First post, by adalbert
Here is a list of some open-source hardware projects (with schematics, PCB files, firmware, etc. so you can build them or modify them by yourself)
I will try to update that list with new projects linked in this thread.
Sound cards thread: The comprehensive list of all modern reproductions of vintage sound cards
SD card to LPT: MicroProject - MicroSD to LPT Printer Port
Sergey's Projects http://www.malinov.com/Home/sergeys-projects
PS/2 to serial adapter PS/2 to Microsoft Serialmouse Adapter Converter / Updated First Post / Firmware Update added
https://github.com/matze79/PS2-Adapter/
MicroATX Turbo XT Motherboard NuXT - MicroATX Turbo XT Motherboard - 9.55MHz, UMBs, XT-CF, SVGA, HD Floppy, Serial
https://github.com/monotech/NuXT
Parallel Port Headphone DAC Replicas of Covox Speech Thing, FTL Sound Adapter and SiliconSoft SoundJr
https://github.com/roybaer/parallel_port_headphone_dac
Turbo display Re: Fabricating a New Turbo Display
PS/2 to RS-232 Serial mouse protocol converter by sklawz with PIC16F628a microcontroller: PS/2 to Serial Mouse protocol converter
site: https://wiki.kewl.org/dokuwiki/projects:pcpointer
Alexandru Groza's website:
PC Chips M919 Cache Module Clone: PC CHIPS M919 Cache Module Clones
site: https://easyeda.com/jerryt74332/m919-cache-completed_copy
Throwback Operator - OPL3 hardware VGM player (sort-of PC hardware): https://github.com/AidanHockey5/Throwback_Operator
WavePi - Raspberry Pi MIDI synth: WavePi: Use Raspberry pi (2/3/4) as a AIO MIDI synth
site: https://github.com/t9999clint/WavePi
MT32-Pi MIDI Hat: https://github.com/chris-jh/mt32-pi-midi-hat
UpLateGeek's 30-pin 4MB SIMMs: https://github.com/UpLateGeek/Let-s-Make-Some-Memories
HardMPU HardMPU, anyone?
Amiga/C64/8-bit Stuff:
wiretap's projects:
Various projects listed by RayeR: http://rayer.g6.cz/hardware/retrohw.htm (also includes some non-open projects)
MDA/CGA/EGA to VGA https://sites.google.com/site/tandycocoloco/m … -cga-ega-to-vga
Currently I listed links found mostly by wiretap, Thermalwrong, ALEKS, RayeR and myself. TODO: probably needs creating some categories.
Repair videos: https://youtu.be/T6mXM1tA7pA
Reply 3 of 34, by Thermalwrong
Alexandru Groza's website: The gerber files aren't currently shared but schematics are there and the write-ups on his experiences with each project are a great read:
HardMPU is an excellent example, I was able to build my own working HardMPU boards from ab0tj's schematic.
There's a schematic and working code, there are examples of it working. It seems to have gone a bit quiet though.
Reply 4 of 34, by ALEKS
I wasn't aware that my projects present such interest.
I updated the web pages and included the Gerber files for the designs that I tested and deemed as working.
PS: You might want to modify the links as I moved some pages. Also I think the audio interface card is missing from the list above.
Thanks,
80386DX / 40 MHz | 32 Mb RAM | Tseng Labs ET4000/W32i with 2 Mb RAM | ISA I/O Interface | ISA Audio Interface | 3.5" & 5.25" FDD | 4 x 512 Mb CF | Intel EtherExpress 16
Reply 5 of 34, by weedeewee
ALEKS wrote on 2021-03-16, 07:28:
I wasn't aware that my projects present such interest. I updated the web pages and included the Gerber files for the designs tha […]
Thanks,
Looking through the pages on your website... it seems you also have some incorrect links from moving the pages around 😀
Very interesting works you're doing there !
Also, from reading your ISA I/O interface page. Was the problem of it not working on a pentium cpu with cache enabled solely due to a bad chip or chip incompatibility, kinda confused on that.
Reply 6 of 34, by ALEKS
Thanks for the broken links hint. I corrected them already.
Regarding why the floppy disk drive controller does not work whith my test system with a P233MMX CPU, I don't know the root cause, yet.
Debugging this kind of issues is very time consuming. I do have access to the test equippment required for observing the timing diagrams at a hardware level but I don't see myself doing that in the close future since I have lots of other priorities already. I am keeping this kind of investigation project for one of those cold winter days...
Good thing is that the floppy controller works with slower CPUs (286/386). I haven't tested with 486 since I don't have one around.
