Say "Hi!" to the Renovation SSI-2001!
Reply 20 of 149, by FreddyV
Hi,
I asked the question to Labs as well on his blasterBoardas well.
Why not using a EPLD to be able to decode any port and then, emulate more sound cards ?
I don't see audio amplification component, how this is done ?
I saw in a 8 bit gui video that only 2 games support it, so why doing it ?
Reply 21 of 149, by Benedikt
matze79 wrote on 2020-03-09, 21:06:
i`m really interested into the software part, a opensource sid emulation core for stm32 would be really great 😀
Well, as mentioned before, the synthesizer part of the emulation core already exists and the author has apparently published it under GPL 3 license: STM32-SID-PLAYER.
Adding bus interfacing code to turn it into a complete SID replacement should be relatively easy.
FreddyV wrote on 2020-03-10, 10:42:
The answer is simple:
Firstly, I'd have to buy or improvise a programmer for EPLDs, because I don't currently have one and secondly, the range of supported ports is already broad enough for at least emulation of the lo-tech Tandy card at 2c0h or 2e0h, for which game patches already exist, and for the Covox Sound Master at 280h or 2a0h, albeit without DMA support.
The CMS/Gameblaster port ranges can be made available either by extending the jumper bank or by temporarily using a test lead. Probably the latter, because I want to keep the visual appearance.
Why do it?
This card will serve not only as an SSI-2001 replica, but also as a test bed for multiple things at once, namely:
  • What could become the first fully open source SID replacement (see above)
  • An NE558 quad timer replacement consisting of two NE556 dual timers
  • Potentially other emulation cores (see above)
  • S/PDIF bitbanging using the STM32's SPI interface via DMA, effectively writing one byte per encoded bit (only if I find time for that)
Condensing all of that into a single PCB layout can reduce the cost, substantially.
Reply 22 of 149, by root42
Because! Also, there are more games: https://nerdlypleasures.blogspot.com/2014/01/ … bedfellows.html
Airball - SFX only, slow PC req'd
Bad Blood - Music only
Battle Chess II - SFX only
BattleTech: The Crescent Hawks' Revenge
F-19 Stealth Fighter
Falcon A.T.
Harpoon
Joe Montana Football - SFX only
Lord of the Rings Volume 1 - Floppy version only, SFX only
Red Storm Rising
Super Jeopardy
Ultima VI - Music only
Windwalker
Furthermore you can probably play C64 VGM with it. And more than that: If we have a replica, people can start coding for it in the homebrew/demoscene. I applaud the effort!
YouTube and Bonus
Reply 23 of 149, by root42
Incidentally: Would someone be willing to take part in an order of ~10 PCBs for the Renovation 2001, which is up on github? I could be persuaded to order PCBs, Mouser parts and NE558s. For the SID: people need to supply their own SID, or optionally I would try to get ahold of some SwinSIDs (~15-20 EUR per piece). They seem to be rare at the moment as well.
YouTube and Bonus
Reply 24 of 149, by matze79
You properly miss some games with native support,
also there even more games, because there are drivers for other sound systems 😉
Red Storm Rising for example,
VICE C64 Emulator also supports the Card.
Reply 26 of 149, by Benedikt
root42 wrote on 2020-03-10, 12:17:
I'd be interested! 😜
And IIRC, all components except for the RCA jack, the tiny NE556s and the bracket are also available from Reichelt and cheaper there.
So I take it you downloaded the files and are impressed?
Keep in mind that the design is still preliminary. There might be errors that I simply don't see.
Reply 27 of 149, by root42
Benedikt wrote on 2020-03-10, 14:50:
I'd be interested! :-P And IIRC, all components except for the RCA jack, the tiny NE556s and the bracket are also available from […]
Then I would suggest to make a smaller order: 3 PCBs at Aisler; because the SIDs will be expensive. The RCA jacks will have to be found (where?) and the 558 -- which we could leave out for the time being, since it would be a beta test. So you never built the card?
