First post, by user33331
Hello
Socket 7/8 boards when can I safely expect that booting from a cd-rom is possible ?
- Coarse date when booting from cd was commonly available ?
- When around 1996-1997 ? What bios versions had boot from a cd-rom available ?
For example for "Intel bios".
When installing win98 to socket7/8 is it common to:
-1st install dos and then install win98 from cd.
"Booting from CD-ROM is supported in adherence to the “El Torito” v. 1.0 bootable CD-ROM
format specification developed by Phoenix Technologies and IBM. Under the Boot Options field
in Setup, CD-ROM is one of four possible boot devices which are defined in priority order. The
default setting is for floppy to be the primary boot device and hard drive to be the secondary boot
device. If CD-ROM is selected, it must be the first device."
A copy of “El Torito” v. 1.0 is available on the Phoenix Web page
(http://www.ptltd.com/techs/specs.html).
Reply 1 of 7, by bofh.fromhell
My trusty 'ol ASUS T2P4 rev 3.1 supports CDROM boot.
And a quick search suggests it was available from launch and it was released in late 1996.
I dont think it was a common feature tho as most OS installs didn't support it until a few years later.
Reply 3 of 7, by douglar
https://en.wikipedia.org/wiki/El_Torito ... _standard)
El Torito is an extension to the ISO 9660 CD-ROM specification. It is designed to allow a computer to boot from a CD-ROM. It was announced in November 1994 and first issued in January 1995 as a joint proposal by IBM and BIOS manufacturer Phoenix Technologies. According to legend, the El Torito CD/DVD extension to ISO 9660 gained its name because its design originated in an El Torito restaurant in Irvine, California
Here's the original standard:
https://pdos.csail.mit.edu/6.828/2014/reading … /boot-cdrom.pdf
If your BIOS does not support the boot standard and you have an IDE CD-ROM drive, a boot manager like PLoP should let you boot from a CD if you can get it on a working boot device.
https://www.plop.at/en/bootmgr-new.html
Reply 4 of 7, by SirNickity
The usual progression of these things is that:
- The spec emerges
- Things start supporting the spec (BIOS)
- Software starts to use the spec (Windows install CD, etc.)
- The crippling bugs and limitations get fixed
IIRC, I was recently able to accidentally boot from a CD with a floppy emulation image on a Super Socket 7 board. I was also NOT able to get an Adaptec AHA-2940 to boot from a disc in a SCSI CD-ROM, despite it detecting that it was authored as bootable. (I am not sure what media type its image specified -- I think it was a Linux disc, so probably No Emulation. Could also have been BeOS R5 Pro, and I'm not sure if that's a floppy image or NE.)
On a Pentium II, things seem to have been pretty much sorted out.
Reply 6 of 7, by cyclone3d
No need to install DOS first if the system can't boot directly to CD.
Win9x came with an install floppy boot disk. You boot to the floppy and then run setup from the CD.
https://www.retrocomputing.co.uk/p/windows-98 … stallation.html
34.59 KiB
384.83 KiB
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 7 of 7, by SirNickity
douglar wrote on 2020-01-31, 20:35:
I'm familiar with the floppy emulation, but there's been other types of bootable CD/DVD's since than, yes?
It's just one of the options when you author the disc. For e.g., you can emulate a floppy, a "hard disk", or no emulation. AFAIK, floppy emulation and no emulation are the most common.
I made a CD with DOS 5, DOS 6.22, Win 3.0, 3.1, WFW 3.11, Win95, Win95C, Win98, Win98SE, and WinME. It has (among a couple others) a Win95C boot floppy image on it, and the rawrite tool to copy it to a floppy. But that same image is also bootable from the disc itself. I just used that last weekend to boot my Pentium 166 from CD and it works really well -- except it does take over the A: drive, so if you need to put in a floppy during Windows setup (upgrade check for e.g.), then you have to use B: to access it.
