First post, by darry
Reading Seeking advice on Sound Canvas VA versus hardware (8820/D70) , I finally bit the bullet and bought a Japanese market SC-D70 . I will receive it eventually .
I have seen contradictory info on its actual voltage input capacity :
- The label on Japanese units says 100V
- The English language manual ( http://cdn.roland.com/assets/media/pdf/SC-D70_OM.pdf) on Roland's web site does not make it explicitly clear if the 120V, 230V or 240V units share the same PSU or not . The 100v Japanese version is not mentioned .
- SC-D70s on sale from Japan and targeting to North American customers are sometimes bundled with 120V to 100V step down transformers.
- koitsu asked Roland USA about this and was basically told that it should work with US mains power .
- The SC-D70 that I ordered was actually tested by the seller on different voltages . I quote : "This item works with AC 100-240V (universal voltage).It comes with Roland CD-ROM. It works perfectly. It's in very good condition.Item was tested on AC100V, and AC240V with step up AC transformer (converter)" .
Just to be safe, I ordered a step down transformer, a Kashimura TI-101, but shortly after ordering I saw some less than reassuring reviews about overheating and circuit tripping .
My questions :
a) Once I receive the unit, is there any way I can safely confirm whether it will safely run on 120V ?
b) Anybody have any experience on the Kashimura TI-101 or other step down transformers ?
Reply 1 of 39, by darry
Found the Japanese manual (http://lib.roland.co.jp/support/jp/manuals/re … 2/SC-D70_j3.pdf) . It only mentions 100 V and says
源プラグは、必ず AC100Vの電源コンセント
に差し込んでください。
which Google translates to
Make sure the power plug is a 100V AC power outlet.
Please plug it in.
Reply 3 of 39, by darry
imi wrote on 2020-04-19, 02:11:
I couldn't find a picture of the internals at the moment, but maybe you can bypass the internal power supply and just use a fitting external one
I have been considering doing that, I would just need to determine the required voltage . I would imagine/hope the PSU feeds a linear regulator on the mainboard and that everything runs on 5V downstream .
A service manual would be really nice .
If you do find some internal pictures, please post them .
Reply 4 of 39, by yawetaG
darry wrote on 2020-04-19, 02:40:
I have been considering doing that, I would just need to determine the required voltage . I would imagine/hope the PSU feeds a l […]
With some synths it's more complicated than that.
Anyway, most PSUs are rated for +/- 20% voltage. So it'll likely be fine on 120V.
You could also have a look at the PCB of the power supply to see whether it may indicate alternate arrangements of components for use in different countries (although Roland tends to use different PSU PCBs for each region).
Reply 5 of 39, by derSammler
yawetaG wrote on 2020-04-19, 09:14:
Yes, but that is because mains voltage is, too. In Germany for example, we have 230V mains. But it's allowed to go up to 253V for short moments. That's why any PSU must have such a tolerance. It does not allow you to generally use a mains voltage that is 20% higher by default. It would blow with the very first voltage peak, since in the US, up to 127V are allowed - and that is too much even with the +20%.
Reply 6 of 39, by imi
well, you're going to get one so that'll probably be easier ^^
I'm pretty sure the PSU is going to be seperate and the internal voltages are going to be generated with linear regulators.
Reply 7 of 39, by darry
imi wrote on 2020-04-19, 09:35:
I agree that it will be easy to get picture once I have it, but in view of the current situation with COVID-19 shipping delays, I was hoping to get ahead of the game in case I need to order anything I will need but do not have .
One thing that has not been commented on yet is the fact that the unit they are going to send me was apparently tested at 240V and did not blow up instantly . I do not know if I can reliably deduce anything from that .
Reply 8 of 39, by daikatana_
I have SC-D70 and there is no AC adaptor included, you'll get just a cable for a power socket. I bought an AC converter, where the output voltage is 110V and it runs fine so far.
Game MIDI soundtracks
Retro games and HW reviews
Reply 10 of 39, by darry
Just received it . Internal PSU looks to be the same as the one described and shown here :
https://www.eevblog.com/forum/repair/switch-m … -supply-107897/
down to the 250V fuse . Now correct me if I am wrong, but if the PSU only handled 100V, there would not be a 250v fuse, would there ? Also the fact that a Roland service note for another product describes it as 100v-240v would be a good indication .
Here are some photos of mine .
1.55 MiB
1.34 MiB
Reply 11 of 39, by derSammler
darry wrote on 2020-04-21, 18:48:
The fuse blows when the current limit is exceeded. The voltage of the fuse doesn't tell much about the mains voltage (only that it is certainly not higher than what the fused is rated for).
I wouldn't risk damaging the unit and just buy a transformer.
Reply 12 of 39, by imi
the model number of the transformer is not the same as in the EEVblog post, so I'd be careful.
is there a voltage rating on the primary side cap? I can't decipher any.
but it seems to be outputting multiple voltages, so just replacing it with an external brick is not going to work.
Reply 13 of 39, by derSammler
imi wrote on 2020-04-21, 19:32:
It's not the same PSU at all, just compare the components and layout. Only looks similar at a first glance.
Reply 14 of 39, by imi
well it's almost identical, so I'd assume it's just different revisions of the same board, seeing as it has the same model number, but they might very well be using the same board populated with different components.
Reply 16 of 39, by derSammler
imi wrote on 2020-04-21, 19:45:
The layout is different enough to assume that these are for different regions/voltages. The section to the right of the transformer T1 is just completely different in layout and components - and that is the primary side which runs from mains.
Reply 17 of 39, by darry
derSammler wrote on 2020-04-21, 20:07:
Probably safer to wait for the step down transformer, then . I just hop that the sender did not damage the PSU by testing it on 240v .
Reply 19 of 39, by SpeedySPCFan
All other Roland synths from this era use universal transformers (they had since 1999). You can ask Roland US for confirmation but I'd wager to say the SC-D70 is the same.
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
