Reply 20 of 28, by Cicada Lullaby
I used the normal installer. The audio only repeats in windows. When I load a dos game, the audio is fine
The card works, but now my audigy won't
I think I would have to use either the Isa card or the audigy, can't seem to use both without conflict
Here is the official PB driver from the PB ftp archive I have:
Hopefully the exe extracts. Not sure what all it contains as I haven't tried it.
EDIT:... this might not be the right one for your specific card. The old Europe PB support site says this is for the Rocky 2.5.
If it doesn't work, I'll upload the others as well.
See here for the list:
http://web.archive.org/web/20050209010924/htt … drv/cat127.html
cyclone3d wrote on 2020-05-09, 04:52:Here is the official PB driver from the PB ftp archive I have:
DISK1_1.zip
It is really great that you archived that ftp. Will you be uploading it to archive.org ?
darry wrote on 2020-05-09, 05:12:cyclone3d wrote on 2020-05-09, 04:52:Here is the official PB driver from the PB ftp archive I have:
DISK1_1.zipIt is really great that you archived that ftp. Will you be uploading it to archive.org ?
I didn't actually archive it. I downloaded it from the archive.org torrent end of last year:
https://archive.org/details/ftp.packardbell.com
cyclone3d wrote on 2020-05-09, 05:22:darry wrote on 2020-05-09, 05:12:cyclone3d wrote on 2020-05-09, 04:52:Here is the official PB driver from the PB ftp archive I have:
Wow, I never noticed it was there, 🤣!
cyclone3d wrote on 2020-05-09, 04:52:Here is the official PB driver from the PB ftp archive I have: Hopefully the exe extracts. Not sure what all it contains as I ha […]
DISK1_1.zipEDIT:... this might not be the right one for your specific card. The old Europe PB support site says this is for the Rocky 2.5.
Rocky 2.5 is a later card, iirc the MMSN855, based on the AZT2320 PnP chip. Given it requires PnP init where the AZT2316 doesn't I'd be surprised if it works, but more chance than the other way around...
What luck, I need I38-MMSN841 - is this pretty much the same? Which install file worked for you Cicada Lullaby?
Not sure what to install or get.
Thanks!
