Request for better texture pack management
Reply 43 of 57, by Gambit37
I've recently reinstalled Windows XP on a fully reformatted drive, and stupidly I didn't back up my Glidos folder before doing so. I lost my texture mapping file I was working on.
I've tried recreating it, but can't seem to get it to load the replacement textures. I've tried it with and without trailing slashes. I also have TextureOverride: Yes. What have I missed?
GLIDOS TEXTURE MAPPING
ROOT: F:\Projects\Tomb Raider Xtra\Hi Res Replacements\Override Folders\
// Title / main Menu
BASE: title\
E7504AFB7D3264410C74C2EA777AB1F3 E7504AFB7D3264410C74C2EA777AB1F3
EFE6179F82CA4471725D4532BC8AA60D EFE6179F82CA4471725D4532BC8AA60D
00AE19B7C0B2D045AE54A1683C076786 00AE19B7C0B2D045AE54A1683C076786
8F2FA7061AB2E84279F2292FDD537C46 8F2FA7061AB2E84279F2292FDD537C46
9DB0846B3F90F68744D01237BFCE59CB 9DB0846B3F90F68744D01237BFCE59CB
474C2C91326153751CC40C34817E6800 474C2C91326153751CC40C34817E6800
6018E6431FA65017D0F703FC8E60D589 6018E6431FA65017D0F703FC8E60D589
8880FD9B651C257778549A7EE7A2E450 8880FD9B651C257778549A7EE7A2E450
C1135A3AA842C8E3CDD2493E48CFAE7F C1135A3AA842C8E3CDD2493E48CFAE7F
// Level 1: The Caves
BASE: level01_Caves
198EC2D38EF00FEA1653750E8B237D7F 198EC2D38EF00FEA1653750E8B237D7F
203D6ED9632B742A2209637764C375F6 203D6ED9632B742A2209637764C375F6
54637C4BF0304439B63F51D3A5EEA382 54637C4BF0304439B63F51D3A5EEA382
60812F71A9287004111BA82EF2404371 60812F71A9287004111BA82EF2404371
708171E626AA342A07B8567EA8A1A53D 708171E626AA342A07B8567EA8A1A53D
C0B3E0125D1A1A0FF5DBBCA296F8AD4F C0B3E0125D1A1A0FF5DBBCA296F8AD4F
F7EB7D4BB45372D13AF34500AD82B217 F7EB7D4BB45372D13AF34500AD82B217
6C7FE41E229619C7ACDED8A8538E3F4E 6C7FE41E229619C7ACDED8A8538E3F4E
8B4825478FAB43844E3D4CB077E97613 8B4825478FAB43844E3D4CB077E97613
57A26AB453DED38FE830BB44A64A71F0 57A26AB453DED38FE830BB44A64A71F0
Here's my Tomb Raider Glidos settings:
Executable: C:\Tombraid\Tomb.exe
ExeSizes: 873739
DosGraphics: Yes
VESASupport: Yes
ControlJudderFix: 1
Resolution: 2
FullScreen: No
ForcedTextureSmoothing: Yes
Mp3BackgroundSounds: Yes
RedbookEmulation: Yes
Reply 47 of 57, by Gambit37
Messing a round with my texture management, I suddenly realised something that would make the whole thing a lot easier.
When you capture the textures using Glidos, it generates a file called complete.bmp. All the documentation on your site says to delete it as it's unused. However, isn't it possible to simply replace this texture with a high-res compound texture that's 1024x1024 and get Glidos to read bits and pieces of that instead? It would be sooooooooooooooooooooooo much easier to manage. We could forget about all the fiddly stuff and just make sure that every element gets updated on that one big tile....?
Here's hoping....!
Reply 49 of 57, by Gambit37
Did you see my post about the complete.bmp Paul?
I thought about this some more since I reordered my folders. I'm now using shared elements between each set of levels (Peru for example). This means that if you could somehow allow use of complete.bmp it would only really be useful for the sprite pages and not so much the wall/floor textures.
Reply 50 of 57, by Glidos
It would be difficult anyway. The texture override system sits between DOS Glidos and Windows Glide. Hence it can create textures no bigger than 256x256. I would have to break the 1024x1024 slab into 16 parts, and then if a texture straddled two, it would be quite nasty breaking some triangle renders into two parts. Not something I really fancy.
