First post, by Intel486dx33
Hi, I need working Sound Blaster Pro 2.0 ( CT1600 ) drivers for DOS/Win 3x
The ones on Vogons driver library don’t work.
I need diskettes #1 and #2
Thanks.
Reply 1 of 7, by keropi
give the package I use a try, extract the SBPRO directory to c:\ (with -d switch if you use pkzip under DOS so it will create the subdirectories) and have a look at README.NFO
CT-1600 driver
* fully updated DOS/Win3.x drivers
* run WINSETUP.EXE to install Win3.x drivers/software/group
make sure the BLASTER variable is correct before installing
the 3.x package.
AUTOEXEC.BAT additions:
SET SOUND=C:\SBPRO
SET BLASTER=A220 I5 D1 T4
C:\SBPRO\SBP-SET /M:12 /VOC:12 /CD:12 /FM:12
SET MIDI=SYNTH:1 MAP:E
CONFIG.SYS additions:
DEVICE=C:\SBPRO\DRV\CTSBPRO.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1
DEVICE=C:\SBPRO\DRV\CTMMSYS.SYS (optional)
package was made with original disks and updates
    SBPRO2.zip
    2.27 MiB
    38 downloads
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 2 of 7, by Intel486dx33
keropi wrote on 2020-01-25, 08:15:
give the package I use a try, extract the SBPRO directory to c:\ (with -d switch if you use pkzip under DOS so it will create t […]
CT-1600 driver
the 3.x package.
SET SOUND=C:\SBPRO
Any way you could extract these files so I could just burn them to a CDROM disk ?
I tried to extract but WinZip won't let me do that.
Reply 3 of 7, by red-ray
Intel486dx33 wrote on 2020-01-25, 09:07:
WinZip 19.0 (11294) - 64-bit extracted them OK on this Windows 10 x64 Enterprise V10.00 Build 18363 19H2 system so I zipped when again using the inbuilt ZIP.
Can you extract the attached? If not what system are you trying to extract on and which utility are you using?
    SBPRO2-W10.zip
    2.27 MiB
    7 downloads
    SBPRO2 zipped on W10
Reply 4 of 7, by Intel486dx33
red-ray wrote on 2020-01-25, 09:23:
thanks
Reply 5 of 7, by Deksor
You can also get the disk images here http://www.win3x.org/win3board/viewtopic.php? … yle=30&f=8&t=23
alternative
Reply 6 of 7, by keropi
very weird, I used WinRAR to create this ZIP file, it extracts ok under DOS with pkunzip 2.04 ...
anyways looks like it's solved now 😀
did the drivers worked for you?
Reply 7 of 7, by Intel486dx33
keropi wrote on 2020-01-25, 11:52:
very weird, I used WinRAR to create this ZIP file, it extracts ok under DOS with pkunzip 2.04 ... anyways looks like it's solve […]
Thanks worked great.
