Added Heroes of Might and Magic: A Strategic Quest (retail). The game installs and runs flawlessly out of the box, I don't even have to use Compatibility Settings.
No compatibility settings needed.
You can also use FRAPS to make screenshots.
The good old NWC logo.
Exploring the map.
But here's the catch: depending on what's shown on the screen, FRAPS doesn't always work. Also, sometimes you get the frame rate counter along with your captured screen. And sometimes, all you get is a blank screen with frame rate counter.
Hey, what is that little yellow number at the lower left of the sceen?
Red Book CD audio is fine though. I'm actually using CD image (as I always do), and all I need to to is to put the HOMM I CD image in the first CD drive letter of my virtual drives, and it works.
Had to photograph my computer screen because FRAPS doesn't always work, but I got CD audio indeed.
And I remember playing HOMM I on an actual Windows 95 PC, whose CD drive was physically connected to the sound card. I always failed to get CD audio working with HOMM I, so that the game always insists to use low quality audio. I also remember trying to play it on an early Windows XP laptop, somewhere in 2002, and CD audio didn't work either. Yet, CD audio works out of the box on my Windows 7 64-bit PC, as it does on a recent XP system of mine.
Why?
Kahenraz wrote on 2023-01-30, 07:51:
I bought a Nostromo N52 back on the day and I didn't like it at all. I recall the keys required a greater force to actuate than I was comfortable with in that orientation. I believe it's just a membrane with plastic caps sliding along a plastic column. There are no switches and it's just the two plastic surfaces rubbing against each other. Maybe it could be improved with some graphite powder, but I can't think of anything else to do.
I don't know if the actuation force would improve or worsen by breaking it in. Specifically, whether the plastic rubbing on plastic, which I think is mildly abrasive, creates micro plastic dust that acts as its own lubricant or if this somehow makes it worse. I never used the device in practice, and ended up throwing it out or giving it away.
Never experienced the problem you described. Indeed, it takes somewhat greater force to actuate the key, but it is barely noticeable, and it doesn't lessen with time and/or usage. Yes, there's nothing special with N52's keypresses, but nothing exactly bad either. As long as keypresses are concerned, the N52 feels like your ordinary keyboard.
Kreshna Aryaguna Nurzaman.
