First post, by brutzler
Hi,
installed actual DOSBox (0.74-3) on a new W10x64-computer.
My very old DOS-Software is working so far. I was even successfull to get access to an external serial module over an USB-serial-Converter.
But the software needs to get access to a printer. It needs to print out on LPT1.
The host computer has no LPT1. There is only a USB-printer connected to the computer.
I already did some configuration on the host, that I can print out to LPT1 from the host:
- Shared the printer with the name 'dosprinter'
- and "net use LPT1 \\pc-name\dosprinter"
But how to route the LPT1 from DosBox to the host?
In the conf-file i only found a section for the configuration of the serial ports, but nothing for parallel ports 🙁
Any hints appreciated.
/brutzler
Reply 1 of 3, by JosSchaars
First check if the printer accepts (DOS) ASCII data streams. Only a matrix or laser printer will. Inkjet printers generally are GDI only and won’t accept the text/data your program sends.
Then see if your program can be set to print to a file. If so, set the name to LPT1.
Reply 2 of 3, by _Rob
DOSBox does not support non-gaming programs, and does not really support printing.
You want a DOSBox fork with printer support. In the past there was a "dosbox megabuild" and "dosbox daum", but those are no longer maintained.
Maintained DOSBox forks/derivatives with printing support
- DOSBox-X
- vDos
- vDos Plus.
