Reply 20 of 31, by Hoping
A few days ago I did "a total conversion" from ATX to AT by unsoldering the cables from the inside of the AT power supply and the ATX, and soldering them on the ATX, main switch included. Also pass the ATX board to the AT case.
So far so good, the change is not noticeable.
Reply 22 of 31, by 386SX
Even if I got a couple of good AT psu that works ok, I'm using an Enermax 2003 ATX one that has the -5V line because I might have been unlucky but I've got a 386 mainboard that seems to need that or maybe the whole config prefers having that. Strangest things happened to me without that voltage rail like the vga output slowly fading to black, random crashes etc.. I think the best solution might be a good modern one with old molex connector but has been tested from serious reviewer for retro components, then adding the ATX to AT adapter and possibly with a well built -5V line mod. But lately I was also thinking to a Pico PSU and adding the adapters/mod.
Reply 23 of 31, by bloodem
alfer wrote on 2020-09-25, 20:19:
I do want to put a YMF71x card in my MMX at some point and heard that it requires -5V.
Definitely not true. I constantly use YMF71x cards with newer PSUs that don't have -5V and never had any issues.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 24 of 31, by chinny22
bloodem wrote on 2020-09-28, 11:27:
Actually your right!
I've got a YM F719 and thought, oh didn't realise they required -5v, should keep that in mind.
Accept that Socket 8 PC already has a Corsair RM550x
Reply 25 of 31, by shamino
pentiumspeed wrote on 2020-09-26, 15:02:
Shamino, […]
Shamino,
Please show me photo of the Compaq server power supply, the label and another photo of the motherboard connectors please. That's three photos.
Compaq server power supply is what I'm look out for.
Cheers,
I came across it recently, sorry it took so long to post photos.
Maybe I should have just replied with a PM but the forum only lets me attach 1 picture if I do it that way.
This is from a Proliant 800 with an LPX dual Pentium Pro 440FX motherboard.
Since the "P5" connector might be something unusual I showed a closeup of it. I can probably hook it up and check voltages on those pins if you need that info.
So people are saying that the common smaller size is LPX?
That's ironic because this PSU came from an LPX case. It's not a fat cube like the previously shown Baby AT but it's not the "normal" size.
All my Baby AT cases use LPX, but my LPX case doesn't.
Reply 26 of 31, by pentiumspeed
What is not pictured is the front panel of power button and LED, please take pictures so I can help you set it up so you can switch it on or off.
Standard AT 2 connectors are standard on this and PSU came from both Proliant 800 (Pentium Pro dual socket using LPX motherboard, basically cheap server) and Prosignia 200.
The other connector is for LED status signal through to the front panel with switch, and extra power wires for 3.3v, power signal one of wire should turn PSU on, active low by grounding, other one is push button signal from front panel with LED through the PSU back into motherboard, just like you do with ATX but odd). 280W is not much for a server but perfect for your other projects and PSU is standard mounting holes too.
"Prosignia" is just a catch all brand starting from low end 386sx computer, home computers, to some odd between mid computer and low end server.
Proliant 800:
https://youtu.be/qF5vvVwhMxU
Prosignia 200:
http://mastodonpc.tripod.com/personal/4055.html
Picture of Prosignia 200 motherboard in detail on ebay.
https://www.ebay.com/itm/Compaq-Prosignia-200 … UIAAOSw3INfCr2Y
Cheers,
Great Northern aka Canada.
Reply 27 of 31, by Horun
shamino wrote on 2020-10-20, 01:32:
I came across it recently, sorry it took so long to post photos. Maybe I should have just replied with a PM but the forum only l […]
Nice ! That is a great example of a "specialty PSU". Has AT connectors and voltages but also 3.3v too plus the special ATX connector.
Thanks for sharing!
Reply 28 of 31, by pentiumspeed
Prosignia 200 with wirings installed in detail with motherboard visible:
https://articulo.mercadolibre.com.ar/MLA-7519 … age-antiguo-_JM
Reply 29 of 31, by shamino
pentiumspeed wrote on 2020-10-20, 02:04:
Sorry for being so unresponsive, I'm in the middle of moving and pretty distracted. 😀
I did get a picture of the wires going into the power switch and LEDs, attaching it here.
The switch is mechanically latching, so I think it's just a matter of shorting those terminals to turn it on.
I have a Proliant 800 which is where this PSU is from. I've been going back and forth about whether to keep it or throw it out. It's hard to justify keeping big cases that are proprietary and can only be used for one system which I hardly ever use. It's a Pentium Pro though, so it's hard to get myself to throw it out either. I'm inclined to keep it if I can.
If I can't, then I guess I'll keep the PSU regardless but since it's oversize I'd only be able to use it in an open air testbench type situation.
I never heard of the Prosignia line before. Funny how much it looks like the same machine but the motherboard is definitely different. From appearance I'm guessing they are the same chassis.
I haven't used the Proliant 800 in years. Last time I used it, I remember thinking the PSU was dying, but I would need to revisit that with fresh eyes. I *think* I was getting an overheat warning on the POST screen. I don't remember if the phraseology was pointing at the PSU or if I had some other reason to think the PSU was an issue.
I might have beat up the PSU by installing dual 512KB CPUs. It came with a single 256K and I don't think the 512s were officially supported.
Reply 30 of 31, by shamino
I have 3 "normal" size AT PSUs. 2 of them are from reputable brands. This is the 3rd, most questionable one. Heatsinks are tiny which explains how light it is.
The label calls it a 250W but the PCB is marked "CWT 200PA" which seems to imply a 200W design.
Maybe "Data Well" is a brand owned by "Channel Well" who actually made the PSU, but that's just a guess.
I've had this since buying it at a local computer parts store back around the turn of the century. I didn't have high standards back then.
I have no problem with replacing caps, but if the underlying design is still a firecracker then there's no point. Any opinions on whether this is worth keeping or should just be thrown out? The most important question is how likely this thing is to cause hardware damage.
90.98 KiB
685.64 KiB
739.69 KiB
631.49 KiB
638.03 KiB
Reply 31 of 31, by DAVE86
shamino wrote on 2020-10-28, 11:22:
I have 3 "normal" size AT PSUs. 2 of them are from reputable brands. This is the 3rd, most questionable one. Heatsinks are ti […]
This is a really skinny CWT. With that 28 size main transformer it's about 150W max output. A few transistors forming a sensing/comparator for short circuit and overvoltage maybe (Around Q5, Q6 with resistors around them ).
Good for testing HDDs maybe or junk mobos if nothing else is around.
