First post, by darry
This is meant to "chronicle" my experience with the Roland VS-880EX . Hopefully, this might be useful to someone else .
I have long (5 years or so) used an Akai DPS-12 multi-track recorder as a mixer for my various sound cards and sound modules . Having run some tests, I have noticed what appears to be low frequency self-noise that peaks at around -60dB in the sub 140Hz range on all the DPS-12's analogue inputs (see Re: Noisy AWE64 recording from any input (line in, EMU8000 MIDI, etc) + upcoming AWE64 comparison if interested), so being the perfectionist that I am, I decided that it might be good idea to finally get a modern, affordable, mixer with a digital (S/PDIF) output (needed for connection to my audio video receiver).
I initially found nothing with S/PDIF output in any sane price range, so I extended my search to vintage multi-track recorders and noticed the Roland VS range . Specifically, I found a nice looking VS-880EX in Japan that looked like it had everything that I was looking for at a decent price . Unfortunately, I only realized when I received it that it did not include the adapter required to mount an internal 2.5mm" IDE hard drive (which I planned to replace with an IDE to CF card reader anyway). Without the said adapter and IDE drive or a SCSI drive, the unit is useless. Luckily, I was able to locate said adapter and order it (see Re: Bought these (retro) hardware today for details).
While waiting for my adapter to arrive, I decided to do some research on the VS-880EX on vsplanet.com . There, I found some info regarding a way to hook up an IDE drive or an IDE to CF directly to to the mainboard. It seems that the mainboard connector has a 50-pin IDC connector that looks like it should be SCSI but is, in fact, a very strange IDE port . The first 44 pins of this connector apparently carry the same signals as a 44-pin IDE connector ( see http://www.vsplanet.com/ubbthreads/ubbthreads … &Number=1005650) . So, being the impatient type, I decided to hook up a 50-pin IDC cable to the mainboard and connect its first 40-pins to an IDE to CF converter using a makeshift gender-changer. I initially powered it externally, but I soon realized that the IDE to CF adapter was somehow being powered from the VS-880EX (possibly through pin 20 of the "IDE" cable ?).
Then, the fun started . I had multiple CF card and two different types of microSD to CF adapters, so surely something would work . Well, yes, but not what I expected . In all cases the IDE to CF adapter was a Startech unit . EDIT : I also tested some SATA SSDs through a JMicron JM20330 IDE to SATA bridge .
a) Kingston 16GB CF card : VS-880EX freezes at boot
b) Sandisk 4GB and 2GB cards : VS-880EX freezes at boot (even setting fixed disk bit on the 2GB card changed nothing)
c) INIC-2051 based microSD to CF card reader (tried with multiple microSD cards 8GB, 16GB and 32 GB) : VS-880EX lets me try to format, but errors out.
d) FC-1307 based microSD to CF card reader (tried with multiple microSD cards 8GB, 16GB and 32 GB) : VS-880EX successfully formats card, but wants to re-format on every boot .
e) Nikon 8MB (not a typo) CF card : VS-880EX successfully formats card and works, even after reboot (would not want to record on it, but for a mixer it's fine).
f) Verbatim 128MB (not a typo) CF card : VS-880EX successfully formats card and works, even after reboot (would not want to record on it, but for a mixer it's fine).
g)Kingston A400 120GB (likely Phison S11 based, did not disassemble it) : has the same behaviour as the Sandisk CF cards, the Verbatim 2GB CF card and the Kingston 16GB CF card (freezes at boot) .
h)Kingston KC600 256GB (Silicon Motion SM2259) : has the same behaviour as the Sandisk CF cards, the Verbatim 2GB CF card and the Kingston 16GB CF card (freezes at boot) .
i) HP S700 250GB (Silicon Motion SM2258XT) : has the same behaviour as the Sandisk CF cards, the Verbatim 2GB CF card and the Kingston 16GB CF card (freezes at boot) .
j) Adata SU655 120GB (Maxiotek/Maxio (JMicron spin-off) MAS0902A-B2C ) : has the same behaviour as the Sandisk CF cards, the Verbatim 2GB CF card and the Kingston 16GB CF card (freezes at boot) .
k) Samsung 860 EVO 500GB (Samsung custom controller) : reaches formatting screen, but I do not want to format . Would probably work .
l) Kingston HyperX 240GB SHFS37A/240G (SandForce SF-2281 based) : reaches formatting screen, but I do not want to format . Would probably work .
