some more shaders for SVN r4319 and later
First post, by Delfino Furioso
+++UPDATE 2020-05-22 : all converted crt shaders are now hosted on @tyrells git repo+++
+++UPDATE 2020-03-27 : thread title renamed as these shaders are not new, we're just adding svn compatibilty+++
Hi everyone!
since the introduction of shaders support in r4319 I've wanted to switch back to dosbox builds (such as ECE) that do not deviate much from the SVN forumula
what kept me from doing it was the limited choice of shaders - since only some are builtin and they mainly reimplement the scalers we are already used to
My knowledge of shaders programming is limited, but I wanted to try to port some of my favourite shaders anyway.
Turns out that I just needed to study the default shader coded within sdlmain.cpp and understand the variable being used.
Credits for all shaders go to the programmers whom created them back in the day
The code I've based my work on is hosted here
https://github.com/libretro/glsl-shaders/tree … ter/crt/shaders
Thanks to Dugan for his work on shipping the previous shaders support code with his fork (now unmantained)
https://github.com/duganchen/dosbox_shaders
Also thanks to Marty for tweaking Dugan's work and shipping earlier revisions of some of these shaders, back when SVN still did not support glsl
https://github.com/MartyShepard/DOSBox-Optionals
Reply 2 of 67, by Delfino Furioso
Hi and thank you!
I don't know if I will be able to do it, since it has some variables and coding conventions which are specific to how the libretro engine will load the shader.
Porting the dugan shaders was easier because they were already coded against the patch that SVN has merged with r4319
That's my understanding, anyway.
I'll try anyway and keep you posted about the results!
in the meantime, some screenshots of the EasyMode and Lottes shaders in action
https://imgur.com/a/pyDEm0w
https://imgur.com/a/4FipjSj
Reply 3 of 67, by tyrells
KainXVIII wrote on 2020-03-22, 07:26:
Great thread!
Can you port pixellate.glslp shader from retroarch? Dunno which difference between this and sharp shader, but i want to compare them..
Hi KainXVIII,
I have attempted a port of the Pixellate shader. It can be found here: https://github.com/tyrells/dosbox-svn-shaders. Would you be able to test it for me and see if it is working? Unfortunately I don't have enough experience with this shader to tell.
Reply 4 of 67, by KainXVIII
Thanks! Here are zoomed examples for comparing (from Conquest of Camelot), they looks slightly different, i don't even even know which is better 🤣
Sharp
4.04 KiB
No downloads
versus pixellate
4.21 KiB
No downloads
Reply 5 of 67, by Delfino Furioso
it seems to me that the pixellate example shows less color-bleeding
@tyrells - feel free to add my shader ports to your repo I've just forked your repo and created a pull request for including my ports
Reply 6 of 67, by KainXVIII
Uploading fullscreen shots where difference is less noticeable (maybe only in fonts), but yeah less color bleeding with pixellate!
115.4 KiB
Sharp
127.51 KiB
Pixellate shader
Reply 7 of 67, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I'm really puzzled. none of those work in plain SVN for me.
First it complains about the version not being supported
Error compiling shader: ERROR: 0:2: '' : version '330' is not supported
ERROR: 0:2: '' : syntax error: #version
and if I delete that line it complains about other things (e.g. with CRT-Lottes):
Error compiling shader: ERROR: 0:38: Incompatible types in initialization (and no available implicit conversion)
ERROR: 0:39: Incompatible types in initialization (and no available implicit conversion)
ERROR: 0:44: Invalid storage qualifiers 'out' in global variable context
ERROR: 0:52: Use of undeclared identifier 'scaleInLinearGamma'
ERROR: 0:61: Use of undeclared identifier 'scaleInLinearGamma'
ERROR: 0:72: Use of undeclared identifier 'scaleInLinearGamma'
ERROR: 0:81: Use of undeclared identifier 'scal
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 67, by tyrells
Dominus wrote on 2020-04-10, 08:21:
I'm really puzzled. none of those work in plain SVN for me. First it complains about the version not being supported Error comp […]
Hi @Dominus.
