HWiNFO for DOS resurrected !
Reply 804 of 884, by roytam1
got "Fatal Error" when starting, DBG log:
VidMode=3
DispComb=8
HWiNFO v6.2.1
Flushing disk caches ...
Reading Data ...
DetectCPU - 586
CPUID=513
Check Cx
Cx[C2]=FF
Cx[C3]=FF
Cx[C0]=FF
Cx[C2]=FF
Cx[C3]=FF
Cx[C0]=FF
CxType=0
Check Potomac
Reply 805 of 884, by Mumak
roytam1 wrote on 2022-05-28, 14:09:
got "Fatal Error" when starting, DBG log: […]
VidMode=3
DispComb=8
HWiNFO v6.2.1
Reading Data ...
DetectCPU - 586
CPUID=513
Check Cx
Cx[C2]=FF
Cx[C3]=FF
Cx[C0]=FF
Cx[C2]=FF
Cx[C3]=FF
Cx[C0]=FF
CxType=0
Check Potomac
What CPU do you have and are you using the latest HWiNFO v6.21?
Reply 806 of 884, by roytam1
Mumak wrote on 2022-05-28, 14:15:
VidMode=3
DispComb=8
HWiNFO v6.2.1
Reading Data ...
DetectCPU - 586
CPUID=513
Check Cx
Cx[C2]=FF
Cx[C3]=FF
Cx[C0]=FF
Cx[C2]=FF
Cx[C3]=FF
Cx[C0]=FF
CxType=0
Check Potomac
tested on "Script PC" emulator, NSSI shows:
17.1 KiB
21.17 KiB
and yes I tested with 6.2.1. BTW hwinfo16 works.
Reply 807 of 884, by SteveC
Are you still interested in random reports? If so here's a ThinkPad 365X report and debug.
I've got a weird problem with a Toshiba Satellite 4000CDs where it acts like the last key you press is stuck down when in the application. I need to play with the machine more though to see if it's just a dodgy laptop!
    HWINFOTP.zip
    15.73 KiB
    51 downloads
Reply 808 of 884, by Mumak
SteveC wrote on 2022-06-24, 17:58:
Yes, still interested in any retro reports 😀 Thanks!
Reply 809 of 884, by RandomStranger
I have some issues with it here: https://gamesystemrequirements.com/user/rando … /devices/289361
CPU and RAM not detected.
Reply 810 of 884, by Mumak
RandomStranger wrote on 2022-09-09, 20:21:
Try the latest version of HWiNFO for DOS, not HWiNFO16 which is for 8086-286 only.
Reply 811 of 884, by SteveC
IBM PC 330 Model 466DX2 (486 DX/2 66MHz) DBG and LOG file
    IBM PC330 466DX2.zip
    7.14 KiB
    44 downloads
Reply 813 of 884, by werchter
Thanks for resurrecting HWinFO!
As someone who developed DOS programs myself, I was always really impressed by HWiNFO's great text interface (TUI), and always wondered how it was build.
I know that we can't expect HWinFO to become open source any time soon.... but are you willing to tell maybe something how you build the interface?
For example programming language it was developed in, and if it's completely custom build, or some kind of TUI library was used?
I think it can be super interesting for any developer working on TUI interfaces (even modern ones) to learn about how this classing programming was build!
Reply 814 of 884, by Mumak
werchter wrote on 2022-10-05, 16:28:
Thanks for resurrecting HWinFO! As someone who developed DOS programs myself, I was always really impressed by HWiNFO's great t […]
The interface is completely custom-built mostly using object-oriented C++, a bit of ASM. It wasn't that hard to create it.
Reply 815 of 884, by debs3759
Textual user interfaces are easy to create in C++ and asm. A complete windowing system is almost as easy. You just need to write it initially in pseudo code, and break it down to the smallest elements. I need to rewrite my own for my x86 OS 😀
Reply 816 of 884, by werchter
Mumak wrote on 2022-10-05, 16:45:
Thanks!
Yes, I writing a DOS interface is relatively uncomplicated, compared to for example cross platform nix* development with ncurses or similar frameworks.
I did some development with Turbo Vision in Borland's Pascal in '90s. Turbo Vision give great results as well, but is relatively complex, especially for straightforward use cases.
Anyway, great work @Mumak on the interface, especially for time period when it was initially released!
Reply 817 of 884, by Mumak
werchter wrote on 2022-10-05, 18:11:
Thanks! […]
Thanks!
Thanks. Some others (creating similar tool(s)) have copied a lot including several details and textual descriptions.. But I won't name them...
Reply 818 of 884, by kennyPENTIUMpowers
downloaded HWiNFO32.exe ..
it wont run, get an error
when i click on it (go to run it) in windows 95 on my p166 machine I get "Error Starting Program" "A required .DLL file, WININET.DLL, was not found"..
this new version doesnt work on win 95 4.00.950a
is there an old original version that does?
according to this page which lists wininet.dll versions the dll comes in the internet explorer package or the OS install (WIN(95OSR2 onwards).. https://www.geoffchappell.com/studies/windows … story/index.htm
wondering which version is necessary?
does this mean i have install Internet Explorer (ughh i dont want that crap on my system) .. or just the dll - which i have no idea where to get from and potentially opening up a can of worms as theres 11ty million different versions..?
ok ok so say i manage to find this missing dll, then what? where does it go? in the same folder as hwinfo32 or somewhere else like the windows folder?
ah retro computing... just as i remember it back in the day .. a complete headache
