First post, by mpe
Just got this motherboard
TS-486 Terminator or SMT4321-22A.
I found some resources here, but sadly there is no description of jumpers.
Before I pick multimeter and start figuring out the settings I wondered if someone has a manual or better doc.
Blog|NexGen 586|S4
Reply 3 of 10, by Deksor
I think unless someone finds a manual (maybe evasive has something in his HDD ?) You'll have to retro engineer it ...
First of all, I think the jumper right above the CPU controls the voltage as the vrm is right next to it.
Next the three jumpers next to the CPU on the opposite side must be controlling the fsb and finally it the big chunk of jumpers must control the CPU settings.
The rest must be controlling the cache.
Some more competent folks may be able to help you to figure out the CPU settings. (For the CPU voltage you can probably check the settings with the CPU removed and a multimeter)
Reply 5 of 10, by computerguy08
I managed to find this manual (from elhvb.com). I enhanced it a little bit, so it's more readable:
TS-486_enhanced.pdf
1.06 MiB
140 downloads
Reply 6 of 10, by Deksor
Added to our website
227.82 KiB
(can't wait to release this to public ! )
By the way can you please dump your bios ? It may be a different rev than the one available online.
Reply 7 of 10, by evasive
there's at least two variants, one with the ali5119 I/O and one with an SMC I/O chip, yet to be identified. Do NOT just flash any bios on this board before checking what I/O chip you have or you may need to reflash it externally.
Reply 9 of 10, by evasive
Deksor wrote on 2020-07-24, 22:44:
Yeah that gift that keeps on giving... I downloaded a lot of stuff over the years it seems...
