Serial port on 486 motherboard
Reply 20 of 33, by lutz79
I used a needle to check every single hole on the female ps2 adapter. I used the speaker connector on the motherboard to get a GND pin. This is the situation. It seems to me the opposite of how it should be. Is it correct in your opinion? Thank you!
    56.62 KiB
Reply 22 of 33, by konc
Check the mouse on your XT, just to make sure that the adapter and the mouse work. There's a high chance that the mouse doesn't support serial operation, have you considered this case?
Reply 23 of 33, by lutz79
The mouse works regularly. I tried it on another PC. I'm not sure though that it supports serial operation, but probably yes. A few years ago, if I'm not mistaken, I used it with a serial adapter. Do you have more detailed information about it? thank you.
Reply 24 of 33, by PARKE
When a mouse supports both serial and PS/2 protocols it is typically noted on the sticker, like so:
75.39 KiB
further read:
PS/2 to Microsoft Serialmouse Adapter Converter / Updated First Post / Firmware Update added
Reply 25 of 33, by lutz79
I downloaded the drivers for the genius newscroll mouse. The drivers work correctly on COM1, both on DOS and on Win311. I see the mouse pointer on DOSSHELL and on Win311. But it doesn't move!
I tried to insert a PS2 optical mouse, but the light doesn't turn on. Does this mean it is not powered?
Reply 26 of 33, by PARKE
I do not know the exact symptoms of a mismatch.
Do as konc advised - try the mouse + adapter on another system with serial port in order to eliminate possibilities. If that works either the PCChips motherboard's IO or the serial cable is faulty.
Reply 28 of 33, by lutz79
Okay, I tried the adapter on my mother's computer with a COM1 port. This computer has Windows 10. I have connected both the Genius mouse and the optical mouse. On restart they are not recognized by the operating system. I am increasingly convinced that the adapter is broken.
Reply 29 of 33, by PARKE
Everything is possible but my first vote would be for the Genius mouse being incompatible with serial port. But there is little harm in buying/trying another adapter. Spare parts are almost a must in this hobby.
Reply 32 of 33, by Peter5557
@Horun
Thanks a lot for the serial pinout! Was so happy to get my P60 Mainboard to run, and then my mouse would not function.
Tried 5 different serial brackets, and with no one my serial mouse was recognized.
Then is soldered the cables like it is seen on your pinot - And now my serial mouse is running fine - Yeah - THX 😀
Reply 33 of 33, by agentot
saved me today!!!!!
thanks!
Horun wrote on 2020-03-14, 23:42:
Ok so there are two standard motherboard pin outs for COM ports, and probably a few proprietary ones. The standard ones are AT/E […]
Ok so there are two standard motherboard pin outs for COM ports, and probably a few proprietary ones. The standard ones are AT/EVEREX type or DTK/INTEL type, the way to check is from pin 5 or pin 9 on the header. If pin 5 is Ground then AT/Everex, if pin 9 is ground then DTK/INTEL. The PcChips m919 v3.4 (or at least my board) has pin 5 as ground just like early Asus and Gigabyte so is AT/Everex. To check your COM port dongle you need to check if pin 5 on the the header connection is connected to pin 5 or pin 3 of DB9.
if connected to pin 5 then it will work with AT/Everex header, if to pin 3 then DTK/Intel header wired. To verify if DTK/Intel type and not proprietary if you discover Pin 5 on header connector is to pin 3 on DB9: check pin 9 on header connector to pin 5 on DB9, it should be 0 ohms. Anything else is proprietary and will need further checking.
Note: Pin 1 on the dongle header connector always goes to Pin 1 on the DB9, no matter which type.
RS232 Motherboard header pinout ( AT/EVEREX )
IDC internal
(newer)
AT/EVEREX Signal Name Description
pin number
header pin cable pin
1 DCD Data Carrier Detect 1
2 RXD Receive Data 2
3 TXD Transmit Data 3
4 DTR Data Terminal Ready 4
5 GND System Ground 5
6 DSR Data Set Ready 6
7 RTS Request to Send 7
8 CTS Clear to Send 8
9 RI Ring Indicator 9
RS232 Motherboard header pinout ( DTK/INTEL )
IDC internal
(older)
DTK/INTEL Signal Name Description
pin number
Header pin cable pin
2 DSR Data Set Ready 6
3 RXD Receive Data 2
4 RTS Request to Send 7
5 TXD Transmit Data 3
6 CTS Clear to Send 8
7 DTR Data Terminal Ready 4
8 RI Ring Indicator 9
9 GND System Ground 5
Pin 10 removed in connector.
EDIT: added extra info and corrected my grammar