My guess is that the issues have something to do with drive size (not the issue) (VS-880EX cannot use more than 4GB anyway). Consequently, I ordered some 2GB microSD cards and a 2GB CF card . I should be able to test those tomorrow . I also got a message that my original Roland IDE adapter is on its way and should be here within 3 days or so, so I will not be needing to "Frankenstein" it much longer with that 50-pin cable and gender changer .
If there was a way to force an SD or CF card to return a lower capacity than actual, it would probably make my life easier (any suggestions ?).
EDIT: The behaviour with Sandisk cards is obviously more likely an incompatibility than an issue with size.
EDIT2: Updated tested list .
EDIT3: Corrections
EDIT4: Updated tested list .
Reply 1 of 38, by Shreddoc
darry wrote on 2020-10-04, 04:38:
I don't know the specifics, but judging from the existence of the old scam industry based around hacked cards misreporting their size, I am guessing this won't be too difficult....
Reply 2 of 38, by Jo22
Shreddoc wrote on 2020-10-04, 06:17:
I have similar issues with an old Pentium with GA586S mainboard and a CF adapter in a removable IDE drive bay.
Most if not all CF cards tested fail to be recognized by the BIOS, except for a 512MB CF card which works fine.
The other cards are NOT fake, though. They work as intended in USB card readers and digital cameras. I can only guess what's "wrong" with them. 5v tolerance? ATA spec too new? Don't support True-IDE mode? Hm. 🤨
Edit: The other cards tested are between 8MB (no typo) and 8GB.
Reply 3 of 38, by Shreddoc
Jo22 wrote on 2020-10-04, 12:00:
I have similar issues with an old Pentium with GA586S mainboard and a CF adapter in a removable IDE drive bay. Most if not all C […]
Or possibly, the device being fussy about the formatting / partition table / MBR - this can happen even with PCs and certain cards/formattings. E.g. my latest card would only boot my DOS machine after I first prepared it with Rufus/FreeDOS. Any other common format or partition method would fail to boot properly with that card in that machine. But once it was done I could then partition and format the card however I wanted, using the machine itself, and it was then fine forevermore.
Overall, the various CF specification revisions, multiplied by the various reader/device firmwares, multiplied by the various formats and partition setups that a card can assume, means there are many possible vagary combinations, so I am not surprised that it is common for people to find incompatibilities.
Reply 4 of 38, by darry
I have an explanation for the VX-880EX always wanting to re-format the FC-1307 based adapters . It's not the VS-880EX's fault or an incompatibility, it's the adapters themselves !
Using Windows 10, if I only create a 1GB or more 1GB FAT16 partitions on an FC-1307 adapted microSDHC card, at power-cycle (unplug and re-plug USB to CF adapter), the partitions are wiped!
If I create an NTFS partition, say 9GB in size and then a 1GB FAT16 partition, no wiping occurs .
If I create an an unformated partition, say 9GB in size and then a 1GB FAT16 partition, the wiping occurs .
If I create a either a FAT32 or NTFS partition that spans the entire card, no wiping occurs .
I have the same behaviour with 2 different FC-1307 based microSDHC to CF adapters and with all card sizes I have tried (8GB,16GB,32GB). I have owned those adapters for several years, so they might just have old buggy firmware .
Maybe they will work OK with the 2GB cards that I have on the way .
Reply 5 of 38, by darry
I just received a 2GB Verbatim CF card and a pack of 5 generic 2GB microSD cards .
The 2GB Verbatim CF card behaves like the Sandisk cards (freezes at boot).
The generic microSD cards behave like all the other cards in the FC-1307 based adapters I have .
<RANT> Why does this have to be so complicated ? I can't keep buying adapters and cards left and right hoping that something will work . I am getting really close to trying an IDE to SATA adapter along with a SATA SSD in that thing </RANT> .
EDIT : The 2GB microSD card I used tests out fine with h2testw.exe .
Reply 6 of 38, by Shreddoc
The fussy behaviour I noted above with my setups, was also using an FC-1307 controller based adapter.
I guess you just need to find something that works, then stick with that combination.
Low quality flash cards (e.g. from AE) can also complicate matters, so it may be best to avoid those.