That's strange. What version of SVN are you using? I've only tested these in r4334, using the vanilla SVN build from Yesterplay80.
Reply 9 of 67, by Dominus
DOSBox Moderator
Jmarsh informed me on irc that the shaders are "compiled" in by the video driver of the system and apparently mine is missing support for these functions. This is on macOS 10.15, the latest and greatest (?), so definitely an issue with getting shaders to run on macOS.
SVN revision 4335, but it is not related to that 🙁
Reply 10 of 67, by tyrells
Dominus wrote on 2020-04-10, 16:27:
Thanks for the feedback. Some other systems (e.g. libretro) include specific #defines in the shaders to correctly handle multiple versions. I will look at refining these shaders to include this.
Reply 11 of 67, by Dominus
DOSBox Moderator
Thanks, that will help, especially when others do more work on shaders...
Reply 12 of 67, by tyrells
Dominus wrote on 2020-04-10, 17:14:
@Dominus, I've updated the shaders in the repository. Would you be able to test these new versions please?
Reply 13 of 67, by Dominus
DOSBox Moderator
All work now. The pp shader has a black border but I guess that is there to maintain aspect correction?
Thanks, that was fast!
now I want the xBR scalers etc 😀
Reply 14 of 67, by tyrells
Dominus wrote on 2020-04-10, 19:19:
Had some time, so added the 4 xBR shaders that don't require multiple shader passes. The others require multiple passes, and I'm not sure if that is currently supported by DOSBox SVN...
The shaders can be found in the 'xbr' sub-directory.
Reply 15 of 67, by almeath
All the xBR shaders are giving me this error, in macOS Mojave:
Error compiling shader: ERROR: 0:1: '' : version '130' is not supported
SDL:OPENGL:Failed to compile shader, falling back to default
DOSBox SVN for macOS (x86-64) - customized with Munt MT-32, Nuked OPL3, 3dfx Voodoo, Extra RAM, Large HD, and more.
https://github.com/almeath/DOSBox-SVN-64-bit-for-macOS
Reply 16 of 67, by almeath
And if I take out the version line:
Error compiling shader: ERROR: 0:211: Invalid call of undeclared identifier 'mat4x3'
ERROR: 0:212: Invalid call of undeclared identifier 'mat4x3'
ERROR: 0:213: Invalid call of undeclared identifier 'mat4x3'
ERROR: 0:214: Use of undeclared identifier 'b'
ERROR: 0:215: Use of undeclared identifier 'b'
ERROR: 0:216: Use of undeclared identifier 'c'
ERROR: 0:217: Use of undeclared identifier 'b'
ERROR: 0:218: Use of undeclared identifier 'c'
ERROR: 0:220: Invalid call of undeclared identifier 'mat4x3'
ERROR: 0
ERROR: 0
Reply 17 of 67, by Dominus
DOSBox Moderator
replace the version with 120 then they work. I don't notice an effect with the noblend or 3d one, though.
Reply 18 of 67, by almeath
Dominus wrote on 2020-04-12, 21:30:
Thanks, I am noticing the same thing. However, I am quite happy with CRT-Lottes for now. My wishlist includes CRT-Royale but there is no indication if SVN supports multi-pass filters?
Reply 19 of 67, by Diduz
tyrells wrote on 2020-04-10, 21:31:
Thanks for your work Tyrells, lottes and pp are much appreciated. 😀
As far as single pass shaders go, I'd suggest CRT-Geom: I've always liked that, because it's not particularly eye-straining and you can easily decrease the size of its output with the "overscan" parameter. One of the issues with other CRT shaders for me is getting gigantic 20+ inches "old monitors", when I remember my real old monitors around the 14-17 inches diagonal size. Of course Retroarch allows fiddling with overscan parameters, but getting that option in standalone Dosbox would be great.
