New forum suggestions/Feedback
Reply 160 of 516, by gerwin
GigAHerZ wrote on 2020-01-05, 07:34:
Saturation has nothing to do with contrast...
? Take some screen colors next to eachother, like green, red, blue. They contrast to eachother. Then decrease the overall saturation to zero, like with photoshop. They become the same grey, without any contrast.
Reply 161 of 516, by GigAHerZ
gerwin wrote on 2020-01-05, 14:56:
Well, seems you define the word "contrast" your own way, not like everybody else...
And how does it even apply to this forum, where everything is the same kind blue-violet-ish?
Reply 162 of 516, by VileR
precaud wrote on 2019-12-29, 13:40:
Purple is at the end of the spectrum, where our eye's sensitivty is the worst, and the color wavelength is the shortest. UV sits right above it. Do you wear sunglasses? It's the part of the spectrum we filter out to reduce eye strain and augment clarity, even under "natural light" conditions. Flooding the background with it is a mistake.
https://iristech.co/what-screen-color-is-best-for-eyes/
There's something about this that should be clarified: short-wavelength violet *can't* be reproduced by computer monitors. In reality it's a very deep blue, which the brain perceives as violet (=with a reddish tinge) because the red photoreceptors in our eyes have a secondary small peak in the far blue end of the response curve.
Computer/phone displays reproduce colors by combining red+green+blue, but the blue component is a 'pure' blue - a little longer in wavelength than real (spectral) violet. So all three RGB primaries sit at longer wavelengths than violet, and you can't create a shorter wavelength by mixing them. You have to mix 'pure' blues and reds - so the purple you're seeing is a mix of two *longer* wavelengths than real short-wave eye-straining violet.
Reply 163 of 516, by gerwin
GigAHerZ wrote on 2020-01-05, 15:06:
Truth is: Prolonged use of Photoshop defined it for me. When Photoshop has it wrong I love to hear how.
Reply 164 of 516, by GigAHerZ
gerwin wrote on 2020-01-05, 15:20:
Well, contrast is pretty much the L component in HSL color system. Difference in Hue (H) is not contrast.
It seems you want to try to define "contrast" by the ability to make difference between two colors. This way, same saturation and light, but difference in hue would be like contrast. But that's wrong understanding of the definition of contrast. Being able to make difference between two colors is not always due to contrast itself. (but because of difference in hue for example)
Reply 165 of 516, by precaud
VileR wrote on 2020-01-05, 15:09:
True, but the point stands that the shorter-wavelength part of the spectrum is the one most responsible for causing fatigue. My UV-filtering sunglasses also take out a big chunk of the blue.
Reply 167 of 516, by j^aws
Don't you all have some kind of system settings with your OS/ hardware to overide visual aspects? I've never come across anything that's perfect. For example, on my phone I have the usual brightness and contrast controls, as well as colour temperature. In addition, there is a blue light filter as below:
244.06 KiB
No forum I've visited has been perfect and I don't expect them to be, but as long as minimum functionality is present then I'm good to go.
Reply 168 of 516, by gerwin
GigAHerZ wrote on 2020-01-05, 15:27:
Yeah that is the core of our difference in understanding. I just briefly looked at these pages:
https://en.wikipedia.org/wiki/Display_contrast
https://en.wikipedia.org/wiki/Contrast_%28vision%29
And it seems that the term contrast is not properly defined; it has a multitude of possible variants. Maybe leave it at that.
Reply 169 of 516, by bmwsvsu
Here's a little more elaborate CSS-skinning I did using Chrome's STYLUS plugin - this time aiming for a dark-on-light theme. I still have some elements that require modding but here it is so far:
DIRECT LINK to see image non-scaled
Reply 171 of 516, by Stiletto
kolderman wrote on 2020-01-05, 20:32:
Did something change? The title bar of each post now has a kind of spotted look to it...I think I preferred the previous look.
Yes, several days ago Snover removed the full-post dithering on altering posts and moved it to the "post title bar". I believe Snover is experimenting in trying to find an acceptable location where keep the dithering, so he moved it there. It's possible there may be no good place for it, humorous reference though it was.
do the Fandango!" - Queen
Stiletto
Reply 173 of 516, by maxtherabbit
kolderman wrote on 2020-01-06, 00:06:
Well, if this forums had polls, and the question was about this so called "dithering", I would vote to get rid of it completely.
same, dithering just sucks I have zero nostalgia for it
Reply 174 of 516, by Stiletto
BTW, I recently discovered that in post formatting, with the new software choosing font color with message formatting and BBCode (the "COLOR=#FFFFFF" etc. tag) has been removed due to the possibility of users choosing color combinations that are unreadable and not adhering to common Internet visibility/disability guidelines. Bold and Italics and others still exist, but Font Color choice is gone. This was by design.
If any post used it for highlighting in the post database, the color choice is being ignored and converted to the default text color for the chosen theme.
Well, alright, it means Robert's lengthy PC Builds posts (Hello, World! :D - Robert B's PC builds - oogle away freely :) ) will lack that extra bit of panache. No, this is not another thing to throw a fit over.
Another retro forum thing sacrificed to modern UI/UX (and possibly one that makes some sort of sense).
Stiletto
Reply 175 of 516, by GigAHerZ
Because of all the complaining (incl. me) i also wanted to share some thanks about some features:
* New posts have a "NEW" icon near datetime
* Post, where browser scrolls automatically, has also blue emphasis color on that particular post's header
Some time ago i complained about those things and now, as these things are done, the thanks and respect is due. Thank you! 😀
...but what is a post in this thread without complaining?
A thing i noticed is that in the "Active posts" or "Your posts" or any other such list, the link to latest post (the most right column) has a hidden link icon, that only becomes visible when the datetime is hovered. Try to approach this from the right side - you have to go all the way to datetime and them come back right to the icon.
It would be nice to have that icon there all the time or to have the hover react already on that empty spot, where the icon would appear.
Reply 176 of 516, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
the link icon is only there to symbolize that you can click on the date which you can do right away without having the icon appear. It might help to visualize that you can click on the date if the icon were always there.
And/or if the columns switched places, so the replies and views are after the "latest post"? (I'm just asking, I'm not the one who decides or does things 😀)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 177 of 516, by GigAHerZ
@Dominus, wait, did the datetime become looking like link just recently? For some reason, i didn't catch that you can click on the datetime as well, but right now, it does change color and cursor becomes a hand-icon. Did it recently change to that or i just missed that obvious thing? 😜 Well, as it is right now, i see no problem. Previously (for somewhat unknown reasons now) i thought one can only click on that icon...
Reply 178 of 516, by Dominus
DOSBox Moderator
It's been like that (clickable, no idea on the hover behavior) at least since the forum update. Could have been working like that in the old forum, too, but I don't know.
Reply 179 of 516, by GigAHerZ
The arriving thirties are already showing it's signs on me... ugh...
