First post, by Nexxen
Hello everybody!
I have this motherboard and after a few years (≃20) I wanted to find out what happened to my motherboard.
After a BIOS update to the last version the motherboard stopped POSTing after pressing the power button, I have to press the reset button to actually have it POST.
From that point on it works perfectly without issues and has no random freezes/reboots/instabilities.
Any ideas?
(I'll be posting pics and whatnots)
Edit: http://www.win3x.org/uh19/motherboard/show/6048
Nothing else in the world smells like that.
I love the smell of burnt components in the morning.
Reply 1 of 12, by Nexxen
Motherboard pictures.
    175.34 KiB
    740.52 KiB
Reply 2 of 12, by Horun
Do you know if the flasher updated the BIOS Boot Block (usually they are not updated BUT some BIOS updates require it) ? Did you load BIOS "Setup Defaults" after flashing ?
Which BIOS did you flash it too ? You probably should put a battery in it....
Reply 3 of 12, by Nexxen
Horun wrote on 2020-10-03, 22:53:
Hey!
Board is in storage, so no battery left in the socket.
I updated the bios like 15+ years ago (at least), I don't remember what I did that time 😀
I could reflash the bios as I wouldn't damage it.
Reply 5 of 12, by Deksor
I have uploaded your photos here : http://www.win3x.org/uh19/motherboard/show/6048
Moreover, we have uploaded all the bioses we could find for your board 😀
alternative
Reply 6 of 12, by W.x.
Please, just a question. Does have this version Explorer IV Speedeasy BIOS menu? I don't see any jumpers for setting up multiplier and FSB speed.
Strangly, on PCB, there are markings for setting jumpers, and even 75 FSB speed. Here, 75 FSB speed is not among listed http://www.win3x.org/uh19/motherboard/show/6048
Reply 7 of 12, by Doornkaat
W.x. wrote on 2021-02-22, 23:48:
The corresponding jumpers are in the lower left corner in the picture.
The manual even shows the setting for 83MHz FSB.
The chipset only officially supports up to 66MHz FSB and does not offer dividers for higher speeds so maybe that's why the avaliable FSB settings aren't listed as supported on win3x.org even though they're listed in the manual?
Reply 8 of 12, by PARKE
Doornkaat wrote on 2021-02-23, 02:59:
According to this Anandtech article busspeeds of 68, 75, 83.3 MHz are 'unofficially achieved'.
https://www.anandtech.com/show/72/7
With this particular board, who knows...
Reply 9 of 12, by Nexxen
PARKE wrote on 2021-02-23, 13:10:
According to this Anandtech article busspeeds of 68, 75, 83.3 MHz are 'unofficially achieved'. https://www.anandtech.com/show/7 […]
That means pc-100 ram, but my specific model can't boot with pc-100 ram no matter he density and rows.
I might try again in the future with different cpus.
Reply 10 of 12, by PARKE
PC100 SDRAM should theoretically be backwards compatible but there was a lot of variation in quality in the early days.
Maybe it is a BIOS issue ? I used to have this exact board in the past and as far as I remember (not 100% sure though) it worked with both pc66 and pc100 sticks.
422.36 KiB
Reply 11 of 12, by Nexxen
PARKE wrote on 2021-02-24, 12:37:
Maybe it is a BIOS issue ? I used to have this exact board in the past and as far as I remember (not 100% sure though) it worked with both pc66 and pc100 sticks.QDI.JPG
This w/e I'm going to try out all my pc-100 sticks and see what works.
Try different fsb options.
Pity the bios chip is soldered, will have to reflash by hand - TL866 is spoiling me 😀