Reply 7 of 38, by darry
Shreddoc wrote on 2020-10-04, 23:29:
The microSDXC card I tried with the FC-1307 were an 8GB Kingston, 16GB Sandisk and 32GB Verbatim . The Sandisk was from Amazon.ca and the 2 others were purchased at reputable retail stores, so unlikely to all be counterfeits .
Having researched this a bit, it seems that FC-1307 partition wiping behaviour is not uncommon :
https://askubuntu.com/questions/1252233/shutd … r-clean-install
https://www.amazon.ca/Optimal-Shop-Digital-Ad … customerReviews (DarkGalXE's comment)
The tests that I have run seem to indicate the issue is related to the partitioning scheme used. Additionally, I have confirmed that as long as the adapter is not power cycled (i.e. powered externally), no wiping occurs, which is consistent with what is reported in the referenced links . If this was ever fixed in a firmware update is unknown to me and even if it was, it's not like firmware version is usually advertised on these things .
I would love to try something that works, preferably a CF to SD/microSD adapter or an IDE (44 or 40-pin) to SD/microSD, but nearly everything uses an FC-1307 or something undisclosed (probably an FC-1307 anyway). The only alternative I have seen is an INIC-2051 based adapter and that one is completely incompatible .
My reason for preferring an SD/microSD adapter is parts availability (CF is pretty niche at this point), but I would probably settle for a stack of 3 or 4 compatible CF cards of 2GB-4GB or more (large size does not seem to be an issue) for use and as spares .
Reply 8 of 38, by darry
I dug up an old SD to SATA adapter in my junk pile. It uses an Fc1306T (no idea if this is related to the FC-1307) for the SD to IDE conversion and a Sunplus chip for the IDE to SATA conversion (performance was terrible, around 7MB/sec max sustained, AFAICR). I also happened to have a spare Jmicron JM20330 IDE to SATA converter handy . I decided to combine the two and see what happens .
So, starting from the VS-880EX :
IDE to SATA (using Jmicron JM20330)
SATA to IDE (using a Sunplus chip)
IDE to SDcard (using FC1306T) .
Obviously, I powered this thing unholy monstrosity externally (I did not want to find out how much current a wire in an IDC cable can carry).
AND IT WORKED !!! It formatted properly and no disk wiping occurred on full power down/power up .
This gave me hope that an to IDE to SATA bridge would work with an actual SSD . So I ordered a 44-pin IDE to SATA adapter (SinLoon) and an ADATA 120GB SSD . I will be able to test it easily on external power and, once my Roland disk adapter/caddy arrives, I should be able to power it internally and, if everything works, actually use the VS-880EX .
This has actually been way more painful than getting the Akai DPS12 working . Ironically, the VS-880EX is newer .
Reply 9 of 38, by Shreddoc
Yes the SD adapters seem to all be the same fundamental design; a design which is not very broadly compatible with different card configurations and partitionings.
The SATA->IDE converters are likely to be based on more robust design standards, thereby enabling greater compatibility.
Reply 10 of 38, by darry
Shreddoc wrote on 2020-10-05, 01:14:
SD to CF using the FC-1307 is definitely wonky in certain scenarios . Why it even cares about partitions is a mystery to me .
PCs may not be as picky regarding CF card compatibility, but I feel that I made the right choice forgoing CF and especially SD converted to CF in my retro builds . When CF media finally disappears from the market and people start experimenting more with SD converted to CF, they are going to be in for a world of hurt unless either non buggy FC-1307 implementation become a thing or more reliable alternatives appear. Neither of those scenarios seems likely, IMHO .
Reply 11 of 38, by Tiido
I am very very slowly working on an ISA+VLB IO card that can definitely use SATA, USB mass storage and probably SD cards too (and drive emulation), with bus mastering for maximum performance, it would put the end to this sort of storage problem. Alas time and money are low, other commitments must come first...
Reply 12 of 38, by darry
Tiido wrote on 2020-10-05, 01:43:
That sounds like it would be really useful in the long term, especially if its ISA support includes 8-bit mode for XT class machines. It could be a one-size fits all storage solution for anything pre-PCI, which would be a fantastic thing to have . I hope time and finances allow you to pursue this eventually .
