ATI Windows 9x DDC/EDID override
Reply 20 of 26, by bloodem
swaaye wrote on 2021-06-28, 19:42:
Oh the funs. 😀
Maybe I will do some experimentation. Which NV card are you using?
Sorry, missed your reply 😀
Any nVIDIA card behaves the same (with my monitor) when I install a driver version newer than 30.82.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 21 of 26, by swaaye
bloodem wrote on 2021-07-04, 10:30:
Ok I installed a 5200 Ultra in my current nforce2 Win98 setup and installed driver 45.23. Connected to VGA. On first start-up with the driver, I have a maximum resolution of 1920x1080. So I went in and unchecked the detect PNP monitor box and rebooted. After reboot I now have a maximum resolution of 2048x1536 and one step below that is 1920x1440. The monitor won't display 2048x1536 but 1920x1440 does work. This also brings in 1600x1200 which my monitor doesn't define as supported in its EDID for some crazy reason.
My monitor is a BenQ BL3200PT which is a 1440p panel.
121.33 KiB
Something you could try is removing the EDID pin from a VGA cable and seeing what kind of behavior that brings.
Reply 22 of 26, by bloodem
swaaye wrote on 2021-07-06, 20:54:
Thanks, swaaye. Tested again on mine, followed the exact same steps as you, but... same result. Seems that newer nVIDIA drivers really hate my AOC Q3279VWFD8 monitor. Somehow they don't want to let go of the 1920x1080 max resolution, even when disabling automatic plug & play monitor detection.
Good idea, will definitly try it, since I have a lot of VGA cables lying around.
Reply 23 of 26, by chrismeyer6
I've coated the EDID pin on a cable in the past with some clear nail polish it worked great and I didn't have to ruin a good cable. You just need to clean the pin with some acetone when your done quick and easy.
Reply 24 of 26, by bloodem
chrismeyer6 wrote on 2021-07-08, 21:28:
Awesome idea, chrismeyer6! Thanks a lot to both you and swaaye! 😀
I've just tested it, and nail polish actually worked like a charm. I can finally use 1600 x 1200 with driver 4x.xx and newer! 😁
Since now I know for sure that it works, I will go ahead and destroy one of my many VGA cables by removing the EDID pin (nail polish is nice for testing purposes, but since I constantly test systems/video cards, it might peel off eventually & get stuck inside a video card connector (which, of course, will surely be an expensive/rare video card 😁 ).
