Reply 20 of 52, by subnet_zero
dreamblaster wrote on 2021-02-02, 22:50:
mini usb through hole version, is very solid as opposed to a micro usb which i ripped off in a prototype, during testing. so yea […]
subnet_zero wrote on 2021-02-02, 22:31:
Quite impressive. Is there a reason why you use a mini-usb connector, like you did with the x2? 🤔 ....I better stock up those cables.
so yeah, because i like it, and you can give these old cables a new life 😀
Sold! 😎 This connector has its own retro vibes.
Reply 23 of 52, by imi
USB-C is available in through hole 😉
funnily enough mini-usb are the only USB connectors that ever broke on me, but those indeed did so multiple times, those weren't through hole though, so I'm sure it'll be fine ^^
Reply 24 of 52, by appiah4
imi wrote on 2021-02-04, 04:10:
USB-C cables are absolutely unnecessary for this kind of application. They are also an extra cost to most people. I have a million micro and mini USB cables lying about and I don't mind using them for these.
Also, we once discussed this with Serge and he persuaded me with one very simple and solid argument: Mini USB cables are A LOT LESS prone to getting detached by accident compared to Mini USB or USB-C. Once you plug them in, they are there for good.
Reply 25 of 52, by dreamblaster
okay i decided for 2022, to go for it, i will start release my higher end dream based boards..
Thanks for your support !
Reply 26 of 52, by S95Sedan
Dont know where these are made for specifically.
Arent your outputs suppose to sit on the wavetable connector side? (same with the X5)
This because if it were to be used in an older soundcard the connectors will be right against the sockets which seems like a design-flaw.
Reply 27 of 52, by RetroGamer4Ever
S95Sedan wrote on 2022-01-23, 21:23:
One design is apparently intended for use as an external module with casing and the other design is for Waveblaster header soundcard connection, with the option to use as an external module in case.
Reply 29 of 52, by dreamblaster
yes still working on firmware, right now even
Reply 30 of 52, by RetroGamer4Ever
The end of the year is upon us. You've obviously been up to something, cause you've recently posted a photo or two of the prototype Dreamblaster designs that you're testing, so what can we expect in 2023?
Reply 31 of 52, by dreamblaster
RetroGamer4Ever wrote on 2022-12-01, 22:28:
You can expect release of X16, I hope to finalize it during xmas holidays,
and release begin 2023.
The first batch will be ready soon, but still some software work.
Reply 32 of 52, by dreamblaster
Resuming X16 development
    262.88 KiB
Reply 36 of 52, by SuperDeadite
I like the look, now waiting for the sounds. Also, maybe a weird request, but I would love if X16 had its own waveblaster header to mount an additional module, then software to control which channels go to each device. Korg NS5R (NX5R) has this ability and its a lot of fun to play with.
Modules: CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster
Reply 38 of 52, by dreamblaster
SuperDeadite wrote on 2022-12-26, 11:27:
that would be a different project, i have been thinking about this : 'waveblaster mixer', to combine mutiple board and chose which channels
but i doubt if anyone really would be interested, and which form factor, how many cards to support,..
Reply 39 of 52, by dreamblaster
Bootloader is basically working now, it allows to update soundbanks and firmware.
Thanks to Hummtaro for the help !
The software now supports multiple bank slots and switching between these.
X16GS will contain the dream/roland GS bank (same as X2GS) and also other banks.
You can switch between banks using midi commands, or using the dip switches :
Dip switch functions :
1234
0000 - Stay in Bootloader (allows firmware update)
x001 - Bank 1
x010 - Bank 2
x011 - Bank 3
x100 - Bank 4
x101 - Bank 5
x110 - Bank 6
x111 - Bank 7
we are finalizing the project, it may take a few more weeks to release.
I will keep you informed on progress