Reply 13 of 38, by darry
I have had second thoughts on that Adata SU655 that I ordered . It is apparently prone to overheating and I cannot find a disclosed power draw for it . I guess I will end up using as a testing device or spare . I ordered an a Kingston A400 120GB that has a max power draw (0.195W Idle / 0.279W Avg / 0.642W (MAX) Read / 1.535W (MAX) Write , according to https://www.kingston.com/us/ssd/a400-solid-state-drive ) that's actually less than half that of some the officially recommended 2.5mm" IDE hard drives (3.5W) for the Roland VS family . So even with an IDE to SATA converter, I should not be taxing the VS-880EX's power delivery abilities .
EDIT : With a max of 4GB usable on the VS-880EX and an endurance of 40TBW on the SSD, I should be good for filling up that VS-880EX about 10240 times . If I did that once a day, I should be good for about 28 years . Considering that I mainly intend to use this as mixer, there should be no immediate concerns about endurance . I do wonder a bit about lack of TRIM, though .
EDIT2: Considering the bandwidth limitations of the VS-880EX, even if lack of TRIM eventually leads to slower max throughput to the drive, it will likely be unnoticeable in this use case .
Reply 14 of 38, by darry
Another day, another surprise . The Adata SU655 120GB SATA SSD, when connected through a JMicron JM20330 IDE to SATA bridge, has the same behaviour as the Sandisk CF cards, the Verbatim 2GB CF card and the Kingston 16GB CF card (freezes at boot) .
I dug up a SATA 2.5" Samsung ST1000LM024 1TB hard drive, tried it through the JM020330, and it works fine (externally powered as it has a 4.25W draw according to label)!
The VS-880EX just does not like the Adata SSD (some might say that it has good taste), but it has no trouble running through cascaded IDE to SATA and SATA to IDE bridges! If the VS-880EX behaves the same way with a Kingston A400, I may just go insane(r)!
Reply 15 of 38, by Shreddoc
As a last resort, could just source a bunch of cheap, compatible 2.5" spinning drives, and churn through those over time. This is an era when such drives are quite cheap, due to the scrap supply from the past decade+'s notebook computers, but that cheap era will not remain so forever.
Reply 16 of 38, by darry
Shreddoc wrote on 2020-10-05, 23:03:
That is definitely an option, but It may not come to that. Out of curiosity, I tried it with a 500GB Samsung 860 Evo and it appears to work (did not try formatting, but at least it did not freeze during boot and let met get to the formatting prompt)!
Apparently, the VS-880EX "likes" some SSDs but "hates" some others . I would prefer no to use an 860 Evo because of its power requirements (4W) and because it's waste to use a minimum 250GB premium (expensive) SSD in a 4GB application. I may just get lucky with the Kingston A400 . Fingers crossed .
Reply 17 of 38, by darry
The Adata SU655 that I have (there appear to be variants) is based on the Maxiotek/Maxio (JMicron spin-off) MAS0902A-B2C .
The Kingston A400 apparently uses a Phison S11 controller .
If the A400 does not work, I do have a few SSDs in service at my place that I could half-heartedly test to try to find which controller(s) the VS-880EX likes . At least I know it likes Samsung 860 EVO SSDs, so that's a fall-back plan (I could always re-purpose a 250GB one after upgrading it, but it still feels like a waste).
EDIT: My initial plan was to be able to use commodity, inexpensive flash cards. I have ordered 2 more generic SD to IDE converters on the off chance they might have less buggy behaviour than my microSD to CF units .
Reply 18 of 38, by darry
So apparently, the only SSD that seems to work (still needs to be fully tested) so far is a Samsung 860 EVO .
Just to be clear, I did not return any of these test purchases . IMHO, they are not defective and should not be returned . My compatibility issues in a very specific/odd use-case should not be of concern to the vendor, again IMHO .
EDIT: The VS-880EX also seems to like a Kingston HyperX 240GB SHFS37A/240G (SandForce®SF-2281 based). It gets to the formatting screen .
Reply 19 of 38, by pentiumspeed
Darry,
Make sure you have storage disk (not removable) bit set in CF cards. That shows the issues I had with CF cards. Find 2GB or 4GB CF and do a test on a slot 1 machine, by using DOS and prepare them for bootable and if they boot in DOS, might work in your VS-880EX.
Ones that works:
Transcend
Industrial grade CF cards.
Swissbit 8GB CF
Cheers,
Great Northern aka Canada.
