Reply 21 of 27, by Faradrim
robbo007 wrote on 2022-01-04, 14:38:
Hi, No 🙁 A real shame as it would have been good to play this on real hardware.
Regards,
Ok i just installed Mondain's Legacy works on windows 98 se. I created sphere based server now im testing working fine. I did test on VMWare Win98 SE works flawless right now.
UPDATE: 9th Anniversary installer working, i'm gonna try all versions of setup so if i can update game with launcher we can login OSI, maybe some private shards like i create.
Reply 22 of 27, by Faradrim
I will give links for play UO i found RunUO based server works right now.
Mondain's Legacy
https://archive.org/download/UltimaOnlineTMMo … h%200%5D%5D.iso
This version also works i tried
https://archive.org/details/UltimaOnlineTM9th … 6.0.1.10Patch72
Then open Ultima Online folder look for file name login.cfg
Then edit with notepad, copy all of this paste and save. After that don't use shorcut on desktop. At folder Ultima Online find client.exe and use it that's it. Make it new shorcut to dekstop.
Copy this to login cfg:
;Loginservers for Ultima Online
;Do not edit this file or patching will fail! Always save a backup.
LoginServer=shard.uoex.net,60
UPDATE: I found old razor setup so can login uosecondage server. I'm gonna upload files you need install like netframework 2.0 ie6 and some patch.
UPDATE 2: Just forget other things,
http://www.uosecondage.com/Connecting
get this http://download.uosecondage.com/UOSA_Client_Setup.exe
get IE 6 and update after that install netframework 2.0
download razor i added, after that use UOSA_Client_Setup.exe unselect razor and other problem just install. Then login that's it 😀
    481.55 KiB
    Razor_Latest.exe
    650.91 KiB
    14 downloads
Reply 24 of 27, by robbo007
Faradrim wrote on 2024-01-24, 08:19:
I will give links for play UO i found RunUO based server works right now. […]
Mondain's Legacy
Is this a private server or the UO official server? I have an account on the official server but using this process does not like my logon details.???
Reply 25 of 27, by Faradrim
robbo007 wrote on 2024-02-13, 18:43:
UPDATE 2: Just forget other things, http://www.uosecondage.com/Connecting get this http://download.uosecondage.com/UOSA_Client_S […]
Just try this. There is no way to play official servers right now because they updated client installation and client. You can enjoy this server, or just try for fun 😀
