First post, by Nemo1985
Hello there, I spent some time testing my collection of pci cards on ms-dos 7.1 with the phil's benchmark pack.
Initially I was using a P3-650 mhz with a MSI BX MASTER mb but I started to get issues with some cards, avance logic card was freezing during some benchmarks, the ET4000\w32p refused to boot (both my et4000 cards) and I noticed some screen corruption using some cards. I had to switch back to a ss7 machine, I used a K6-3+ @ 550 mhz with the Aopen X59 pro.
Every card has been tested with the maximum memory installed.
138.61 KiB
Still I had some quirks, but I suppose it was because of the cards, the purple color on there shows that the benchmark was able to run but with issues.
Sis 6202 had troubles running benchmarks at 640 with 2mb of memory, banding and screen corruption, it doesn't happen when 1mb is installed and try different chips didn't change the result.
I did a topic before about matrox cards but then deleted since noone was interested, it seems the one with older bioses has less compatibility issue on msdos, the Mystique with bios version 1.2 gives a bit higher results and works on Chris 3D 640, while it doesn't if updated to bios version 1.8, unlucky I haven't been able to find any other bios release.
Trident 3DImàge 9750 other than the bad performance it has screen corruption on PC Player 640 on the higher and lower border.
On the other hands I have been impressed with Permedia 2 performances, despite being an opengl\winnt card it was very good on dos. The ET6000 is great too.
I was wondering if anyone know the difference between ET6000 and ET6100.
Reply 2 of 18, by BinaryDemon
What’s the un-colored (white) boxes represent? I’ll have to take a closer look at Permedia2.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 3 of 18, by Nemo1985
BinaryDemon wrote on 2020-02-02, 00:28:
Uncolored because I'd have to use too many colors
Green is for the best performance, yellow second, orange third and red the worst.
The last 2 3dfx cards have white color because I wanted to try the Nvidia GeForceFX 5500 pci too but it wasn't boot on ss7 machine so I took it off from the comparison.
I also did the quake 640 benchmark (with vbe 2.0 cards only since it didn't work with 1.2) but the results were cpu limited so I took that off too.
Reply 4 of 18, by Horun
Nemo1985 wrote on 2020-02-02, 00:18:
Nice ! Thank you. When you say Maximum memory did the Matrox cards have 8Mb or more ? I have some M2 with 8Mb but never tried Chris 3d test on them, odd to see good results on one test but black screen results other test. Maybe the card/matrox driver doesn't like the way the higher end test initiated.
Other thing: never thought a CL card would perform as good as your results on the 5446. Very interesting !
Reply 5 of 18, by Nemo1985
Horun wrote on 2020-02-02, 03:08:
Thank you for showing some interest 😀
I uploaded the version with mb memory for every card, I should say that for maximum amount I mainly refer to older cards with SOJ package.
About the matrox cards, I would be curious to check the other bios release or other release for the m220 or millennium 2 but I can't find them, they have a great quality output and if downgrade the bios (I found how to do it since I was able to downgrade from 1.8 to 1.2) improve the dos compatibility it would be the jack of all trades, believe me when I say that some of these cards have a very low quality, it can be seen on Chris 3D 320.
I agree with you the CL-GD5446, has good results, too bad I don't have the GD5440, it was the chip after the 5436, I found it for 20 eur, quite too much for my tastes. Another card I would be curious to test is the Ark2000mt, to my knowledge it could gives very nice results.
I did those test to decide which videocard to use on my amd 5x86, I will probably re-run the tests on that older machine but preliminary results shows it is mainly cpu limited.
Reply 6 of 18, by clueless1
Great job, man! Very interesting results, but mostly, a great round-up of cards. I've been trying to get my hands on an ET4000 and ET6000 for years but they're always so flippin expensive. The other really interesting number I saw was for the Avance Logic ALG2302.A. It is so much faster than the ALG2301.B. In my tests, the 2301.B is just a little bit faster than the GD5430, but your ALG2302.A is in the top third of your results. Any idea what brand and model the card with that chip is? Mine is a Hercules Stingray.
Some other observations on your results:
-I'm surprised at the relatively big difference between the Banshee and V3 2000 in certain benchmarks
-most of the cards I have line up with your results.
-you need to get a TNT2 M64 PCI. They are relatively cheap and easy to find and are always at or near the top of such comparisons.
-I wish you had the Ark Logic 1000/2000PV. I'd love to see how they compare to the ET6000 and Banshee. See, I have the Ark1000/2000 but not the ET4000/6000. We should trade for benchmarking purposes, then trade back when done. 😀
-it's interesting to see these results on a K6-3+ 550. I think it's actually a really good platform to test DOS PCI graphics cards. I would suggest you retest on a slower platform (P233MMX) to see how the results change. I have found that the faster the platform, the more exaggerated some of the differences between the cards become. Think about what the typical DOS retro PC would be built on today for gaming. Too fast becomes problematic for a lot of games, so the typical recommendation for a fast DOS gaming PC is somewhere between P200 and K6-2 550. I've been testing between P75 and P200 over the years and occasionally posting results here.
