Reply 380 of 1061, by red_avatar
appiah4 wrote on 2020-12-03, 12:35:
Isn't Audician a YMF71x card at the end of the day? I use YMF 71x cards in a lot of PCs and can easily tell you that I am 100% sure half of the stuff on that list is wrong, you are either using a wrong DOS driver or your card is fucked.
Some of the problems may be tied to the version of the games I'm trying (they're original copies mostly) and some sound problems I DID fix by using later or older versions - UFO Enemy Unknown worked fine once I installed the CD version. For the rest, I found others who had very similar issues so it's not the card - most likely the lack of compatibility that may have been fixed in certain game updates.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 382 of 1061, by red_avatar
Velociraptor wrote on 2020-12-03, 18:46:
DOS gaming is a bit of a minefield with stuff like that. It's just the nature of it. It makes us appreciate what DIrectX has done for us.
Hah, I recall when I bought my Pentium 166 and it came with an Aztec card - first non Creative card I had. Stupid thing crashed on Direct X 5 games such as Magic the Gathering - drove me nuts until I spent all my allowance of a year on a Creative Labs set with a CD drive, speakers and ... a SB AWE64. Boy was I happy to have that card. So let's say, even with DirectX, we still had some problems 😉
Retro game fanatic.
Reply 383 of 1061, by kolderman
What abolished all sort of synth and midi playback eliminating the possibility of variety to how music and sound is played back? Bah I'll take DOS gaming over that any day.
Reply 385 of 1061, by SquallStrife
Pierre32 wrote on 2020-12-03, 11:45:
As for being on Blerbs, that could be a time availability thing, as there is far less production & editing required for the vlog style vids. They still get tons of views.
This x1000
Reply 386 of 1061, by carlostex
keropi wrote on 2020-12-03, 12:25:
I have some of these in my 200mx system: […]
Duke Nukem 3D: no slowdowns with 44100hz selected
Cannon Fodder 1 : could never run this well on this system - setup detects and beeps with SBPRO, after L1 cache disabling the intro works but the main game always crashed for me with any soundcard in this system edit: confirmed working on 386DX , game is speed sensitive and does not like more than 16mb of ram
Pinball Illusions: no problem
Pizza Tycoon: no problem
UFO Enemy Unknown: no problem
Innocent Until Caught: game loads CT-VOICE.DRV , it works fine - double checked with dosbox and it is the same because I could not trigger a SFX to play , where are they used?
Heart of China: it's OK after L1 cache disabling
Dune: I have no idea how to trigger speech - have the floppy version
hope this helps!
I would do the testing myself but Keropi did the debunking himself.
I've had the privilege to be a beta tester for the Orpheus, for a few months, and i have to say: it's the best all rounder DOS card ever made. This is my opinion of course.
But, after years of using the 3 main contenders for SB Pro: ESS Audiodrive, Yamaha YMF-71x and Crystal CS423x i have to say my favorite is still the Yamaha YMF-71x. It's lack of ADPCM modes is the greatest disadvantage, but come on people, there's workarounds for this, patches made available by the community.
It's the only chipset of the 3 to be capable of mixing SB Pro Stereo at 44khz: Try a good MOD player like Inertia, select SB Pro Stereo and force mixing at 44khz. Try it on the YMF chipsets and enjoy the clarity. Then do the same on the other chipsets and watch (listen) them fail.
The software is kind of lame, but Tiido has made really nice software for these cards. Which reminds me...
Reply 388 of 1061, by darry
Why use SB Pro mode in a mod player when Inertia Player and others support WSS mode for 16-bit 44.1KHz or 48KHz stereo output ?
I mean, it's great if the YMF-71x can do 44.1KHz stereo in SB Pro mode, but I just don't see a use case since the chip supports WSS mode anyway .
EDIT : Orpheus works great in WSS mode in Open Cubic Player and so does my YMF715 based Audiotrix 3D/XG . IMHO, Orpheus has cleaner sound, subjectively (I have taken a break from quantified measurements and comparisons).
Reply 389 of 1061, by keropi
Keep those reports and questions coming people they help answer questions others might have! I would rather prefer someone reading for example "adpcm sounds in nukem2 are not supported" and not spend their money rather than getting disappointed afterwards 😀
Reply 390 of 1061, by underthebridge
I was thinking... the CS4232 has an external OPL3, and the Windows drivers readily utilize this OPL3 chip for FM. Why not compare how the CS4232 drivers work with the CS4237 ? ... Perhaps it would shed some light on how to force OPL3 sound.
Reply 391 of 1061, by 640K!enough
carlostex wrote on 2020-12-04, 01:40:
Officially, the actual Sound Blaster Pro doesn't offer stereo PCM playback at 44.1 kHz either. So really, if it's supposed to be emulating a Sound Blaster Pro, it shouldn't work.
Reply 392 of 1061, by Tiido
YMF71x goes to 1MHz on SBpro if the DMA can keep up 🤣. Real Sound blasters have the sample rate wrap back once 45KHz is reached, the next step won't produce a higher but a lower rate instead while Yamaha goes up to the maximum possible. I can do 500KHz on Intel 420EX board but sound is jittery then, most other things I have tried crap out at beyond 111KHz speeds.
42.7 KiB
SB rates that are possible
Reply 393 of 1061, by carlostex
640K!enough wrote on 2020-12-05, 16:45:
I know, SB Pro 2 is Stereo at 22Khz, but just because Yamaha supports higher rates doesn't make it a bad SB Pro clone. In fact it should be a bonus. What we should say is that if other clones do not support higher rates they aren't flawed.
@Tiido
That is very impressive!
Reply 394 of 1061, by McDaddyMark
Does anyone have an exact link of where to order this? The instructions state "there is an Orpheus item in the drop-down product list" I don't see any such list on either serdashop.com or pcmidi.eu. What am I missing?
Reply 395 of 1061, by Pierre32
McDaddyMark wrote on 2020-12-07, 20:36:
It's via the contact form, which is linked in the How to Order section from either of these sites:
http://pcmidi.eu/
http://orpheus-soundcard.eu/
Reply 396 of 1061, by keropi
yeah sorry if this is not a real webshop but for the moment you fill that form and your data gets entered in a "order/waiting list" and you get contacted when your turn comes... there is no way to do a full-automatic assembly for these so we can offer for example 100pcs at once - at least not at a sane cost - so 60% is still hand-soldered ...
Reply 397 of 1061, by red_avatar
hope this helps!
I'm late to reply but thanks - that does sound good. My system has 16MB of RAM for max compatibility so hopefully Cannon Fodder will work as well.
And IUC is a bitch to run with anything except a Sound Blaster and even then you need to have lots of memory - there's sound all over the intro so it's easy to test. It's too bad because this is one game I have yet to finish.
Retro game fanatic.
Reply 398 of 1061, by keropi
Well I could not trigger any SFX with dosbox too, I will try later with my original CD - maybe it will make a difference as I cannot vouch of the origin of the game currently in my HDD 🤣
Reply 399 of 1061, by McDaddyMark
keropi wrote on 2020-12-07, 22:48:
OK. Thank you for the response. I completely understand you're situation. I have submitted my information in the form as you explained and will wait patiently to be contacted.
Thanks.
