First post, by skel2raw
Hi guys,
I would like to easily switch between the Midi devices (MT32, SC55, SC88, SC8820, Yamaha MU80) I have connected to my pc retro build. Depending on the game I am playing I would like to easily switch between the devices without using their midi thru ports.
Do you know of any sort of midi switch, hub etc. which simply has a midi in and a couple of midi outs between which I can easily switch?
Thx!
Reply 1 of 46, by BloodyCactus
motu microlite, motu midiexpress, roland mpu 104+105 in combo, midisport 4x4 maybe.
there are lots of midi switchers/selectors.
Reply 2 of 46, by cyclone3d
You can also use a simple AT style keyboard switch or a really old KVM switch.
That will be your cheapest option.
Do a search on eBay for:
Din-5 switch
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 46, by dionb
I use an Edirol 550 (5 in plus 5 out), the 880 does 8 in 8 out. The advantage over a simple switch is that you can use one source for multiple outputs at the same time. Plus nice snazzy 19" rackmount. However cyclone3d's suggestion is most definitely cheaper.
Reply 4 of 46, by BloodyCactus
a lot of newer units too are usb controlled and have no switches for manual selection, which is something to be aware off.
ie: emagic amt-8 vs akai me30pii
Reply 5 of 46, by xjas
I have a Casio TB-1 (2 in, 8 out) and a Midiman Thru 3x8 (3 in, 8 out). Both are really nice as they work as more of a matrix and you can route multiple PCs or sequencers to a stack of sound modules however you like. 100% physical button switching, no USB needed.
Reply 6 of 46, by skel2raw
Thank you guys for the suggestions!
BloodyCactus wrote on 2020-03-04, 15:53:
Why would I need both? Are they not simply the same thing with one of them just having one more output?
Reply 7 of 46, by BloodyCactus
no the mpu 104 is an input selector, so eg: you could connect your ryzen 90000, your xp, your k6, your pcjr and your atari st to it. (it has 5 inputs, 1 output)
the mpu 105 is an output selector, all your modules plug into it (it has 1 input, 5 outputs). you can activate none, 1, or all outputs at same time.
Reply 8 of 46, by skel2raw
cyclone3d wrote on 2020-03-04, 16:02:
You can also use a simple AT style keyboard switch or a really old KVM switch. […]
Din-5 switch
That is actually a very nice idea. never realized that midi and AT style keyboard have the same connection.
Reply 9 of 46, by skel2raw
BloodyCactus wrote on 2020-03-04, 20:34:
Ah I see. But looking at the prices I guess it would make more sense to get a motu micro lite.
Reply 10 of 46, by dionb
skel2raw wrote on 2020-03-04, 20:43:
Don't assume eBay prices are the only deal in town. You can find this sort of stuff much cheaper through classified ads. My Edirol UM-550 cost me EUR 50 and I barely missed out an an MPU-105 for half that.
Reply 11 of 46, by skel2raw
dionb wrote on 2020-03-04, 21:00:
Where for instance can I find this kind of stuff?
Reply 12 of 46, by cyclone3d
Are you located in the USA? If so, there is always Reverb and Guitar Center.
A lot of pawn shops also tend to have a lot of used audio gear.
YMF7x4 Guide
Reply 14 of 46, by cyclone3d
Ok, so just get one of those old 4-way switch boxes with the DIN-5 connectors. If you need to switch between more than just 4 external midi devices, just get however many you need and daisy-chain them.
Each box you add will net you an additional 3 output selections.
Edit:
You could always just build yourself one with a rotary switch, project box, and the appropriate number of DIN-5 connectors.
Here is an example of a 24-position, 2-pole rotary switch. I think the 3rd wire used (ground) could just be connected all together and shouldn't need to be switched.
234.13 KiB
It looks like you can go all the way up to 36 position rotary switches.. but those are getting way up in price.
YMF7x4 Guide
Reply 16 of 46, by cyclone3d
imi wrote on 2020-03-04, 22:29:
if you use a manual switch just don't switch during playback ^^
Ha.. true that.
YMF7x4 Guide
Reply 18 of 46, by dionb
skel2raw wrote on 2020-03-04, 21:52:
In Germany... For some reason, all the cool electronics stuff is in the US 🙁
You sure? I live in NL and have the feeling most is in DE 😜
Anyway, check eBay Kleinanzeigen. That works more like Craigslist than the regular eBay with prices to match.
Reply 19 of 46, by skel2raw
dionb wrote on 2020-03-05, 07:00:
Ok, I stand corrected... Most of the cool electronics are in the US AND Japan. I was just searching for the Edirol UM550/880. The UM880 looks so beautiful and does exactly what I need. It's like love at first sight. The problem is the ones on eBay are mostly from Japan with 100v. On Kleinanzeigen etc. I couldn't even find one offer.