Reply 54 of 57, by Gambit37
I don't have the time right now to write a detailed "how to" post about the texture management that I'm using, but here's a quick break down.
1) Create a text file in C:\Program Files\Glidos\Textures called whatever you like. You don't even need any of the odd named folders in here, it can be empty except for the text file if you like
2) Edit your text file in Notepad. Here's the start of my one:
[code]
BASE: title\
00AE19B7C0B2D045AE54A1683C076786 bottom_left_corner
474C2C91326153751CC40C34817E6800 passport_01
6018E6431FA65017D0F703FC8E60D589 passport_02+mansion+menuring
8880FD9B651C257778549A7EE7A2E450 top_left_corner
8F2FA7061AB2E84279F2292FDD537C46 top_right_corner
9DB0846B3F90F68744D01237BFCE59CB bottom_middle
C1135A3AA842C8E3CDD2493E48CFAE7F bottom_right_corner
E7504AFB7D3264410C74C2EA777AB1F3 top_middle
EFE6179F82CA4471725D4532BC8AA60D letters_01
BASE: 01_Peru\level01_Caves\
198EC2D38EF00FEA1653750E8B237D7F surface_01(snow,rock,foliage)
203D6ED9632B742A2209637764C375F6 surface_02(calendar,skulls,foliage)
54637C4BF0304439B63F51D3A5EEA382 objects_01+lara
57A26AB453DED38FE830BB44A64A71F0 sprites_01+letters_01
60812F71A9287004111BA82EF2404371 surface_03(snow,brokenwalls,slot,switch)
6C7FE41E229619C7ACDED8A8538E3F4E objects_02+lara+pasport
708171E626AA342A07B8567EA8A1A53D objects_03+lara+bear+wolf
8B4825478FAB43844E3D4CB077E97613 objects_04+lara+passport
C0B3E0125D1A1A0FF5DBBCA296F8AD4F sprites_02+wolf+bear+brokenwall+letters_02
F7EB7D4BB45372D13AF34500AD82B217 surface_04(maya,brick,switch,rock)
[/code]
3) This file controls where Glidos looks for the data. It builds paths based on values used ROOT + BASE + ODD NAMED FOLDER MAPPING.
ROOT and BASE are pretty self explanatory. The ODD NAMED FOLDER MAPPING is simply the weird named folder that Glidos creates during capturing follwed by a space followed by a folder name of your choice (something sensible that matches its contents, for example)
So, if we take as our example, one of the passport images used on the main title screen:
BASE: title\
ODD NAMED FOLDER MAPPING: 474C2C91326153751CC40C34817E6800 passport_01
Anytime Glidos expects to find an image in folder 474C2C91326153751CC40C34817E6800, it will instead look in F:\Projects\Tomb Raider Xtra\Hi Res Replacements\Override Folders\title\passport_01.
There's one caveat: each time you redeclare BASE, relative paths will operate from the new path. In this way you can collect all data for a level together in one subfolder.
taking it a step further, you can collect mutiple levels together, as I have done (Peru for example).
And a further step beyond that, is to use link files to point to other folders where data common to all levels can be stored.
E.G, in my passport example above, I don't have any image files in that passport_01 folder, I use a linking text file, for example: (72--144)(0--96).PassportPhoto.txt. The contents of this file are:
TLNK: common\passport\passport-photo.png
The path in this file is relative to the ROOT path, it ignores the BASE path. So I put all the passport images in one place, and can link to them using TLNK files from *any* folder I choose. Same goes for any other common data. See the attached screenshot of my folder layout for this to make sense.
Additionally, for wall data, some of it is duplicated between levels. Usually I'll leave the PNG images in the mapped folders, but if the data is common to a numbed of levels, I'll put it in a shared folder outside the level folders. This helps reduce the amount of images needed and is one reason why I'm very keen to release levels in themed packs, all of Peru for example.
I hope that gives you some ideas of how to go about this...
    10.76 KiB
Reply 57 of 57, by Gambit37
*Cough*
Would it be possible to change Glidos so that it looks in any part of the filename of a texture or mapping file for the coordinates? At the moment, you can add comments in the filename by putting it after the last bracket, but you can't put a comment before the first bracket.
It would be a lot easier to manage if the comments were viewable first, so that one can re-order an explorer window by name, rather than coordinates.
Is this possible at all?