YouTube and Bonus
Reply 28 of 149, by root42
This is what it would look like at Aisler. I will have a look at the BOM later. If everything works out, I might just order 3 PCBs and components.
136.64 KiB
YouTube and Bonus
Reply 29 of 149, by Benedikt
root42 wrote on 2020-03-10, 15:11:
The RCA jacks, NE556 in SSOP14 package and the Keystone bracket are available from e.g. Mouser, probably Digikey, as well.
No, so far, I have never built the card. I published the design as soon as it looked presentable.
However, I am reasonably confident that the MOS6581+NE558 configuration is identical to the original card, because all the visible traces are identical and the schematic makes sense.
MOS8580 configuration should also work, as far as the layout is concerned, but I'm not entirely sure about the values of the resistors that set the voltage of the adjustable voltage regulator.
The problem with these 3-pin adjustable regulators is that the output voltage can drift depending on the load and how much it drifts depends on how large or small the resistor values are.
When it comes to the STM32-based version, some resistor values are still unknown, because their purpose is fine tuning of the card's output levels.
For the time being, I would suggest to wait with PCB orders and to take another close look at the schematics and layout to compare them to existing board photos.
Reply 30 of 149, by root42
Hm. Do you think there will be revisions to the board?
YouTube and Bonus
Reply 31 of 149, by Benedikt
Well, if I find errors while double checking everything, you better bet that there will be revisions.
However, if I don't, there probably won't.
Give me a day or two.
Reply 32 of 149, by Benedikt
So far, I have only found one minor error:
The position of the mounting holes for the bracket was off by fractions of a millimeter. Just enough to prevent it from fitting.
Other than that, I have added a hidden pad to simplify Fagear's compatibility mod for fast ISA busses, which is not included in my board layout.
You still have to cut a trace and run a wire, just like you would have had to do on the original card, but the added pad allows you to hide the wire below a chip.
Reply 33 of 149, by root42
Cool.
I am still not giving up on getting a bracket with DB15 hole. Maybe this would be an option:
https://www.mouser.com/ProductDetail/Keystone … ccOWCwv6Q%3D%3D
We could do one hole for the RCA jack and fix the bracket with the DB15 hex screws.
YouTube and Bonus
Reply 34 of 149, by Benedikt
root42 wrote on 2020-03-10, 21:52:
Cool. I am still not giving up on getting a bracket with DB15 hole. Maybe this would be an option: […]
Cool.
We could do one hope for the RCA jack and fix the bracket with the DB15 hex screws.
I'll have a look at the datasheet, tomorrow.
Reply 35 of 149, by Benedikt
Mmh... I'd have to shift the DA15 socket by 7 or 8 mm, i.e. almost to the edge of the board.
A configuration without joystick port would need both mounting holes for the bracket, though.
This repositioning would also be among the most noticeable alterations to the design.
In short: I understand the motivation, but I'm not particularly fond of the idea because of the visible alterations it implies.
The choice of a cheaper and more common type of DA15 socket was a compromise, already, and based on the realization that of the two DA15 variants on the original cards, only the ill-fitting one is still available and even that is ten times as expensive.
Reply 36 of 149, by Benedikt
I spotted an error in the schematic: The values for the LM1117-ADJ's configuration resistors were way off.
I must have forgotten to set the reference voltage in KiCAD's voltage regulator calculator.
The updated version is online and the board layout stays the same, anyway.
Everything else looks good, so far.
If everything goes well, I'm going to order a batch of boards in a couple of days.
A ten-piece batch would result in ~5€ per board.
Reply 37 of 149, by matze79
did you already order pcbs ?
Reply 38 of 149, by Benedikt
matze79 wrote on 2020-04-13, 15:47:
No. For the time being, that has been postponed, but I have not found any further errors in the design, either.
Reply 39 of 149, by matze79
Recieved the PCB today and a Fake ehh SwinSID, thx root42 !
189.55 KiB
