First post, by InbetweenDays
- Member
I couldn't find this information anywhere else online so after I finally worked it out, I thought I'd post here.
This is for the IBM 720k external floppy drive type 4865 as used with the 5160 & 5170. Internally mine uses the Alps DFL413C02B which apparently is the same drive as used with the PS/2 series (40 pin edge connector).
Mine could only read/write disks it had formatted, which were then not readable in another machine (I formatted a 1.44MB as 720K and copied some files to it. When I tested it in 1.44MB drive again, it still showed the original FAT). It wouldn't read 720K originals or disks formatted in a different drive... ie, classic head alignment issue.
I used ImageDisk aka IMD after seeing this page on aligning a 5.25" drive. The only info I could find on aligning 3.5" drives talks about loosening the stepper motor and rotating it... which doesn't work on this Alps drive.
Long story short, I eventually found the right alignment screw - this is a conical adjustment rod that pushes against the end of the worm gear shaft to move the position of the heads. See pic below...
In my case I also needed to adjust the position of the track 0 sensor. I used a DMM to check the sensor voltage (3rd solder point down in the pic) as I adjusted it, until I was getting ~5V with the heads on track 0, and I think <1V when moved to track 1. Again, couldn't have done it without ImageDisk... fantastic utility.
It don't mean a thing if it ain't got 5-pin DIN.
Roland addict and founding member of the Association Of Molex Haters
