First post, by Deksor
Hi !
I've got this FIC PA-2000 motherboad. I don't really have any questions about it, it's just that I've taken the time to retrieve the manual from there http://www.elhvb.com/mobokive/Archive/Fic/man … 2000/index.html ... but it's spilled across many .pdf files inside many .zip files and some pages are poorly scanned, some are better, and they're not oriented properly for the most part.
So, I took the time to take every page, put them in the right orientation and merge them into a single .pdf file, and now I just want to share it 😁
You can grab it here :
PA2000-MANUAL.zip
4.6 MiB
67 downloads
I've also found this nice high res picture on the internet, so let's just make sure it won't get lost ^^ (I won't put a picture of mine because mine is in a rough shape, with damaged caps, damaged ICs and a missing BIOS).
1.7 MiB
alternative
