First post, by Predator99
I will take the Sigrok-EGA project...
6€ MCE2VGA replacement - CGA/EGA/HGC capture with logic analyzer
...as opportunity to test, sort and show my collection of EGA cards and provide the BIOS images (around 20 in total I think)
Everybody is welcome to contribute, please use the proposed format.
But please no discussion here to keep readability...post questions/comments here:
BIOS image collection - requests, discussion etc
+++Discussions here please to keep readability
Reply 2 of 26, by Predator99
Manufacturer/Identifier: Thomson Renaissance
Chipset:
BIOS-String: Version 1.00 IBM COMPATIBLE.*EGA BIOS V1.6 COPYRIGHT Award Software Inc.
Status: Card is working
1.29 MiB
1.21 MiB
EGA-Thomson Renaissance - F.rar
8.23 KiB
143 downloads
Reply 3 of 26, by Predator99
Manufacturer/Identifier: Pardise Autoswitch EGA2
Chipset:
BIOS-String: IBM COMPATIBILITY 0COPYRIGHT PARADISE SYSTEMS, INC. 1986 PEGA BIOS
1.14 MiB
1.13 MiB
EGA-Pardise Autoswitch EGA2.rar
9.73 KiB
149 downloads
Reply 4 of 26, by Predator99
Manufacturer/Identifier: D2A62LVEGA Video 7 VEGA
Chipset:
BIOS-String: Note: Some code expects "IBM" here!w<VEGA BIOS Code, Version 1.08 èN Ë(C) Copyright 1985,1986 Video-7 Inc., All Rights Reserved. Updated: 05/21/87
1.29 MiB
1.05 MiB
EGA-D2A62LVEGA-Video 7 VEGA-B.rar
8.43 KiB
138 downloads
Reply 5 of 26, by Predator99
Manufacturer/Identifier: AST 3G Plus
Chipset:
BIOS-String: IBM is mentioned for compatibility only. (C)Copyright 1985 Interlink Business Network Corp. V1.27 (C)Copyright 1987 AST Research, Inc. V2.023 All Rights Reserved
1.08 MiB
1.6 MiB
EGA-AST-3G Plus - B.rar
8.95 KiB
123 downloads
Reply 6 of 26, by Predator99
Manufacturer/Identifier: TSENG EVA/480 ET-2000
Chipset:
BIOS-String: [This is not a product of IBM (IBM is a trademark of International Business Machines Corp.)ëY * Copyright(c)1986 Tseng Laboratories, Inc. 07/28/86 V1.xx*
TSENG EVA/480 ET-2000 EGA / NEC GB-1 COLOR GRAPHICS BOARD
1.06 MiB
1.34 MiB
EGA ET2000.rar
11.39 KiB
134 downloads
Reply 7 of 26, by Predator99
Chipset:
BIOS-String: IBM is mentioned for compatibility only. (C)Copyright 1985 Interlink Business Network Corp. V1.27 (C)Copyright 1985 AST Research, Inc. V2.022 All Rights Reserved
Status: Card is working, also with IC missing compared to #4
1.02 MiB
1.2 MiB
EGA-AST-3G Plus2.rar
8.91 KiB
118 downloads
Reply 8 of 26, by Predator99
Manufacturer/Identifier: IBM EGA
Chipset:
BIOS-String: 48/31/94891 MBI THGIRYPOC)C( 65377260042(
Status: Not working, starts to smell. BIOS read with TL866
803.47 KiB
1.03 MiB
EGA-IBM EGA.rar
8.44 KiB
125 downloads
Reply 9 of 26, by Predator99
Chipset:
BIOS-String:
Status: PC boots but no display - wrong jumper setting?
1.07 MiB
1.11 MiB
ATI 16899-0 EGA Wonder VIP - F-VIPC000.rar
16.65 KiB
132 downloads
Reply 10 of 26, by Predator99
Chipset:
BIOS-String:
1.34 MiB
1.5 MiB
EGA - CT-8090.rar
7.98 KiB
120 downloads
Reply 11 of 26, by Predator99
Manufacturer/Identifier: Genoa SUPEREGA FCC ID FB85EW4880
Chipset:
BIOS-String:
https://arvutimuuseum.ee/th99/v/E-H/54061.htm
1.16 MiB
1.26 MiB
14.91 KiB
EGA - Genoa.rar
12.45 KiB
140 downloads
Reply 12 of 26, by Predator99
Chipset:
BIOS-String:
1.02 MiB
1.09 MiB
14.37 KiB
EGA-CT P82C431.rar
7.5 KiB
121 downloads
Reply 13 of 26, by Predator99
Chipset:
BIOS-String:
1.12 MiB
1.06 MiB
EGA-HP 45983-60001.rar
8.87 KiB
129 downloads
Reply 14 of 26, by Predator99
Chipset:
BIOS-String:
991.61 KiB
1.04 MiB
9.22 KiB
EGA-Spegasync.rar
9.13 KiB
140 downloads
Reply 15 of 26, by Predator99
Chipset:
BIOS-String:
1.03 MiB
1007.35 KiB
17.44 KiB
EGA-CT P82C435.rar
11.12 KiB
120 downloads
Reply 16 of 26, by kdr
Manufacturer/Identifier: SPEGASYNC-00
Chipset: Chips & Technologies CS8240 (82C43x)
BIOS-String:
IBM EGA COMPATIBLE.*UNISYS ENHANCED GRAPHICS CONTROLLER  VERSION 1.30
(C)Copyright Sigma Designs, Inc 1985,1986
Status: Working at 4.77Mhz
860.21 KiB
Front of SPEGASYNC-00 card
905.02 KiB
Rear of SPEGASYNC-00 card
Jumpers/Switches are the same as on a genuine IBM EGA card:
SW1-4: configuration switches
P1: configure pin 2 of video connector to be GND (for CGA monitors) or RS (for EGA monitors)
P2: light pen connector
P3: configure EGA for I/O port 3x0 or 2x0 [but BIOS doesn't have support for cards at 2x0]
Notes:
Card does not work in a Turbo XT system at 10Mhz (but it's fine at 4.77Mhz). Apparently neither the ROM nor the RAM chips (120ns) are fast enough.
