The "Driver CD" for motherboards thread
Reply 20 of 104, by PC Hoarder Patrol
I have the Gigabyte VIA support CD from around that time (2002 / VUCD v2.1) if you want a copy, although there are newer versions on archive.org
Readme.txt
3.14 KiB
82 downloads
https://www.mediafire.com/file/mydphcvm1os6ld … UCD_21.ISO/file (14 day link)
505.86 KiB
Reply 21 of 104, by SETBLASTER
PC Hoarder Patrol wrote on 2020-03-23, 06:20:
Readme.txt
hi, can you share the iso?
i didnt get the archive one because it mentioned it was for 7VM400M-RZ VIA KM400 Chipset
thanks
Reply 23 of 104, by Joseph_Joestar
I still have the original driver CD for my Abit KT7A-RAID Rev 1.0 in case you need that.
I think the only difference between that and the non-RAID version is in the Highpoint controller driver.
Reply 25 of 104, by SETBLASTER
Joseph_Joestar wrote on 2020-03-24, 11:15:
hi joseph
sure i can use that, can you share an image iso uploaded to mediafire or zippyshare or anynother?
thanks!
Reply 26 of 104, by Joseph_Joestar
SETBLASTER wrote on 2020-03-24, 18:56:
Here you go then, uploaded to zippyshare: https://www31.zippyshare.com/v/muyqTzWR/file.html
As mentioned earlier, my KT7A-RAID is Revision 1.0 so I'm not sure if these drivers are suitable for later board revisions. Also, the CD has a PDF version of the manual, if that is useful to you.
Lastly, here's a photo of my CD, manual and the old, worn-down box.
P.S.
I also have the latest available BIOS for this board, in case you need that.
    320.16 KiB
Reply 27 of 104, by SETBLASTER
Joseph_Joestar wrote on 2020-03-25, 06:50:
Here you go then, uploaded to zippyshare: https://www31.zippyshare.com/v/muyqTzWR/file.html As mentioned earlier, my KT7A-RAID i […]
P.S.
thanks joseph!
i tried to use the link but it gives an error 404
does it work for you? maybe the link is wrong?
the latest bios would be nice to have, is it easy to find on google?
Reply 28 of 104, by wirerogue
SETBLASTER wrote on 2020-03-26, 01:08:
thanks joseph! i tried to use the link but it gives an error 404 does it work for you? maybe the link is wrong? […]
P.S.
thanks joseph!
the entire abit ftp site is on archive.org
https://archive.org/details/archiveteam-ftp_abit_com_tw
Reply 30 of 104, by Joseph_Joestar
thanks joseph!
Strange, I checked the link after uploading and it worked for me then, but now it appears to be dead. Re-uploaded to mediafire:
https://www.mediafire.com/file/17gneoqkpfs2ph … iver_CD.7z/file
I'm attaching the BIOS directly to this post. As with the driver CD, it is intended for motherboard revision 1.0 so I'm not sure if it will work on later revisions. Also, I found a leaflet with some errata regarding the driver CD in the box, so I'm posting a picture of that here as well.
    262.37 KiB
    BIOS_KT7A-RAID_A9.ZIP
    193.83 KiB
    71 downloads
Reply 31 of 104, by SETBLASTER
Joseph_Joestar wrote on 2020-03-26, 15:58:
Strange, I checked the link after uploading and it worked for me then, but now it appears to be dead. Re-uploaded to mediafire: […]
thanks joseph!
thank you!!!! iso downloaded! im sure it works on my version too
Reply 34 of 104, by SETBLASTER
finally someone has the an7 cd that i never found!!!!
plus im still looking for cd images of all these:
gigabyte ga-5ax
gigabyte ga-6vtx
gigabyte BX2000+
Aopen ax59pro
Epox mvp3g5 or G2 should be the same.
Epox 8RDA3+
Reply 36 of 104, by SETBLASTER
BRBlosh wrote on 2020-04-23, 06:34:
I finally upload AN7 CD to archive.org. You can download it. Later, I upload the SATA driver diskette.
https://archive.org/details/nv-124-m
THANK YOU!!!!
i was looking for that cd for a long time!!
Reply 37 of 104, by DoutorHouse
Ok, this is not a CD, but a diskette image for my Asus PI-P55T2P4 Motherboard i found stored inside a box of old diskettes. There was also a manual and a CD inside the motherboard's box but i guess the CD is long gone and i haven't found any trace of it yet...
Asus Motherboard Supporting Diskette Rev. 1.10.zip
1.34 MiB
74 downloads
108.44 KiB
I think the CD was the one on this picture but i can't remember for sure... Not much in it besides what was on the diskette, except some drivers for Asus soundcards or something...
Maybe somebody has an ISO of it and is willing to share? Thanks!
146.58 KiB
Reply 38 of 104, by vmr_
I think I have somewhere the original CD for Gigabyte ga-5ax, possibly Asus P5a as well. Have to dig it out from storage 😀
Not sure about AOpen ax59pro, have to check
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 39 of 104, by SETBLASTER
vmr_ wrote on 2021-05-24, 16:30:
thanks! anything you can find will help
when you do an iso please upload to any hosting site like mediafire
