Windows 3.1 in 256 colours
Reply 42 of 93, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
In order to be able to use the SVGA drivers from W3.11 in DOSBOX, you must patch them to be VESA compatible.
Go to:
http://japheth.de/dwnload1.html
And download the file SVGAPtch.ZIP (run the program on SVGA driver and it will work in DOSBOX).
If nothing helps - and if you did all you wrote - well, your copy of Windows is probably corrupted... Since it works for other people...
Mirek
Reply 44 of 93, by iamthejake2000
mirekluza wrote:
In order to be able to use the SVGA drivers from W3.11 in DOSBOX, you must patch them to be VESA compatible. Go to: http://japhe […]
Go to:
Mirek
aah thanks a lot! works like a charm. but is there a way to get windows 3.1 to run in enhanced mode? thanks.
OldDoom.com, my Doom (1 & 2) site.
Reply 46 of 93, by iamthejake2000
i guess it must be something in my autoexec.bat or config.sys files. i did a fresh install of windows and everything's fine. i've been trying to get into enhanced mode on a setup from a hard drive from a very old computer of mine. i'll mess with the boot files, thanks for all your help!
Reply 47 of 93, by Dominus
DOSBox Moderator
ah, probably more likely something botched in your system.ini or win.ini (since DosBox doesn't read and execute the boot files (autoexec.bat/config.sys) unless you are booting from an hdd image). If those had some drivers loaded for 32-bit disk and/or file access this would explain a lot. Just compare those two files to your working windows and comment things out (with 😉 until it works 😀
I got my old setup (with Norton Desktop and such things) pretty fast into working order that way.
Reply 49 of 93, by Plan9FOS
Just a Collection of Win 3.1 video driver sites:
S3:
http://ranger.s3graphics.com/swlib/?license=accept
http://ranger.s3graphics.com/swlib/764drv/
SVGA.exe:
http://oldfiles.org.uk/powerload/win3x.htm (and Windows 3.11 Update for 3.1)
http://www.winsite.com/bin/Info?500000024307
SVGA VESA Patch:
http://www.japheth.de/dwnload1.html
SciTech SDD + UniVBE + SNAP:
http://www.scitechsoft.com/ftp/sdd/
http://www.scitechsoft.com/ftp/snap/
http://arcadecontrols.com/arcade_downloads.shtml#Drivers
Reply 50 of 93, by Radinor
I have a problem with running win 3.1 in 256 color mode:
When it runs in 256 color mode and I start scrolling down a window, dosbox freezes for a moment then it closes. I have this problem in surface and direct3d mode too, and so far I've only encountered it in gulikoza's dosbox. How can I fix this?
Reply 55 of 93, by Dominus
DOSBox Moderator
It'd be nice to know with whic program that happens.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 56 of 93, by Radinor
I've tried some other things like: mounting a different directory as drive C: and installing win 3.1 there, then putting the S3 driver on it, because I thought that maybe something is wrong with the current windows install, but that didn't work. I even tried using the XGA driver and the Paradise card driver, but that didn't work either.
In dosbox.conf, the video memory is set to 2 MB and the system memory is set to 8 MB. I tried turning them up a bit (sys mem: 16 MB, vid mem: 10 MB), but that didn't work either.
And the strange thing is that, it only happens if I use the scrollbar to scroll down, if I use the down arrow key, there's no problem.
Reply 58 of 93, by kenny120
A screen shot of Windows 3.1 running in Dosbox
[/img]
    27.67 KiB
All that we are .............. â–’DB V.72 for
Is all that you'd love to beâ–’WIN XP
All that we know.............â–’DB V.65 for
Is hate and machinery.....▒Linux Xandros Φ
We're engineers
Gary Numan - The Pleasure Principle
Reply 59 of 93, by Dominus
DOSBox Moderator
oooooooooookay.... a little late in the game 😀