Haven't bothered to test the serial port.
ROM is 16KB, labelled "UN 1.30".
The L1A2334 chip is a custom Sigma Designs gate array that implements the 'glue logic' and the hardware portion of the Sigma CGA emulation.
    SPEGASYNC.ZIP
    9.4 KiB
    117 downloads
    ROM dump of SPEGASYNC-00 card (UN 1.30)
Reply 17 of 26, by kdr
Manufacturer/Identifier: ERGO480
Chipset: Chips & Technologies CS8240 (82C43x) + Sigma Designs L1A2334
BIOS-String:
IBM EGA COMPATIBLE.*UNISYS EVC V 1.60
Status: Bad RAM chip (U6) on M3D0-M3D3 (low 4 bits of plane #3), freezes system during POST
Status: appears to be working, requires multisync TTL display @ 31.25khz (or possibly even higher)
845.09 KiB
Front of ERGO480 card
741.3 KiB
Detail shot of ROM socket and ROM chip
930.07 KiB
Rear of ERGO480 card
Jumpers/Switches are similar as on a genuine IBM EGA card:
SW1-4: configuration switches (somewhat similar to the IBM EGA switches I think?)
SW5: enable CGA hardware emulation? (When ON, shorts the light pen switch input to GND.)
Oscillators:
28.500Mhz (CLKSEL=00)
32.000Mhz (CLKSEL=01)
'SPARE OSC' (CLKSEL=10)
EGA feature connector (CLKSEL=11)
Video BIOS uses CRTC register F9 to program an extra divide-by-2 stage so that the card is able to generate standard 15.7khz / 21.8khz modes from the high-speed oscillators.
Notes:
Card fails to POST, error beep is long-short-short-short, and then the system freezes/fails to boot.
ROM is 32KB, no label on the chip. Card only decodes C000-C3FF (16KB).
Hidden underneath the ROM socket (!!) is a PAL16L8 device that responds to I/O writes at port 03CBh and switches between the upper and lower 16KB banks.
The L1A2334 chip is a custom Sigma Designs gate array that implements the 'glue logic' and the hardware portion of the Sigma CGA emulation. This chip has some kind of emulation control register at 03DCh.
SW1 is stuck in 'OFF' position so I rigged up a jumper wire for it.
    ERGO480.ZIP
    15.44 KiB
    118 downloads
    ROM dump of ERGO480 card (V1.60)
Reply 18 of 26, by kdr
Manufacturer/Identifier: NEL ELECTRONICS / "ULTIMATE EGA+++"
Chipset: "UDL" C3 (8737KK)
BIOS-String: NEL INTERNATIONAL 1987 IBM EGA COMPATIBLE SMART BIOS 5.93 11/17/87
Status: working in XT systems at 4.77Mhz and 8Mhz, display corruption at 10Mhz
Oscillators: 16.257Mhz and 27.648Mhz
296.66 KiB
Card had 120ns memory installed. I tried 100ns memory, but the card is still unstable when running the bus at 10Mhz. Writes to display RAM are fine, but reads often fail to return valid data = corruption when scrolling etc. I suspect it's actually the ASIC that can't keep up with the 10Mhz bus.
No datasheet or other documentation appears to exist for the "UDL" series of chips. There are sure to be some "Super EGA" modes available (given the 27.648Mhz oscillator on the board) but no idea how to access them or what kind of display they might require.
    ULTIMATE_EGA.ZIP
    8.92 KiB
    123 downloads
    Dump of ULTIMATE EGA+++ video BIOS
Reply 19 of 26, by mogwaay
Hi there,
Sorry to bomb this thread, but in the interests of digital preservation, I thought I'd add an EGA card I was working on last night to the list incase anyone is looking for ROMs.
Manufacturer/Identifier: Juko ST (NEL Electronics)
Chipset: UDL C3
BIOS-String: NEL INTERNATIONAL 1989 IBM EGA COMPATIBLE BIOS 6.04 09-09-90
Status: Unknown - haven't got it tested yet...
Jumpers/Switches: again, not tested, but I think it's similar to the NEL/Juko Ultimate EGA: https://arvutimuuseum.ee/th99/v/I-L/50064.htm
522.62 KiB
Back of card
693.2 KiB
Front of card
Juko_ST_BIOS_M5M27C128_DIP28.BIN.zip
9.15 KiB
120 downloads
Dump of BIOS ROM
Interesting how the ROM is labeled Juko ST, which appers to be a motherboard BIOS (Juko XT Super Turbo I think) but the contents of the ROM does appear to be a Video Bios extension. Also a later version than on this thread and here EGA Card Restoration Attempt.
