Reply 20 of 23, by Martin8bity
Robin4 wrote on 2021-08-30, 19:26:
I think iam going to use software first. Then i dont have to spend so much of money for nothing.
But maybe it is a last resort, if iam out of other options.
Sure, software may be the easiest. There is no need to spend a lot of money. Greaseweazle is cheap and you can even build it yourself with $10 BluePill STM32 board https://github.com/keirf/Greaseweazle/wiki/Blue-Pill-Direct.
Reply 21 of 23, by Robin4
Martin8bity wrote on 2021-08-30, 20:53:
Is that board for doing low-level on the floppy drive?
Reply 22 of 23, by Martin8bity
Robin4 wrote on 2021-08-30, 23:48:
It does all read/write on low-level, mostly it supports SPC flux level file format and conversions have to be done by other utilities.
