First post, by brutzler
installed actual DOSBox (0.74-3) on a new W10x64-computer.
My very old DOS-Software is working so far. I was even successfull to get access to an external serial module over an USB-serial-Converter.
But the software needs to get access to a printer. It needs to print out on LPT1.
The host computer has no LPT1. There is only a USB-printer connected to the computer.
I already did some configuration on the host, that I can print out to LPT1 from the host:
- Shared the printer with the name 'dosprinter'
- and "net use LPT1 \\pc-name\dosprinter"
But how to route the LPT1 from DosBox to the host?
In the conf-file i only found a section for the configuration of the serial ports, but nothing for parallel ports 🙁
Any hints appreciated.
/brutzler