Also good to know is that all the other functions of the I/O interface work as expected. I am using 4 CF cards (primary: 2 Gb / 512 Mb; secondary: 4 Gb / 256 Mb) with Windows 98 with this controller and I can get sustained write rates of 1.2 MB/sec. Onboard ROM BIOS is disabled and Windows takes over with its own software INT 13h implementation for the secondary controller. I'd say this controller exceeded my initial expectations.
Cheers,
Reply 7 of 34, by wiretap
Here's a few small projects I made:
Ninjamicro FreeSpeed AMD Goldfinger Clone:
Re: Making an AMD "goldfinger" clone ?
2-digit Turbo MHz Display:
EGA Feature Connector 120-column and 132-column Adapters:
[Super EGA-120] PC Magazine Volume 5 Number 15 Project
Asus P2B-DS Rev 1.06 FSB Modification Adapter:
Not a PCB project, but rather how to easily convert a Pentium Pro Shuttle HOT-613 Single CPU to Dual CPU:
WORKING Shuttle HOT-613 (Single to Dual - Pentium Pro)
AWE64 SIMMconn files I converted from the original, with BOM/JEDECs:
Re: Simmconn AWE64 Adapter
Circuit Board Repair Manuals
My Project List
Reply 9 of 34, by wiretap
Need to make this thread a sticky.
Hoglet's RGB2HDMI: https://github.com/hoglet67/RGBtoHDMI
Bloodmosher's Amiga 2000 RGB2HDMI: https://github.com/Bloodmosher/Amiga-VideoSlot-RGBtoHDMI
Claude's Pi-Storm Amiga Accelerator: https://github.com/captain-amygdala/pistorm (latest Altium source, gerbers & BOM is in the Discord, or group buy there for about $12)
LIV2's 2MB Chip RAM for Amiga 500/2000: https://github.com/LIV2/A500-2Meg-Chip-ram
LIV2's 8MB Fast RAM for Amiga 500/2000: https://github.com/LIV2/GottaGoFastRAM
Floppie209's Amiga 2000 PCB Remake: https://github.com/Floppie209/Amiga2000-remake
Chucky's ReAmiga 1200 PCB: http://www.reamiga.info/?page_id=38
Chucky's ReAmiga 3000 PCB: http://www.reamiga.info/?page_id=40
Chucky's Amiga 4000 Replica PCB: https://github.com/ChuckyGang/A4000RevB
My Project List
Reply 10 of 34, by Tiido
My SIMMs are not open-source, or at least I have not knowingly made any resources publicly available 🤣
I do think it is a good idea to make this thread a sticky ~
Reply 12 of 34, by Stiletto
wiretap wrote on 2021-03-21, 12:33:
Tiido wrote on 2021-03-21, 12:55:
Okay, done - just remember that VOGONS (including Marvin) is so full of quality threads that it would be very easy to fill Marvin -> General Old Hardware's first page with stickies - and then some 😉
do the Fandango!" - Queen
Stiletto
Reply 14 of 34, by RayeR
Interesting, I was asking mods for such thread last year because there are various interesting community HW projects but they are shattered over the forum and outside on author's webises and nobody replied me. So I put my personal list of interesting projects I have found (mostly for me and friends)
It would be good if adalbert can collect this thread links and will keep them updated in top post as it will grow to multiple pages...
Gigabyte GA-P67-DS3-B3, Core i7-2600K @4,5GHz, 4GB DDR3, 128GB SSD, GTX670(GF7900GT), SB Audigy + YMF724F + DreamBlaster combo
Reply 15 of 34, by adalbert
RayeR wrote on 2021-04-03, 16:50:
I collected all of the links in the first post, I will try to improve the list a bit later (maybe make some categories, etc). I also included a link to your website: http://rayer.g6.cz/hardware/retrohw.htm, though not all of the projects seem to be open-source. I would like to mostly include projects that allow everyone to contribute, make improvements and modifications etc. But maybe another category for "non-open" community projects would also be OK.
Reply 16 of 34, by hyoenmadan
https://twitter.com/Toble_Miner/status/1341029666254180352
Isn't retro per se... But this may interest people who would want a bit more reliable and faster storage than using standard SDcards. I've also read these are more resistant to write wearing, but don't know... eMMC on board driven nettops seem to die fast because storage kicking.
Reply 17 of 34, by wiretap
hyoenmadan wrote on 2021-04-05, 22:26:
I don't see a source anywhere for that. Is it a closed project or can the gerber files be downloaded somewhere?
My Project List
Reply 18 of 34, by RayeR
eMMCs are mostly used as internal storage of mobile phones. Similar to SD cards theirs quality depens widely on manufacturer but generally should be better...
