First post, by Graham21
This is an add on from my previous thread (Re: Date - Setting the date for DOSBox only.
I'm using DOSBox r4296.7z as suggested.
I works GREAT but is locked to Cycles = 3000.
How do I adjust that - there doesn't seem to be the Options.bat file mentioned in FAQs?
Is there a way to set that as I launch or should I just figure out where the Options.bat file is, or should be, and fix there?
Thanks,
Patrick
