]
vbeplus https://gona.mactar.hu/DOS_TESTS/vbeplus.zipvesa12 https://gona.mactar.hu/DOS_TESTS/vesa12.zip
Univbe works on my nvidia geforce 4 go 4200 😀
Reply 415 of 887, by Warlord
- l33t
anyways between all the files spitz posted and I posted try some things and see if it doesn't help.
Reply 416 of 887, by Warlord
- l33t
vorob wrote on 2021-01-14, 08:40:Well, this Toshiba 5205 is surprisingly unfriendly dos the laptop. It doesn't have BIOS and will alter its brightness only via Windows app, if you go into dos brightness will be always on minimum. Also, like I mentioned above, I've got some strange artifacts in dos games. Later dell with GeForce 4200 doesn't have them. It's strange.
you can change the brightness in the bios. Theres also a utility called Toshiba Hardware Setup that allows you to enter the bios from the command prompt and you can change the brightness there. I don't have the laptop in front of me but I am 100% sure of that. In the bios you must select "User Define" under power options.
Reply 417 of 887, by vorob
- Oldbie
This thing was fixed with NOLFB patch (http://dnr.duke4.net/patches.php.html). I've tried under Win 98 and it worked, then I've tried under clean DOS, launched without patch and screen flashes, then activated patch and all is fine.
NOLFB disables the linear framebuffer in VESA 2.0+ BIOS
I didn't see any chance in picture quality, wonder what I've lost?)
Reply 418 of 887, by Spitz
- Member
Great! You can now enjoy retrobrew without issuses 😁
Reply 419 of 887, by Warlord
- l33t
glad u found a way, can you test if vesa12 has the same effect. It should do the same thing as noflb.
