First post, by Jimbondaxor
First of all, hello to all and sorry that my first topic on here is a pathetic cry for help but there you go.
I need help with a socket 370 mb and a psu
This is the board in question.
https://microdream.co.uk/compaq-deskpro-en-so … ml#.Xl60dKgzZjE
Anyone have any experience with this particular Compaq board? I know it's an OEM.
I recently purchased it and I also have a Pentium III 866Mhz and 256mb sd ram.
It wont't post. I tried my good (modern) PSU, I've also tried some no name PSU with supposedly higher 3v and 5v amperage. (30 on both) but no luck. A few green lights light up on the MB but the cpu fan doesn't spin and there's no vga signal.
The seller swears the board works (of course). He claims it works with one of his old 20pin PSUs.
What do you guys think? Is the board toast or do I need some kind of special old PSU, or maybe some custom OEM PSU? I've been dealing with this nonsense the past few weeks and it's not fun.
Reply 1 of 6, by flupke11
If it's an i815 your 866 should work. Have you tried:
- resetting cmos
- another stick of PC-133 SDRam
- with an AGP or PCI VGA
- check individual components on another M/B.
I am not sure the PSU is really the culprit here. Have you tried the PSU on another mainboard?
Reply 2 of 6, by Jimbondaxor
flupke11 wrote on 2020-03-03, 21:10:
If it's an i815 your 866 should work. Have you tried: […]
- resetting cmos
- I did reset cmos
- yes, the PSU works...the CPU and RAM also work, I've tried them on another board
It's either the PSU or the board and I'm starting to think it's the board, although the seller claims it works only with old PSUs, how old I'm not sure.
Reply 3 of 6, by dionb
The only PSU-related thing left (if your PSUs are known-good) is negative voltages. Do your PSUs supply -5V and -12V? If not that could conceivably be what the seller is referring to. Not at all sure that's the case. I have the uATX version of this board and has never refused any PSU I threw at it - although I do actually generally use ATX 1.x PSUs with those lines, so can't be sure.
Reply 4 of 6, by Jimbondaxor
dionb wrote on 2020-03-03, 22:10:
Hmm, I'm not seeing -5V anywhere written on the side of the PSU. Can you link an example of a PSU that supplies negative voltages? What kind of PSU are you using with your 370 board?
Reply 5 of 6, by Horun
I have a few retail ATX PSU from the late 90's to early 2000's and all during that time had -5v and -12v. There are still some made like this one at Amazon:
https://www.amazon.com/Coolmax-I-500-500W-Pow … /dp/B0081H7EDK/
But many new ones do not have the -5v and or -12v
A picture of one of my older 20pin ATX PSU for testing motherboards
    306.85 KiB
Reply 6 of 6, by ole smoky2
I can't help with your problem but in defense of the seller, who is not me, a year or so ago I sold an old Matsonic slot 1 board with a p2 400 and ram on ebay. I had used the board for a while and it worked perfectly. Had it playing games the night before I shipped it. But sure enough the buyer could not get it to boot at all. I tried to help, even sent him to this forum. Ended up refunding his money and let him keep it. So I can tell you this stuff does happen.