-you might want to test with Univbe as well. I have found that even at VGA 320x200, it slightly helps performance in certain benchmarks: Chris' 3D, Quake, Duke3D, and even occasionally 3dbench. So here's the scoop: For the S3 cards, there's S3VBE20.EXE, which only uses ~6kb but doesn't help as much as SDD/Univbe. Sci Tech Display Doctor 5.3a is what I use. It has a smaller footprint (~13kb) than Univbe 6.7 (~17kb) and equal performance. I test with and without SDD53a. It doesn't work with newer cards that already have VBE2+, like the Millennium II, Voodoo3, and TNT2 M64. But they don't need it because they already have native support.
Thanks for sharing these results. I'm always interested in DOS graphics card benchmarks. Cheers!
Reply 7 of 18, by Nemo1985
Thank you.
Avance logic card is one of my favourite for 1995 year, mainly because it's an almost unknown manufacture but to my eyes it's not that bad...
This is my card: https://i.imgur.com/MSmETIe.jpg I would have said it's an oem card but according to vga museum it's a powercolor.
I never heard about the tnt2 m64 pci, if you have some link feel free to send me a pm 😀
I have two et4000\w32p cards, one is the Hercules with vb v1.2 support the other is Siemens card (http://www.vgamuseum.info/media/k2/items/cach … da792716_XL.jpg) which weird enough supports vbe 1.32 but despite of this it has lower compatibility compared to Hercules (vbe 1.2).
Well actually that was the purpose of my test, since dos platform is strictly software the cards are cpu limited already (at least at 640x480 resolution), one of the reason I removed the quake 640 from the comparison it's because most of the cards were having the same result, imho lowering the cpu speed will flatten the results even more.
Yes Univbe is a great idea, it was always adviced back in time, probably will enable the 640x480 resolution on quake and give some higher results as you suggested, I will consider that, thank you!
Reply 8 of 18, by Disruptor
Nemo1985 wrote on 2020-02-02, 14:42:
Thank you. Avance logic card is one of my favourite for 1995 year, mainly because it's an almost unknown manufacture but to my e […]
Thank you.
Oh, I have a predecessor of your ALG graphics card:
The ALG2301.A from 1994. (1 MB + possible another 1 MB in 8 sockets)
It was my first PCI graphics card.
Reply 9 of 18, by clueless1
They are quite common. It was a low-end nvidia card for Win9x but had surprisingly good DOS performance. Just search ebay (or wherever you shop for retro gear) for 'tnt2 m64 pci' and you'll find plenty of results. 😀
Reply 10 of 18, by Horun
The only PCI cards in my collection not on your list are: ATI Mach64 2mb, ATI Rage XL 8mb, Viper 330 (Riva 128 4mb), and a WDC WD9710 "Paradise Pipeline PCI" think it is a 1mb but expandable. I may look for TNT2 M64 PCI, was sure I had one but might have given it away or it's an AGP variant in a differant box of stuff 🙁
added: just found a CL-5434 2mb pci and Trident 9440 both in low end pentium boxs.
Reply 11 of 18, by The Serpent Rider
Trident 9440 series is horrible. It's more or less fine as VLB card for a 486 system (CPU is too weak anyway in most cases), but PCI version does not scale gracefully.
Reply 12 of 18, by Nemo1985
I did the same tests with the Amd 5x86 133 paired with Biostar MB-8433UUD-A, 256kb cache and 32mb FPM memory, settings for cache an memory are the fastest possible.
112.45 KiB
Results are just silly, the videocards are heavily cpu limited.
For this reason I also tried the ET6000 with overclocked cpu and bus (40x4) 160 mhz, the improvment is huge.
In the end with such pci vga cards doesn't really matter which one you are going to use.
Reply 14 of 18, by Nemo1985
Intel486dx33 wrote on 2020-02-07, 11:25:
Why don’t add a column to your spread sheet for total score of all the benchmarks to which card has the best overall score.
Thank you for the advice.
Honestly I do not think it would be useful, I just compared the overall results of the Millennium 2 and Trident card, the first get an overall higher total results but despite of that in 1 test it gives black screen, that means it is less compatible than trident card.
Reply 15 of 18, by The Serpent Rider
Also Chris3D and 3DBench are totally synthetic and does not represent anything useful.
Reply 16 of 18, by appiah4
Shit, that SiS 6326 is an absolute dog..
I will be doing a similar test on my current Socket 7 PC at some point. I have a crap ton of PCI cards to test with it.
Reply 17 of 18, by imi
Yeah, I always like seeing benchmarking roundups of old hardware ^^
I plan to do some benchmarking too in the future ^^ I have a wide variety to choose from even if I'm missing certain noteworthy cards due to prohibitive costs nowadays. (I'm looking at you ET6000&co)
Reply 18 of 18, by Nemo1985
appiah4 wrote on 2020-02-07, 12:48:
Sis 6326 is bad with the 486 pc, but with the k6-3 wasn't that bad (not great, not terrible), still I don't get why some cards gets lower results despite being more powerful with the 486, I will probably test the cards with another 486 mb...
