Reply 120 of 158, by appiah4
Joseph_Joestar wrote on 2020-12-15, 10:31:
appiah4 wrote on 2020-12-15, 10:27:
I was playing around with my beloved Dreamblaster X3MA and gave Hamtaro's Roland GM soundbank a spin, find the sample attached. It sounds better than I remember to be honest.
I hear a bunch of skipped / missing notes in that recording.
Is it just the audio file or does the X3 actually sound like that?
That's what happens when you try to record on a dual core laptop running a Bloomberg terminal at the same time. So yeah it's my recording error, I edit the post above with the re-recorded file.
Reply 121 of 158, by Joseph_Joestar
appiah4 wrote on 2020-12-15, 10:48:
Sounds great now. Cheers!
Reply 122 of 158, by appiah4
appiah4 wrote on 2020-12-11, 05:48:
Hummtaro wrote on 2020-12-02, 16:12:
I created an equalizer preset for Yucatan FX! I tried to get a more balanced sound and avoid any clipping for max quality. In ad […]
dreamblaster wrote on 2020-12-01, 18:21:
I see a new video by Phil, mentioning an issue with Descent music. So I also recorded Descent on chill pcb, without applying th […]
I see a new video by Phil, mentioning an issue with Descent music. So I also recorded Descent on chill pcb, without applying the volume fix.
It has quite deep bass, and high volume, but on my setup it does not sound as bad as on Phil's.
Phils video : https://youtu.be/6lTp1l8LYD0
My recording : descent_yucatanFX.mp3
If you have a low end soundcard, it is best to fiddle with mixer settings or the sysex file, as Phil recommends, to avoid distortion.
Any Yucatan/Cancun users can provide further advice ?
In addition, i added a 'Low' version for very sensitive soundcards.
It comes as Midi file you have to play before starting your game.
Hope it helps someone!
Yucatan FX Preset.zip
Yucatan FX Preset - Descent.mp3
This did not work for me, PLAYMID gets stuck when trying to play the MID. Celeron 1300 system, ES1868 sound card. PLAYMID is speed sensitive perhaps?
Ok so am I the only one with problems with this?
Reply 123 of 158, by dreamblaster
Remember Yucatan FX needs +12V so was not compatible with the 'normal' small CHiLL 'n Phil adapter (which had only 5V).
Today I tested the new CHiLL n Phil IV (with DC/DC option) with Yucatan Fx.
See it at work here with Yucatan Fx - hocus pocus : https://youtu.be/Zw8y8r37X5Q
    130.53 KiB
Thanks for your support !
Reply 124 of 158, by matze79
The Module only delivers 0.5W on + and -12V hm i guess some WT will draw more current, so its only for use with Yucatan ?
Reply 125 of 158, by dreamblaster
matze79 wrote on 2021-01-10, 15:44:
I would expect the +12V/-12V to be sufficient, but there is also a limitation in the 5V current a soundcard can deliver on the DB15 port.
I only tested with Yucatan now. I would expect other small waveblaster cards to work fine, but would advise caution with large, power hungry cards (like XR385)
Reply 126 of 158, by aleksej
dreamblaster wrote on 2021-01-10, 15:55:
This adapter designed to work with DB50XG which powered by gameport only. Additional DC-IN provided.
http://peratron.narod.ru/shop/peratron/WBA040MkIV.htm
Tested by mine on AWE32 and AWE64 Gold with various results on various exemplars - some cards deliver enough power for it some not.
Reply 127 of 158, by dreamblaster
Yucatan Fx demo by Jccwu : https://youtu.be/OjNdEe41HaU
(from Doom, Doom2, Duke 3D, Dune2)
Reply 128 of 158, by Hummtaro
appiah4 wrote on 2020-12-21, 14:28:
Have you got it running?
Has anyone else tested my presets in dos?
I've tested only in Falcosoft Midi Player..
X570|R5 5600X|32G|Rx6800
Reply 129 of 158, by appiah4
Hummtaro wrote on 2021-02-01, 09:50:
Have you got it running? […]
No I never resolved it and ended up dismantling that system. I will reinstall it on an ESS Solo-1 in an LGA775 board soon though, so we'll see how that one goes..
Reply 130 of 158, by Hummtaro
I've tested now in DosBox. PLAYMID.EXE seems to run fine!
Reply 131 of 158, by Rawit
I've been using Hummtaro's presets for some time under DOS 6.22 with PlayMid. It has worked for me with an ES1668. If I don't enable the MPU with the ESS tools, PlayMid hangs the system.
@Hummtaro: those presets are fantastic!
YouTube
Reply 132 of 158, by dreamblaster
Yucatan Fx Demo by PCSoundLegacy : https://youtu.be/5h085bDcMRI
Reply 133 of 158, by dreamblaster
Retired Yucatan Fx from the webshop.
Added to the museum page : https://www.serdashop.com/Museum
Reply 134 of 158, by Salient
dreamblaster wrote on 2021-07-11, 07:38:
That was quick... Glad I got one 😀
Reply 135 of 158, by appiah4
Not much point with X2GS nowadays but glad I got onw anyway, I like clones of actual older hardware.
Reply 137 of 158, by schlomoe99
Whelp. Time to list mine for on eBay as "Super custom sound module retro games gaming LGR Philscomputerlab **Rare!!1!** " for $999.99 on eBay call it a day! /s
Reply 139 of 158, by appiah4
cde wrote on 2021-07-18, 17:53:
I'm glad I got the Yucatan FX, I was wondering though, how different is the X2GS in terms of SC-55 fidelity?
Very similar. It has a near identical waveset but a rather (too) bassy mixer that can distort on some sound cards.
