First post, by murrayman
I know the short answer is Seasonic 300w, but bear with:
I have a PIII system (see sig) that I’ve been doing diagnostics on for two years now after a HDD failure. All parts have been swapped out short of the motherboard, and the issues were never resolved, so I now have an Asus P3B-F on the way. Along the way though, it was theorized the issues could have pertained to dirty power from the original AOpen 250w PSU. It’s possible that it may have been hit by lightning in early 2018 while plugged into a power strip that was switched off but not grounded, hence the failed HDD and anomalous issues since, so I’m worried what sort of damage might have been done, and don’t want to accidentally damage the Asus board when it arrives (I’m electrically illiterate, so don’t bite me if that’s not how things work 😀 ) So this system is number one priority at the moment to get a new PSU; even if the one I have is still good, it’s dated 1999, so it’s getting long in the tooth, and I don’t recap things.
However, I’ve got two other machines - one a PMMX, another a PII (see sig for both). The motherboards in each of these use the older two-plug setup that predates the 20-pin connector. They both have original PSUs and, while functioning, they are over twenty years old and won’t be recapped.
So what are my options here, if any? The only two restrictions I have (which are constraining, I know) are that the units have to be new - not NOS or old open box, they have to be recently manufactured and with caps of reputable quality - and that I don’t have to fabricate adapters of my own (willing to buy, not make). Also, what is the importance of hefty 5v supply with these systems? I’ve read that it’s really important on some older systems in other threads, especially Athlon XP rigs, but I haven’t been able to figure out why.
Asus P3B-F 1.04, PIII 1.0GHz, 512MB PC133, V5 5500 AGP, SB0160
Asus P3B-F 1.03, PIII 933, 384MB PC133, GeForce DDR 32MB, SB0100
CP 5170, PIII 500, 256MB PC100, DM3DII 12MB, ESS 1868
PB M S610, PMMX 233, 64MB PC100, DM3D 4MB, Sound4
Reply 1 of 11, by The Serpent Rider
The answer is the same. New ATX PSU (Seasonic, etc) with adapter. Many Athlon XP era motherboards were using 5v line to power CPU. That's why it's important to have better PSU on such system. That said, modern 400-450W PSU with 30A 5v should suffice for anything, outside of extreme overclocking (liquid nitrogen, etc).
Reply 2 of 11, by CharlieFoxtrot
I have Corsair CX450M 450W PSU in my Slot 1 system. CX450M has 110W combined for both 3.3V and 5V rails and max 20A for both. That should be fine for all PII and at least most PIII systems, but it won't be enough for most Atlhons or P4 computers.
Like Serpent Rider wrote, you need at least 30A or more for those. While most 300W PSUs of the era could deliver 30A for "minor" rails, modern PSUs are different and are designed to deliver most of their power to the 12V rail. There are very few if ANY new PSUs on the market that can deliver thise amps on the minor rails in lower end PSUs and for overclocked high end Socket A systems you practically need top of the line PSU. And even if low-end PSUs nominally can deliver 30A, they simply crash when both 3.3V and 5V have heavy loads. Modern PSUs simply are designed for very different systems and loads.
  • Celeron 300A@450 : 256MB : 80GB : DVD : Riva TNT : Voodoo2 : SB Live! : SB AWE64 Value
  • Compaq 425 : SB16 CT2290
  • Sun Ultra 60 : UltraSparcIIe 450 : 2xSun Creator3D : 2x36GB SCSI 10k
  • Digital DecPC 425SE Color
  • Compaq Armada 1700
Reply 4 of 11, by murrayman
Got it. Which Seasonic unit is the one most choose? All the ones I’ve found typically have 14A or 17A for the 5v rail, and the max I found was 20A for an older used model.
Similar question for DC-DC units: Google results showed most people talking about custom or industrial PSUs that only supply 12v and typically have a battery backup built within. I’m not familiar with these or even what’s implied here (very much a noob with electrical stuff), but they do state there are no units that split off into 5v or 3.3v. The point here for me is to avoid custom and purchase new or, at worst, a refurbished reliable PSU from someone else.
Reply 5 of 11, by The Serpent Rider
I didn't wrote that.
You don't need strong 5v rail on P4.
Reply 6 of 11, by red-ray
I feel the sensible option is to get a PSU that reports how much current is actually used. Below you can see my Dual P-III uses just over 18 amps @ +5 so I expect a 17 amp @+5 PSU would be fine for a single P-III system.
file.php?id=79081
The PSU I am using is good for 20 amps @ +5, see https://thermaltake.azureedge.net/pub/media/p … 7fbd038ec81.pdf
    48.8 KiB
    18 amps @ +5
Reply 7 of 11, by CharlieFoxtrot
The Serpent Rider wrote on 2020-03-18, 13:53:
I didn't wrote that. […]
True for both. I forgot that P4 indeed was pretty light for 5v unlike Athlons.
Reply 8 of 11, by Munx
FSP400-60GHN
Still in production, 23Amps on the 5V rail, 80+Bronze, costs less than 40 Euros.
When running a 1GHz Athlon system the 5V rail was still @ 4.97Volts.
My builds!
The Underdog - The budget K6
Reply 9 of 11, by murrayman
I’m seeing mixed stories online about FSP not being as quality as they once were. Substantiated or no?
Reply 10 of 11, by murrayman
Bumping this before committing to a purchase - finally ready to revive one of my rigs. There are no new or NOS FSP400-60GHN available to ship to my area that I can find online, and none of the newly manufactured Seasonic PSUs or competitors seem to have anything close to 30A for minor rails - typically just 14A or 17A. The consensus I've seen some places is that the Seasonic S12III SSR-500GB3 is a good choice. Still only 20A to the minor rails though. This will be powering the PIII 933 rig I have in my sig. Should this work for my setup?
Reply 11 of 11, by Horun
That Seasonic PSU should work just fine for a P3-933, am using a similar rated Antec with my P3-1Ghz.
