Munt issue with Windows 10
Reply 80 of 82, by darry
slx wrote on 2022-01-05, 23:27:
Sadly, the munt does not find the dosbox after I restart the PC! I have to do the same method every time! My system is […]
My system is
Windows 10
Version: 21H2
OS Build: 19044.1415
I'm running the same build currently (got updated recently), but I had Munt previously installed. It still works fine for me after a reboot .
My version of Munt :
13.36 KiB
Reply 81 of 82, by sergm
Well, yes, there is definitely a problem with the device registry on this system, otherwise the installer would work. I suppose, dosbox is not the only MIDI app of interest, right? If yes, a build with the integrated mt32emu would be a better solution.
Reply 82 of 82, by slx
It means the problem is with my system!
Yes, I use the CoolSoft VirtualMIDISynth too for General MIDI musics (like the Betrayal at Krondor).
darry, I use the same MUNT as you do!
I started to use the old Taewoongs DosBox because there is an integrated MT32 emu in it.
!!!Thank you guys for your time and help!!!
