First post, by user33331
Hello
What form is called a socket 7 board with 1pc raiser ?
- What is the case style is it a custom case for Fujitsu ( OPTi Viper.) ?
+ ATX is >"1999+" PC cases ( Large rectangle opening: Pentium II,socket A,...).
+ AT is <"1998" PC cases ( Has a hole for old keyboard connector: Pentium 1,486,386,...).
    59.82 KiB
Reply 2 of 4, by eisapc
LPX is the board itself, there is no standard for the riser boards.
I have seen the following riser boards in LPX boards:
- plain ISA
- ISA+VLB (only one VLB slot on riser)
- EISA slot used for ISA and PCI
- Proprietary with ISA and PCI
LPX was used for 286 allready.
Cases used for LPX boards are non standard, but sometimes interchangeable.
Many OEMs had LPX in their portfolio (SNI, ASUS, IBM, DEC just to name a few)
eisapc
Reply 3 of 4, by gex85
Oh well, I have good memories about the LPX form factor...
My childhood system was a "Tulip Impression Line Compact" 486 machine, which had an LPX board as well.
https://www.tulipgv.nl/impress.htm
https://www.tulipgv.nl/impression-compact.jpg
Still trying to obtain this machine again, but Tulip systems in general show up very very rarely, and I have never seen this particular model for sale anywhere.
1992 - i486DX2-66 // 1997 - P1-233 MMX // 1998 - P2-350 // 2000 - P3-650 // 2001 - Athlon 1400 // 2003 - Athlon XP 3200+ // 2008 - Xeon E5450 // 2015 - Xeon E3-1240v5
Reply 4 of 4, by dionb
eisapc wrote on 2020-01-29, 12:48:
LPX is the board itself, there is no standard for the riser boards. I have seen the following riser boards in LPX boards: - plai […]
- plain ISA
eisapc
Yep, and it gets worse - even where risers and boards match, there's no guarantee the case will. I had an IBM PS/1 486 motherboard with matching riser that was about 5mm too far forwards for my generic (yes, they exist) LPX case.
