First post, by Arn
I'm back with a new problem 😉 My problem is that my joystick isn't working properly..
I'm running with a Logitech Wingman Digital Extreme, with the latest drivers. Win XP. Through the gaming port. Therefor I cannot use the Wingman Profiler and have to use the windows built in controller settings.
The problem isn't that the game don't find any joystick, cause it does. Also when I'm configurating the controls, I can assign a button to an action by pressing it, though not configurate the axis..
And then when I play. The axis isn't working but all the buttons! Wierd?
In the controller settings, the axis are assigned to different actions, so if it would detect any impulses from the joystick, something would happen!
I'm also running VDMSound, and I've tried it with 4axis/4but, 2ax/2but and without emulation but it won't work..
Also, the axis works in windows, but not in any game 🙁
Anyone know how to fix this? Thanks in advance 😁
