First post, by foil_fresh
hi all
i've ordered a thermaltake pipe101 solid copper 500gm heatsink that requires either a separate 80mm or 92mm fan. motherboard is an ecs 648fx-A2. i currently have a stock cooler which is terribly loud and wobbly to the point that one of my SATA ports broke off from the vibration (i assume).
now back in the day i had a p4 2.4 that my dad gave me and it had a stock fan too, so i have zero knowledge about these hot beasts and how to cool them.
i have read that the fans should have 2 connectors - 1 for power and 1 for rpm management from the mobo. if this is correct, what kind of fan would be sufficient to cool the 103w TDP going thru this half kilogram heatsink? ebay / amazon inks / model numbers would be appreciated.
i would like to keep noise down. the heatsink is capable of handling 3.8ghz so i guess this cpu at 3.2 means that the heatsink will be cool enough with a lower speed fan? wrong? right? ehhhh?
cheers guys.
    59.43 KiB
Reply 1 of 8, by kolderman
Just make sure the fan is high static pressure. Do not get a slow one! Quality brands will make quiet capable fans. The Prescott were a disaster for heat, if I was you I would switch it for Northwood. They are cheap enough.
Reply 2 of 8, by foil_fresh
kolderman wrote on 2020-01-13, 07:14:
what is considered slow RPM and what is considered fast in this case?
and the 130nm northwood is cooler than the 90nm prescott? will it be slower? i mean the prescott is nearly 2 years newer. i'm okay with performance improvements.
Reply 3 of 8, by PC Hoarder Patrol
Any decent standard 3-pin or PWM 4-pin would do. Maybe look at the original quality beige/brown Noctua fans to match that lump of copper!, though they are pricey compared to others.
https://noctua.at/en/products/fan
Reply 4 of 8, by kolderman
I think 1000-1400 rpm is reasonable for a cpu fan. They have 4 wires, one is for PWM to control speed.
Prescott was a mixed bag performance wise. It was not much of a leap over Northwood and could even be slower. It was really a new cpu arch and not very good.
Reply 5 of 8, by foil_fresh
kolderman wrote on 2020-01-13, 07:29:
damn you're right, i just had a look at some older benchmarks and they're basically neck and neck. prescott wins in some and northwood in others. i would definitely be feeling the burn if i paid the rrp back in 04 for this thing.
i found one fan - vantec tornado TD8038H 80mm case fan - this was reccomended for the heatsink on another page elsewhere, yet its speed is a whopping 5700RPM. is this just overkill or is the 1000-1400rpm suggested too slow for the job?
Reply 6 of 8, by kolderman
That fan is High Air Flow Case Fan. Do NOT get that kind of case fan.
The noctua nf-f12 is high static pressure and does about 1500 rpm. Air flow fans can get such high rpm as there is nothing pushing back against them.
I run a Northwood 3.4ghz with a regular s478 hsf assembly and its fine.
Reply 7 of 8, by foil_fresh
kolderman wrote on 2020-01-13, 07:55:
ok cheers. i have had a look at all their 92mm fans and found this one on ebay.
should be good yea?
Reason: removed eBay link
